Old 09-22-2014, 09:05 AM   #15
nfaj
Drives: 2015 BRZ limited 6MT
Idk my exact speed when it happened. I was paying attention to the road more than the speedo. Regardless of how fast I was going i saw >8500 on the tach :/
nfaj is offline   Reply With Quote
Old 09-22-2014, 09:11 AM   #16
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
Option 1:
Pull the motor, pull the heads, inspect everything.
Option 2:
Do nothing.
Not sure what you are looking for us to tell you? Whether the car seems fine or is acting up, the above are pretty much your only two options regardless. If it hit 8500rpm under minimal load, I wouldn't be too concerned about it personally. Only you know things like if you let the clutch all the way out, how fast you were actually going, etc.
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
The Following 2 Users Say Thank You to woode For This Useful Post:
BRZ21 (09-23-2014), raven1231 (10-10-2015)
Old 09-22-2014, 09:16 AM   #17
nfaj
HELP! accidental overev!
I'm pretty sure the clutch was out all the way for a sec or half a sec max. I was at 7400 when I accidentally down shifted into 3rd. Would a compression/leak down do anything for me as far has piston head damage and bent valves?
Man I'm paranoid as fuck
Old 09-22-2014, 09:24 AM   #18
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
If everything feels fine, you're probably fine. Aside from the balance of the internals, the only issue I can see that prevents higher revs is stuff like valve float causing the piston to contact the valves. Not sure if this is even an issue on our cars or not.
In short, if everything seems fine, you're probably okay. Not much you can do to inspect without a LOT of work that's probably not worth is. ECU most likely already recorded the over-rev as well.
Lastly, I suggest you learn pronated/neutral/supinated hand position shifting instead of "fake gated shifting." You'll be much less likely to miss a shift that way.
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 09-22-2014, 09:29 AM   #19
nfaj
@aznatama Thanks for the advice! Is there anyway to reset the Ecu to erase that over rev log? Disconnect battery maybe?
Old 09-22-2014, 09:38 AM   #20
aznatama
aznatama's Avatar
I don't know about the 86's ECU, or if it even has an overrev counter. However, in cars that DO have the counter, no, it is not generally resettable unless hooked up to a computer. I guess I wasn't completely clear, but I meant that IF the ecu has a counter, it'll likely been tripped already.
'14 BRZ LTD MT DGM
Old 10-10-2015, 08:17 AM   #21
Anon86
Drives: 86
First post here It happened to me two days ago on the track. It was my first trackday, second turn of the day. The main straight finishes almost exactly at the end of 4th gear. I'm very used to downshift to decelerate on street, and therefore I've downshifted to 3rd when I was barely starting to brake. Revvs jumped over 8.5k rpms. I've changed asap to neutral, but a good second passed before I've corrected.
The car seems to be fine, I've babied it for 2 full laps, listening to sounds etc... Since the car was pulling fine I've pushed and I've attained my record lap just 5 minutes after the miss shift.
It's however 2 nights that I can't sleep: I really love my car and I'm worried it will result in a major engine failure sooner or later.
Video:
https://vid.me/G2cJ
Anon86 is offline   Reply With Quote
Old 10-10-2015, 08:50 AM   #22
efactor84
efactor84's Avatar
Drives: 2015 Scion FR-S
You would be that guy to post this. Is the cat driveable? Check the block.
efactor84 is offline   Reply With Quote
Old 10-10-2015, 08:55 AM   #23
ZionsWrath
Thanks
ZionsWrath's Avatar
Originally Posted by TM View Post
Wondering how you were going 110+ when 4th maxes out at 106 on redline???
If i time my shift perfectly i see 107 on the speedo
Old 10-10-2015, 09:32 AM   #24
Video:
https://vid.me/G2cJ
Usually, not always but usually if you are going to cause damage in an over rev it happens right away. With a one off situation I would not worry since the car is running fine. There is really nothing you can do now since if you did cause an issue th damage is already done. Very unlikely you did though so go take a nap and stop obsessing about it.
Old 10-10-2015, 09:43 AM   #25
raven1231
Omg guys I put 87 octane fuel in my car! What should I do
drewbot (10-10-2015)
Old 10-10-2015, 10:11 AM   #26
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
Give up on life, the car is totalled. You should just give it to me.
Bobblehead is offline   Reply With Quote
The Following 2 Users Say Thank You to Bobblehead For This Useful Post:
drewbot (10-10-2015), MisterSheep (10-13-2015)
Old 10-13-2015, 04:58 PM   #27
Fishbed77
Fishbed77's Avatar
Drives: 2013 FR-S 6MT Whiteout
I get it bro I'm just being paranoid since I was going atleast 110+ on 4th that would've easily been over 9k in 3rd .
I gotta say, if you were doing 110 on an interstate, I really don't give a damn what kind of shape your car is in now.
I've just seen too much asshattery on the interstates lately to have much pity.
Fishbed77 is offline   Reply With Quote
Old 10-13-2015, 09:50 PM   #28
radroach
Drives: car
At this point you've voided any notion that anyone should care what you did. 110 in unreasonably fast to be going on a public road.
The Following User Says Thank You to radroach For This Useful Post:
pushrod (10-13-2015)
