Old 11-02-2014, 08:43 PM   #15
I fill mine with helium!
My car is .0000000000001 pounds lighter now!
flippy (11-20-2014)
Old 11-02-2014, 09:36 PM   #16
Whatabouteggs
[Citation Needed]
Drives: 2014 WR Blue Subaru BRZ Premium
I use an approximately 78% concentration of nitrogen with 20% oxygen and some other proprietary compounds.
Whatabouteggs is offline   Reply With Quote
The Following 2 Users Say Thank You to Whatabouteggs For This Useful Post:
Dadhawk (11-03-2014), Laika (12-17-2014)
Old 11-02-2014, 10:42 PM   #17
Ultramaroon
not playing cards
Ultramaroon's Avatar
Beat me to it!
Old 11-02-2014, 11:05 PM   #18
Poodles
Drives: 2015 Series.Blue
The supposed other advantage is that the tires won't oxidize from the inside out... Dunno how much I believe of that, but if I was given the option to use nitrogen for free/cheap, I'd probably do it as a "why not?"
I'm sure we do dumber things to our cars that has no real function...
The Following User Says Thank You to Poodles For This Useful Post:
Bristecom (12-03-2014)
Old 11-03-2014, 07:18 AM   #19
tnle
Drives: Toyota 86 13'
Waste of money for street driving and the track day regulars (imo), unless you're chasing ten tenths competitively.
Ran it once to trial out it's characteristics on track and wasn't blown away, finished the day and refilled tires with "regular" air... because its free...
tnle is offline   Reply With Quote
Old 11-03-2014, 07:53 AM   #20
Kelbyat07
Poor College Kid
Kelbyat07's Avatar
Drives: ~.~
I thought we get it for free.. well at least for me.
Kelbyat07 is offline   Reply With Quote
Old 11-03-2014, 09:20 AM   #21
As opposed to oxidizing from the outside?
Mitsu salesguy tried that line when I was looking at Evos. Said as soon as you put air under pressure the oxygen level sky rockets and destroys the tires from the inside. I laughed so much I almost puked right in the showroom.
The great part was when I asked if they would change the air in my Lancer GT tires to nitrogen (as a joke) he said they couldn't do it there as they didn't have a tank.
gramicci101 (11-03-2014)
Old 11-03-2014, 12:59 PM   #22
BRZ21
i kill cones.
BRZ21's Avatar
Drives: around cones in a parking lot
the only reason is to limit the fluctuation in pressures due to temperature changes.
that is the only reason. regular driving you probably wont notice any difference (except around this time of year as temps cool off)
on the track it is much more stable.
anyone that says it doesnt do anything is wrong.
2013 SSM BRZ Limited 6MT
BRZ21 is offline   Reply With Quote
Old 11-03-2014, 01:12 PM   #23
stugray
Drives: 2013 GBS BRZ Limited
Originally Posted by BRZ21 View Post
the only reason is to limit the fluctuation in pressures due to temperature changes.. that is the only reason
If you use DRY AIR, there is no difference.
AIR is 80% Nitrogen AND ~20% Oxygen.
Nitrogen & Oxygen are RIGHT NEXT TO EACH OTHER on the periodic table
Therefore a cylinder filled with 100% Nitrogen will experience EXACTLY the same change in pressure with temp as a cylinder filled with 80% nitrogen & 20% oxygen.
I say it doesnt do anything and I say YOU are wrong.
SCIENCE Bitches!
The Following 2 Users Say Thank You to stugray For This Useful Post:
rice_classic (11-20-2014), Tcoat (11-04-2014)
Old 11-04-2014, 02:01 PM   #24
BRZ21
i kill cones.
BRZ21's Avatar
SCIENCE Bitches!
Dry air? Thats just as complicated to find...
You're right with your idea but in the real world "air" in your tires is whatever "air" your compressor pumps in... not dry.
I'm not wrong.
Old 11-04-2014, 02:18 PM   #25
Ultramaroon
not playing cards
I fill my tires with used coolant so the pressure doesn't change at all.
Old 11-04-2014, 02:25 PM   #26
I just change my air each season.
Just put my winter air in as the summer stuff just wasn't cutting it anymore!
Old 11-04-2014, 02:29 PM   #27
stugray
I'm not wrong.
You must not work around auto paint much. They ALL have air dryers on the compressors.
I will rephrase:
"There is no difference between using dry air versus Nitrogen to fill your tires. Anyone who says otherwise is wrong"
Actually this discussion made me think about it a lot.
IF you could find a phase change liquid that evaporates right at the final target temp of the tires at race temps, then you could have MORE STABLE temps than anyone experiences right now.
The liquid would work as a tire balancer (like the little beads that some use) and would evaporate to keep the tire temps stable.
I have never heard of that before.
We use some interesting liquids at work as cooling fluid.
It evaporates at 70F and leaves NOTHING behind.
I used it in my ultrasonic cleaner to clean some carb parts.
It was cool - pour in fluid, turn on cleaner with heat.
Come back in 20 minutes and parts are clean, dry, and there is now dry-dirt at the bottom of the cleaner. It is similar to dry cleaning fluid.
Old 11-04-2014, 02:38 PM   #28
Ultramaroon
not playing cards
Awww, damn it, Stu. I was just d!cking around. Now I'm going to have to pull out my thermo text. I hear what you're saying but I feel like there's something being overlooked.
Toyota filled my coolant overflow with washer fluid Decay107 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 36 08-11-2016 10:18 AM
Is the front sway bar bushings liquid filled? Rayme Issues | Warranty | Recalls / TSB 13 10-02-2014 05:06 PM
filled up w e85 now car wont start..id1000s dw65s jdl kit kingkai23 Forced Induction 8 07-24-2014 10:56 AM
Prescription Filled!!! SIC8D6 Scion FR-S / Toyota 86 GT86 General Forum 39 04-12-2014 01:47 AM
Dealer filled my new FRS with 87 octane; Should I flash ECU? Hakuzen Issues | Warranty | Recalls / TSB 37 01-09-2014 05:52 PM
