#15 | |
Country Boy 4 Life
Lots of info on here about 17x9 +45 rubbing. +42 only gives 3mm of clearance. So, depending on what 255 tire you choose, you will need a spacer. Additionally, to really feel the grip of the fronts, you will need some negative camber. I have 18x9 +42 with 245/35. So, same wheel offset and width. I first added a 5mm spacer. Then I added a 10mm spacer. Now I'm running a 12mm spacer. 10mm+ will give you room for a 255, room to install camber bolts, and add negative camber. Win-win!
I LIKE TIRES! |
| Wheel Directory: Rota Grid 18x8.5 +44 / 18x9.5 +38 | CoRi J | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 119 | 04-26-2019 10:42 PM |
| Wheel Directory: Rota Grid 18x9.5 +38 | Sandman3zb | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 67 | 06-20-2017 02:41 AM |
| Wheel Directory: Rota Grid 18x8.5 +44 | Cjymiller | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 26 | 09-05-2016 11:42 PM |
| Wheel Directory: Rota Grid 17x9.0 +42 | BlaineWasHere | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 81 | 06-26-2015 09:12 PM |
| Wheel Directory: Rota Grid 2 17x8.0 +38 | stvrjs | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 27 | 09-02-2013 05:08 AM |
