Old 10-06-2014, 02:12 PM   #15
mkivsoopra
I have this issue too. My stage 1 did something similar, though not as often, so I never thought much of it. I only have a few thousand miles on it so far, and was broken in as per instructions. Also greased the splines with the included grease as per instructions as well.
mkivsoopra is offline   Reply With Quote
The Following User Says Thank You to mkivsoopra For This Useful Post:
Sportsguy83 (10-06-2014)
Old 10-06-2014, 02:30 PM   #16
Shady195
Drives: '13 10 Series FRS #1203
I guess my question is then...
Why is clutch dust build up an issue on aftermarket clutches and not on the factory one? Seems odd pointing to dust specifically.
Not doubting there is an issue here with aftermarket setups vs stock, clearly there is. Just seems odd that dust would be the culprit on an aftermarket and not factory disc.
Shady195 is offline   Reply With Quote
Old 10-06-2014, 02:40 PM   #17
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Exedy Stg. 2 tolerances seem to not be right for the input shaft (too tight)....
Old 10-06-2014, 02:45 PM   #18
Shady195
Given how tight those tolerances are to begin with, I would imagine it would be damn near impossible to get the transmission seated without a lot of force. Which someone should have taken as being wrong to begin with no?
Old 10-06-2014, 02:51 PM   #19
Sportsguy83
Drives: Limited BRZ
The tolerance between the input shaft and the hub of the clutch disk is what I'm talking about.
Let me ask you, if it's not dust or tolerances, what do you think it is?
Because the other thing that can make a clutch drag is a bad pressure plate.
Again, consider this is not 1 or 2 random people with issues, this is "I know more than 10 people with the same clutch (between forum and locals) and all of them have the issue at some point".
The Following User Says Thank You to Sportsguy83 For This Useful Post:
GT86_PRAGUE (12-12-2014)
Old 10-06-2014, 02:56 PM   #20
blown
Drives: ft86
just ordered the stage2 clutch
blown is offline   Reply With Quote
Old 10-06-2014, 03:03 PM   #21
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
A guy with a centerforce clutch also had the same issue.
JDKane527 is offline   Reply With Quote
The Following User Says Thank You to JDKane527 For This Useful Post:
Old 10-06-2014, 03:06 PM   #22
marcoaferrer
marcoaferrer's Avatar
Drives: Whiteout FR-S
The other thing to take into consideration is the type of dust. Organic friction disk residue vs. cerametallic. Also exedy states that the break in period is crucial because on a newly fitted clutch only 30% of the fiction material is making contact. So i would imagine there would be a lot of dust generated merely from breakin
marcoaferrer is offline   Reply With Quote
The Following User Says Thank You to marcoaferrer For This Useful Post:
Old 10-06-2014, 03:11 PM   #23
buddy32
Drives: WRB Subaru BRZ Limited
So extremely annoying. I'm going to warranty this with Exedy and get a different brand. Still looking at options and haven't decided which one.
Whoa, was gonna order this clutch soon too.... good thing saw this thread before that!
Mind posting up what you replace with later on?
buddy32 is offline   Reply With Quote
Old 10-06-2014, 03:12 PM   #24
Sportsguy83
Drives: Limited BRZ
Sure, will do
buddy32 (10-06-2014)
Old 10-06-2014, 03:19 PM   #25
jher
Drives: 2013 Scion FRS
Damn, just got mine installed last week. Will keep a look out for this issue. Suck big time.
jher is offline   Reply With Quote
Old 10-06-2014, 03:30 PM   #26
Shady195
Because the other thing that can make a clutch slip is a bad pressure plate.
What I was speaking of as well.
I don't know, bad pressure plate seems more likely than dust IMO.
I'm not discrediting the issue at all here, just throwing ideas and my own opinions out.
Old 10-06-2014, 03:50 PM   #27
Xerious
Speed Chaser Thrill Seekr
Xerious's Avatar
Drives: 2014 Asphalt Monogram FR-S 6MT
@jher I was about to order this clutch this week. I guess I'll have to hear from you as well as follow this thread. I'm also curious about alternatives that people find that work.
Performance: Jackson Racing SC & Oil Cooler, 18x9.5 Gram Lights 57Xtreme Wheels, 255/35 Yokohoma Tires, Rays Volk Racing Black 17hex 12x1.25 lugs, KW V3 C/O, Stance Control Arms
Exterior: LED DRL MOD Kit, Tom's Tail-lights, 5%/40% tint
My Build
Xerious is offline   Reply With Quote
Old 10-06-2014, 04:25 PM   #28
jher
Yeah I would waited it out until things get sorted out or fix. Xerious ask CSGMike what clutch is he running?
Exedy Clutch KAR Engine, Exhaust, Transmission 28 01-03-2016 08:27 PM
Exedy Stage 2 Clutch alpine Engine, Exhaust, Transmission 21 09-09-2014 01:24 AM
Share your interesting experience when you bought your BRZ/FRS g0ast BRZ First-Gen (2012+) — General Topics 18 02-25-2014 01:39 PM
exedy clutch questions ft86me Engine, Exhaust, Transmission 8 02-13-2014 10:58 PM
