#15 |
Drives: Toyota
You need to make sure the car is on a level not just front and back but left to right as well, gas station or some parking lot is USUALLY good, as the side of the street has a dip towards the gutter.
Take a hot reading and take one parked overnight if you have a garage, that should help you understand how much oil is drained back. Usually, it is about 1/8 - 1/4" difference. You kind of want the cold reading on level surface to be at least above the high dot, obviously. It's all relative as long as you park the car in the same spot, I prefer a hot reading seeing the oil on the top dot. It's possible factory put in a little more as the engine breaks it the rings may use some oil, 1cm sounds OK, the picture posted look a little high |
#16 |
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
Mine's a bit overfilled as well
#17 |
Re-member
Drives: Toyota camry
Anyone thinks this overfilling is related to the idle issue that others are experiencing?
Nothing decays like progress, and nothing preserves like neglect.
#18 |
Loves the Smell of Track
Drives: '13 86
Mine's reading ~ 1/2 pint high as well. Won't know how accurate the dipstick is until refill with correct amount. I'm not concerned enough to to dump the oil before its due.
2020 86 Hakone MT build thread: https://www.ft86club.com/forums/show...31#post3326231
2013 Toyobaru 86/FR-S 6MT, Red, aka Candy O SOLD http://www.ft86club.com/forums/showthread.php?t=7934 Last edited by phm14; 06-16-2012 at 02:52 AM. |
#19 |
Drives: Toyota
If it bothers you, and you don't have an oil extractor, you can use a mity vac to suck it out of the dipstick tube.
#20 |
First 86
Drives: Scion FRS Argento Automatic
I checked my oil in the morning while the car was at a slight(3-5 degrees) incline (rear lower than front) after a 200 mile drive at an average speed of 70 mph. The dipstick showed about a half quart low, so I added half a quart. Checking my oil on my return on a flat surface and cold it showed about a half quart high. So it seems like the dipstick is pretty sensitive to being on a flat/inclined surface.
Life is short...NO BORING CARS |
| The Following User Says Thank You to russv For This Useful Post: | jcw99 (12-09-2016) |
#21 | |
FT86Club Vancouver
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Foam = fail lubricant... Now, this applies for traditional Inline/V/W engines, but not sure about horizontally opposed boxers... I would assume the same applies though. |
#22 |
A little overfilled is not a big deal at all. If it's a quart or more overfilled then I would do something about it. I work at toyota and the new prius motor is supposedly sensitive to overfilling because it could effect fuel economy to the point that it will throw a check engine light if it's overfilled. But it takes almost a whole quart overfilled to do that. So I guess I'm trying to say anything under 1/2 a quart over should be nothing to worry about at all. We got a engine that was overfilled in a Camry which caused it to foam but go to find out the customer had poured an extra 3-4 quarts during his DIY oil change.
| The Following User Says Thank You to DYOLF26 For This Useful Post: | jcw99 (12-09-2016) |
#23 |
Drives: Whiteout FR-S
Well I just sanded mine, and even after I just get out of the car from driving, I can read it with no problems
Defiantly a must for this car! I'll try and post a picture or two later when I get around to it. |
| The Following User Says Thank You to yayforaddison For This Useful Post: | jcw99 (12-09-2016) |
#24 |
First 86
Coming from 2 Mini Coopers which had impossible oil dipsticks to read the FRS is ok.
#25 | |
Drives: Black GTS86 Aero
Mmmmmm whipped oil
#26 | |
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
Mine is up the the hole in the middle. Is that good?
#27 |
Re-member
Just slightly over filled is not a bad thing, it might reduce mpg a negligible amount but it wont cause problems. Keep in mind, the more oil, the more ability to suspend and neutralize contaminants. Not a bad thing for a new engine.
#28 |
Drives: Evo 8
Add the correct amount then Try checking it with it cold in the AM always had issues reading my WRX's in the past while warm it splashes up reads funky
| Factory Roof Rack? | \o/ | Scion FR-S / Toyota 86 GT86 General Forum | 92 | 02-15-2013 04:25 AM |
| Factory Service Manual | Brett | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 25 | 06-11-2012 12:12 AM |
| Car Cover (Factory or Otherwise)? | Biggins | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 04-22-2012 10:25 AM |
| An entry level FR revival? | aliphian | Other Vehicles & General Automotive Discussions | 9 | 11-14-2011 09:09 PM |
| How much are you guys paying to fill your tanks? | Giccin | Off-Topic Lounge [WARNING: NO POLITICS] | 64 | 04-13-2011 02:36 AM |
