Old 10-15-2014, 08:22 PM   #15
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
You can always swap back to your stock header to get through inspection, it only takes 30-45 mins to do.
Old 10-15-2014, 08:40 PM   #16
Foobar
SLO NO MO
Foobar's Avatar
Originally Posted by phrosty View Post
It's my understanding that emissions testing looks at OBD2 readiness checks, not CELs, and a tune can not defeat this.
ECUTek is able to do it (force readiness). At least for O2 - I presume the rest just as easily. That being the case, it's likely the other tuning platforms can as well.
That all said, my information is second-hand (posted on this forum elsewhere), I'm not a tuner.
Old 10-16-2014, 02:06 AM   #17
steve99
What is OBD-2 readyness check ??
Does this just mean the odb-2 diagnostic port works and parameters can be accessed ??
The ECU will flag the P0420 cat efficiency code you have no cat in the header the main secondary cat in mid pipe is not monitored.
The ECU works out if its going to flag the P0420 code (cat efficiency) by comparing the readings from the 02 sensor's before and after the cat in the header .
The 02 sensors are not disabled and both 02 sensors are still active and the readings available to the ECU with a "tuned" rom just the activation of the P0420 CEL code is disabled. You can do this on a "stock" tune as well.
If the emissions guys are just using a standard OBD reader the 02 signal will still be available as will all other obd functions its just the ecu will not flag a P0420 CEL code and the ODB reader will not see it.
Old 10-16-2014, 08:12 AM   #18
eachey51
eachey51's Avatar
Drives:
I am buying a catless header! It sounds way better and if i get a cel i can just swap my stocker back on to pass inspection
eachey51 is offline   Reply With Quote
The Following User Says Thank You to eachey51 For This Useful Post:
B-R-Z (10-16-2014)
Old 10-16-2014, 08:49 AM   #19
B-R-Z
B-R-Z's Avatar
That's my plan as well. I have a catless UEL and OFT tune so I get no CEL and not due for inspection until 2018.
Def go UEL, the performance gain of EL vs UEL in NA vehicle is negligible. Plus, you want rumbles.
Old 10-17-2014, 08:10 AM   #20
eachey51
eachey51's Avatar
Drives:
I bought the car knowing i wanted an uel header! That sound and the low end torque tho! Cant wait to rumble around my back roads
Old 10-19-2014, 06:23 PM   #21
ramiram1984
Drives: 2016 STi DGM
[ame]https://m.youtube.com/watch?v=FBftmylvLC4[/ame]
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
Loud exhaust / Buddy Club Spec II exhaust help! chiefshayan Engine, Exhaust, Transmission 26 12-06-2019 05:59 PM
Another project teaser. Exhaust hole covers for single exit exhaust! Wonderbar Cosmetic Modification (Interior/Exterior/Lighting) 57 05-30-2014 01:46 AM
The Exhaust Diet: Lightest Header to Exhaust tip combo phastafrican Engine, Exhaust, Transmission 3 12-30-2013 08:44 PM
Revive Your Exhaust Tone with Our Debut FT86Club Exhaust Clearance Sale! FRSport.com Engine, Exhaust, Bolt-Ons 0 09-06-2013 02:08 PM
Perrin Catback Exhaust vs Nameless Performance Exhaust. vignesh Engine, Exhaust, Transmission 201 06-05-2013 09:47 PM
