Old 02-12-2015, 07:02 PM   #15
fantah
fantah's Avatar
Drives: 2013 BRZ Premium Black
supposedly the ECU reflash from the dealership will fix it. When I took my brz in they wouldn't reflash the ecu unless the CEL came up, which never happened. Now that im on stage 2 OFT I haven't had the problem since because Shiv said applied the update for the RPM drop as well.
fantah is offline   Reply With Quote
Old 02-12-2015, 08:04 PM   #16
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Nope, the reason why the flash "fixed" it is because it fixes the RPM from dipping so low during idle, and indirectly "fixing" the LED blinking.
As some of you may know, any LED component require very little power to operate them, and without the proper capacitors, they become very sensitive and fluctuate (blink) because of the idle dip causing the car to almost stall out (alternator stop for a split second, restriction of the voltage current).
My point is, there is no REAL fix until Subaru add a capacitor for those DRL LED.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
The Following 2 Users Say Thank You to DaJo For This Useful Post:
Sportsguy83 (04-22-2015), VIPER (04-06-2015)
Old 03-20-2015, 02:22 PM   #17
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Cool
Is there any solution to enable the LED DRL to stay on with the EBRAKE engaged?
Chad86 is offline   Reply With Quote
Old 03-20-2015, 03:19 PM   #18
Koa
.. any chance you can make some headway on this and see how feasible it would be to replace these caps with higher quality ones?
Old 03-21-2015, 04:02 AM   #19
Euro7R
Drives: 2013 Subaru BRZ
This happens to me on the odd day. Whenever I see reflection of my car in traffic while behind someone. Blinks off and on.
Euro7R is offline   Reply With Quote
The Following User Says Thank You to Euro7R For This Useful Post:
VIPER (04-06-2015)
Old 04-11-2015, 12:46 PM   #20
VIPER
Professional Test Driver
VIPER's Avatar
Drives: ’14 Monogram Hot Lava FR-S
I contacted Toyota HQ and opened a case with them, if I can get a real solution I will post the results. Since it seems to effect even he non LED FR-S as ray_viva posted.
If anyone else has already gone through this process let me know. I did let them know about the capacitor DaJo mentioned.
VIPER is offline   Reply With Quote
Old 04-11-2015, 04:11 PM   #21
KalbiCool88
KalbiCool88's Avatar
Drives: 2005 SLK350, 2015 RS 1.0 FRS
Yeah this too has happened to me during idle coming to a stop in traffic. It cuts off for a split second before coming back on. Will be keeping my eye on this thread for updates.
KalbiCool88 is offline   Reply With Quote
Old 04-11-2015, 11:52 PM   #22
spatcha88
Drives: 2013 Scion FRS Whiteout
Originally Posted by ray_viva View Post
I have the same problem too on my FR-S it doesn't have the LED DRLs, but Everytime when I hit the brake the RPM drops and the DRLs shut off and come back on within a sec...
that god damn rpm drop... I get that too bugs the shit out of me
spatcha88 is offline   Reply With Quote
Old 04-20-2015, 03:18 PM   #23
VIPER
VIPER's Avatar
Heard back from Toyota and they are logging the incident and passing it on, but without a current TSB fix on it they don't have a solution. Basically I need to take it in sometime and replicate it and then they will get the regional guy involved, from there it goes higher up into Toyota.
The more people that call or email Toyota the better chance they realize it is not a isolated incident. However not that help with the full pump issue that is more widely noted.
http://www.scion.com/contact/
I go in around July for an oil change, I will try and get a little further then, and update with any new info, if any.
Old 04-20-2015, 03:28 PM   #24
vroom4
Happens to my Brz during hard braking at autox
vroom4 is offline   Reply With Quote
Old 04-22-2015, 10:10 AM   #25
Kevinn
Drives: 2014 BRZ Limited, Black, Manual
Hmm, that's odd. I've never noticed this, but it's rare that I can see my own DRLs when behind the wheel. I have a '14 manual BRZ, I assume it has the updated ECU flash since it's a 2014,and I don't have idle dip issues
However, in my car, the DRLs stay on no matter if I'm in gear, or neutral. The only time the DRLs shut off is if the ebrake is pulled, or the headlights are on. (or car shut off)
I'll have to keep a closer eye on my DRLs as I'm coming to a stop.
Kevinn is offline   Reply With Quote
Old 08-08-2015, 03:58 PM   #26
VIPER
VIPER's Avatar
Went into the Toyota dealership today for my 15 month maintenance, and to have the LED lights checked out. Pretty much what I thought would happen, they just said "If all electrical loads are on then it is possible for the system to be stressed and a slight flickering headlight is the result." I told the service guy I would need to talk to the Tech to explain it in more detail, but that did not happen, and the Tech guy did not fully understand the issue, since the engine dips below 500 RPM with no additional electrical loads, it seems like they did not fully understand the issue. Even if they did understand what was going on, they would not be able to fix it.
Also I asked them to check out the vibration from the side speaker during some bass. they said it was because I had the music up too loud and I should turn down the bass. (also if I could have talked to the tech I could have explained that is not when it is happening, it is on low-med level.
They also tried to tell me it was not time for my 2nd oil change. My milage is only 8,181, but that is for 15 months. So when Toyota told me to have the dealership look at it again I had little faith that anything would be resolved. If you want something fixed you have to do it yourself.
The Following User Says Thank You to VIPER For This Useful Post:
KalbiCool88 (08-08-2015)
Old 08-08-2015, 04:00 PM   #27
KalbiCool88
I thought it was 6 months or 7500 miles whichever comes first?
Sent from my A0001 using Tapatalk
Old 08-08-2015, 08:24 PM   #28
VIPER
VIPER's Avatar
The 2014 Scion FR-S book says 7.5 for months and 7.5 (1000) for millage
AutoWindow 3 blink Tap-Turn Module schwartzki Exterior Parts (Aero, Lighting, Etc.) 1 08-13-2013 06:28 PM
GT86 front panel in the GT6 trailer, but for a blink moment yajin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 05-17-2013 12:43 AM
Is it possible to link the turn signal blink to the side marker on the BRZ? tracerit Cosmetic Modification (Interior/Exterior/Lighting) 1 03-09-2013 02:03 PM
How to: Fixing hyper blink on LED turn signals Laika Cosmetic Modification (Interior/Exterior/Lighting) 0 01-20-2013 06:58 PM
F.S. Three blink...1 tap signal module BMWDavid Audio/Visual, Electronics, Infotainment, NAV 0 10-02-2012 02:37 PM
