Old 11-10-2014, 06:26 PM   #15
Outlawstar98
SLOW BRZ
Outlawstar98's Avatar
Drives: 2013 328i xDrive; 2013 BRZ
Project Kics or bust!
Outlawstar98 is offline   Reply With Quote
Old 11-11-2014, 02:43 AM   #16
robot
There are now 2 carseats!
Drives: 2013 DGM BRZ
mcguard.
Spline drive.
-Don't get ones for aftermarket wheels and put them on your stock wheels as they wont seat right.
-Do get aftermarket conical ones for aftermarket wheels.
-the mguards I had on my sti never tarnished in dc winters with hour plus long commutes and tons of salt.
-the part that seats on the wheel moves separate from the rest of the nut so that the wheels don't get scratched.
-the Subaru sti branded ones are these...so they are oem quality.
-project kics are super expensive for what they are
-mutely ones are safe but slightly cheesy. In the past they had finishes that came off over time. They might be better now.
-saving weight by buying lightweight lug nuts is silly. Take a piss before getting in the car and you will notice the same difference.
robot is offline   Reply With Quote
The Following 4 Users Say Thank You to robot For This Useful Post:
campy (11-11-2014), DAEMANO (11-11-2014), Marcoscrdo (11-13-2014), sprintertrueno86 (11-11-2014)
Old 11-11-2014, 02:44 AM   #17
robot
http://www.oakos.com/Merchant2/merch...ory_Code=15STI
I also wanted to not sound like the grumpy old man here and commend you on the effort of researching a gift for your boyfriend. Many would not got to this length.
Old 11-11-2014, 09:17 AM   #18
enouf
Mr. Grumpy
enouf's Avatar
Drives: 86 GT, Fuji Red, MT
+1 for McGard SplineDrive
[ame="http://www.amazon.com/McGard-65554BK-Chrome-SplineDrive-Installation/dp/B0006HOVNE"]Amazon.com: McGard 65554BK Chrome/Black SplineDrive Wheel Installation Kit (M12 x 1.25 Thread Size) - For 5 Lug Wheels: Automotive[/ame]
enouf is offline   Reply With Quote
Old 11-11-2014, 09:28 AM   #19
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by robot View Post
mcguard.
Spline drive.
Uhmm oem wheels are conical like aftermarket ones in our case. These aren't Hondas with ball seat wheels.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
Koa (11-11-2014)
Old 11-11-2014, 07:10 PM   #20
extrashaky
Drives: 2014 BRZ Limited
It's worth noting that the difference between those two kits is that the one on Amazon has locks. The lock kit is $40 by itself, so that's not a bad deal at Amazon. (I actually bought a set of these for my own car.)
But again, the guy may not like spline drive nuts. I think she should get him what he wants, even if that's bright red SR48s.
Old 11-11-2014, 10:23 PM   #21
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Ok. I'm about to ask two very lazy questions because I really don't feel like pulling a wheel off of my BRZ.
Just received by winter tires on steelies from TireRack. They came with small, open-ended lug nuts. I don't really want to use open-ended lugs as I want to protect the studs from rusting. I suppose if all else fails, I could just smear a bit of grease on the protruding studs every so often.
Q1: The lugs that came with the steelies are the tapered (not rounded) base lugs. Are the stock lugs on the BRZ tapered as well? (I have a Series.Blue, which has different wheels, so maybe that's difficult for most of you to answer offhand, I dunno.)
Q2: I assume the stock lugs are not to be used because they aren't deep enough to properly seat against the thin steelie. Can someone point me to a nice set of black lug nuts on Amazon that will be deep enough for my steelies, and that I can maybe use for the stock wheels come spring if they do indeed have the same base style?
Bonus Q: Why the hell doesn't the spare tire require separate lugs if the stock ones bottom out?!
Stang70Fastback is offline   Reply With Quote
Old 11-12-2014, 10:17 PM   #22
Fastbrew
Drives: 2014 Pearl White BRZ
[ame="https://www.youtube.com/watch?v=g_cQ2hDb9wc"]Johnny Limbo and the Lugnuts 8-24-13 White Salmon Wa. - YouTube[/ame]
Fastbrew is offline   Reply With Quote
Old 11-22-2014, 04:48 AM   #23
Bongertz
Drives: Brz
I own a wrb brz with the sti kit, and just recently got the rota titans flat black. Should I get lack lugs or should I pick something that'll add a little color? Sr35 blue or chrome?
Bongertz is offline   Reply With Quote
Old 11-22-2014, 08:53 AM   #24
whataboutbob
AutoX-10/10ths every run
If you want performance and don't need locks CSG Chromoly: http://counterspacegarage.com/produc...s-m12x125.html
Build thread:Here
This car is nuts!!! 200 hp?!? No way. Jen Scion FR-S / Toyota 86 GT86 General Forum 408 04-23-2014 04:00 AM
Wrx lug nuts and frs lug nuts? Frs123 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 11-15-2013 09:35 PM
Lug Nuts Overland'n'5thGEN Northern California 9 07-22-2013 05:16 PM
Lug Nuts BRZ loogs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 07-17-2013 12:09 AM
Lug nuts? Ludacrits Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 06-24-2013 11:13 AM
