Old 11-17-2014, 11:55 AM   #15
DarkSunrise
DarkSunrise's Avatar
I don't notice any loss in steering response or feedback at the track on 235/40/17, but the sidewall on these tires is very stiff (NT05) and they're mounted on 8" wide wheels.
Also note the reduced sidewall makes the fender gap more noticeable on stock suspension.
I'd go with 215 or 225 in your position.
2022 BRZ Build
2013 FR-S Build
Old 11-17-2014, 12:56 PM   #16
Superhatch
AIM4APX
Superhatch's Avatar
Drives: 2013 WRB BRZ Limited
Originally Posted by juliog View Post
Keep in mind that the actual width of the tire varies per manufacturer/tire model, e.g. not all 225s are the same width..
The sidewall to sidewall measurement has an industry standard, and this is measured and repeatable between manufacturers.
The tread width does not have any standard, and this is where you can see different contact patches for the same size tire between different styles of tire (winter vs. all season vs. summer) and manufacturers (dunlop vs. nitto summer tires of the same size).
http://www.tirerack.com/tires/tirete...jsp?techid=194
Note section: Section Width.
So a 225 will always have a sidewall to sidewall measurement of 225mm (see Section Width below), but the tread of two 225 wide tires can be different (see Tread Width below).
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
Superhatch is offline   Reply With Quote
Old 11-21-2014, 05:19 PM   #17
ashtray
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
UPDATE:
Ok, so I decided to go with 225/45/17 on my 7.75" rims. Michelin Pilot Super Sports.
$70 rebate going on now. Got a decent deal locally. They had to order them but will get them Monday. Looking forward to the newfound grip but also the ability to drive my car in the rain this winter.
Debated for a while between 215 and 225, but in the end its not going to have a huge impact and I'd prefer that tiny bit more of traction. With the wider than stock rims, I figure overall height/diameter is close to stock.
ashtray is offline   Reply With Quote
Old 11-25-2014, 07:25 PM   #18
ashtray
Ok, 225/45/17 Pilot Super Sports = super happy.
Should have done this 2 years ago...
Old 11-26-2014, 04:22 PM   #19
jflogerzi
jflogerzi's Avatar
This what run and extremely happy.
2013 Series 10 FRS #553
Optimal Wheel Size for Stock Power Tanuki Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 110 06-09-2016 10:08 PM
optimal tire size for stock wheels brillo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 12-05-2015 12:01 PM
Optimal tire for 17" rim RealShkillz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 10-20-2015 04:18 PM
Optimal Tire Size For Stock Rims Raven604 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 04-05-2013 08:41 PM
optimal street tire size for RTR on 17x7 hankster Tracking / Autocross / HPDE / Drifting 110 03-21-2013 12:40 AM
