Old 09-06-2014, 10:42 PM   #15
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
Originally Posted by Sportsguy83 View Post
GTX3076R/end of story.
I have it in my car with great results, 550 whp @ 19 psi.
@jamesm (best tuner out there in other words) is upgrading his 2867 to a 3076r as we speak.
/end thread.
Why wouldn't you opt for the GTX3576r instead? Better wheel matching and better flow. Spool difference is extremely minimal considering the T350 turbine is a overall better and more efficient design than the T30.
The T30 turbine does well with the vband housings.
Coheed is offline   Reply With Quote
Old 09-06-2014, 10:47 PM   #16
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I honestly didn't consider it.
I was between the 3076 and 3582 and between those two there is noticeable spool difference and since I didn't plan to go over 600 whp anytime soon stayed with the 30
Sent from my SAMSUNG-SM-N900A using Tapatalk
Old 09-06-2014, 11:06 PM   #17
Coheed
Coheed's Avatar
I have extensive experience with the GT3076r, but the GTX is a different animal. Would love do testing on a .82 vband setup with the GTX, as the .63 housing is not my preferable choice for that turbine wheel. It would be interesting to see how this turbo reacts to different cams as well. But 550whp is really cranking on that turbo for stock cams. Congrats on that power number. I've never seen a GT30r hit anything over 480whp In Utah. Turbo just runs out of steam. GTX may be a different story, as it handles higher pressure ratios much better than the regular 76mm wheel.
Would be crazy to see the power this engine would make with a 6262. Probably would only be worth it with cams/springs and a 9k redline. That would be insanity right there. Engine would need extensive work.
The Following User Says Thank You to Coheed For This Useful Post:
Sportsguy83 (09-06-2014)
Old 09-09-2014, 02:56 AM   #18
BadBRZ
Drives: Subaru
Look at fullblowns car that's what they ran at 25psi to hit 760whp
BadBRZ is offline   Reply With Quote
The Following User Says Thank You to BadBRZ For This Useful Post:
Coheed (09-11-2014)
Old 10-02-2014, 10:32 AM   #19
diodelphi
diodelphi's Avatar
Drives: 86
Perrin Performance in wrx
Pre Race brz
Revvolution brz
Ptuning brz
Dynosty brz
Interesting to see Pre Race, Revvolution, Ptuning and Dynosty All used GTX3076R in their tuning for over 350whp.
diodelphi is offline   Reply With Quote
Old 10-02-2014, 05:12 PM   #20
Coheed
Coheed's Avatar
Pre Race brz
Revvolution brz
Ptuning brz
Dynosty brz
The GT3076r should perform well on lower boost levels, but I think the GT3576r will perform better all around. This is purely based on my experiences with the GT3076r and it's downsides in comparison to other turbos in that frame-size. I haven't used the GTx3576r myself, I'm just a number cruncher and theorist at this point. But if it's any consolation, I have been spot on with my predictions in the past...
I believe the hit to response from using the larger turbine would be offset by pairing the larger turbine with the 76mm compressor. The turbine with the longer moment will drive the larger compressor more easily with less backpressure in the housing. Pairing the .63 housing to the t350 turbine will help offset any loss to response while still flowing better than the T30 turbine. Also, surge would be reduced which would help low-end power. If the GTX76r compressor wheel could be had without the ported shroud housing you could gain some efficiency back by switching to a non-ported shroud.
I feel like a lot of decisions are made based on what is popular or has been used a lot in the past. It would be nice to see more data and science to determine which would be the best match for a particular setup. Of course, it probably won't matter on lower boost levels, but I like to geek out over this kind of stuff.
Old 10-03-2014, 02:23 AM   #21
dabocx
dabocx's Avatar
Drives: Scion FRS
Now your making me want the GTX3576r, I wanted the gtx3076 originally but now I dont know
dabocx is offline   Reply With Quote
Old 10-03-2014, 10:04 AM   #22
diodelphi
diodelphi's Avatar
Drives: 86
Thanks so Coheed :-)
Old 10-03-2014, 01:35 PM   #23
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
I personally preferred the GTX2863 over the GTX2867 based on both dyno results and driving results. Had em both on the car. I have driven several and worked on several with the 30 series on them of different variants and still prefer the smaller 28 series assuming you plan to stay sub 450whp. Response is basically instant regardless of RPM and it eats up far less real-estate in the engine bay. At the end of the day there will be several good routes to go and it will come down to type of use the car will be exposed to and personal preference.
LSx Powered 86/ASE Master Certified Automotive Technician
AZFA20 is offline   Reply With Quote
Old 10-04-2014, 03:39 PM   #24
xwd
What A/R are you using on the 2863? The .64 A/R Tial? How is the spool and response compared to the 2867R? I agree both turbos are more than enough for almost everyone.
Dynosty Tuned 530WHP 439TQ Toyota 86 with GTX3076 Turbo Hal@Dynosty Forced Induction 16 10-12-2014 11:59 AM
keep the gtx2867 or get gtx3076 Frs300 Forced Induction 67 09-16-2014 03:28 AM
GT86 Rev Works GTX3076 Turbo Kit Group Buy Interest? Rev Works Forced Induction 1 09-04-2014 02:28 PM
Turbo coolant lines GTX2867. Can I use the throttle body coolant lines? mike the snake Forced Induction 8 04-01-2014 06:56 PM
