Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
11-04-2014, 11:29 AM | #15 |
Drives: 2013 Scion FRS in white out
Everytime I've flashed the car it's taken a couple hrs of driving before everything is sorted. I don't think It's am instantaneous change like some think
2013 Scion Frs AT in Whiteout, Borla UEL header, Greddy SP Elite AxleBack. Kraftwerks C38 Supercharger tuned by Moto East and 2 kid seats in the back.
11-04-2014, 11:33 AM | #16 | |
To be clear, it looks like I lost power from 2700-3700 RPM and from 5000-6300 RPM. Again, not jumping to conclusions, just stating facts for now. I'll pay (again) to re-dyno, and will update with results.
2022 BRZ Build 2013 FR-S Build |
The Following User Says Thank You to DarkSunrise For This Useful Post: | wootwoot (11-04-2014) |
11-04-2014, 11:44 AM | #17 |
Unless your fuel trims are wildly off, dynoing immediately after a flash should give representative. OFT OTS tunes start IAM at 1.
How much time went by between the runs? Same temps?
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
11-04-2014, 11:52 AM | #18 | |
If the car cooled down (or if it needs time to adjust after the flash), it's possible the after dyno was done with the limp VVT tables active, which kills power.
The Following User Says Thank You to wparsons For This Useful Post: | DAEMANO (11-06-2014) |
11-04-2014, 11:52 AM | #19 |
StreetKart
Drives: 2014 Scion FR-S Monogram
i've never heard of having to wait for a tune to take effect... i'd flash it again and make sure you actually flashed the tune in the car....
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
11-04-2014, 12:01 PM | #20 | |
The Following User Says Thank You to phrosty For This Useful Post: | DAEMANO (11-06-2014) |
11-04-2014, 12:05 PM | #21 | |
I'm sure coolant temps had dropped during that time, but we did 3 runs post-flash. I would think by the 3rd run coolant temps would have stabilized, but who knows.
11-04-2014, 12:10 PM | #22 | |
Hicas Thread Basher
Drives: Subaru BRZ 13, Hyundai Genesis 15
yes, te ecu need a little time to re-learn... |
11-04-2014, 12:17 PM | #23 |
Open Loop actually.
The Following 2 Users Say Thank You to s2d4 For This Useful Post: | DarkSunrise (11-04-2014), Pseud0logik (11-15-2014) |
11-04-2014, 12:19 PM | #24 |
Drives: 2013 FRS
FWIW, just yesterday I tested a FRS (6AT) with only Grimmspeed intake on the dyno yesterday. Stock tune, it put down 171whp (as expected). With Stage 1 tune, it put down 177whp.
https://www.facebook.com/23343167667...type=1&theater OP- You should be able to see bigger gains that what you saw when even running the stock tune. One thing I do remember about tuning a JDL header (their EL version) was that it needed a lot of runs (with very little cool down) to get up to temp. And each successive run would make 1-2hp more. I took 4 or 5 runs before it was up to temp and made peak power. This is because their headers are quite heavy (thick gauge material) and have a lot of thermal mass. This is the reason why heavy headers benefit from heat wrap or thermal coating. This is also the reason our own header uses thinner gauge material. That said, I have never tested their UEL header so for all we know, it may have different mapping needs that other UEL headers that we've tested. Custom tuning would be the next natural step in this situation. |
11-04-2014, 12:23 PM | #25 |
op,
do you have logs of those runs?
11-04-2014, 12:28 PM | #26 | |
I'm pretty sure the tune file loaded properly since I haven't seen any CELs for removing the first cat, but to be safe, I'll try re-flashing.
11-04-2014, 12:30 PM | #27 |
Wasn't logging at the time unfortunately.
11-04-2014, 12:40 PM | #28 |
Drives: 2013 FRS
By the looks of it (high higher, soft fuel cut), you have a tune file loaded. So I don't think that is the culprit. That header may just require custom tuning. Do you know if you were running a 93oct map or a 91oct map? The 93oct map, on 93oct, will make a few hp more.
Similar Threads | ||||
Quick Review-OpenFlash (Dyno Test) - Stock vs. Vishnu Stage 1.0 vs. Vishnu Stage 1.1 | FRSTEVE | Software Tuning | 105 | 08-04-2017 04:48 AM |
Stock FR-S/BRZ shock dyno & stock FR-S spring dyno | xwd | Tracking / Autocross / HPDE / Drifting | 16 | 08-07-2014 09:04 PM |
Stock Dyno vs GReddy Intake Dyno | JTOFJPN | Engine, Exhaust, Transmission | 0 | 06-01-2014 03:56 AM |
Stock Dyno and Perrin Stage 1 Results | brillo | Software Tuning | 4 | 01-24-2014 08:26 AM |
FINAL RESULTS: Taking Full Blown Stage 1 To The MAX! @Pure Automotive (Dyno Inside!) | Pure Automotive | Forced Induction | 57 | 03-27-2013 11:41 PM |
