Old 08-30-2014, 01:04 PM   #15
Antstronaut
So Hot Right Now
Antstronaut's Avatar
Drives: '14 BRZ
Originally Posted by b1gb2olo View Post
Yes I followed youtube tutorials exactly
So after you have the stock tune loaded in the OFT; you are going to "Write" and it is saying, "Mode file not found cannot create a running file?"
Has the car ever been tuned? I.e. the "stock" tune may not be an actual stock tune?
Installed: | Perrin: Resonated 2.5" Catback, Oil Cooler, Radiator Hoses, Inlet Tube, Filter, and Shorty Antenna | Openflash Tablet | Cusco AOS Catch Can | FBM Radiator | RCE Yellows | Whiteline Camber Bolts & Rear Adjustment Bushings | Michelin Pilot SS | Konig Feathers | Valenti Smoked Tails | ProTeckt Skidplates | Diode Dynamics LED Int/Ext
Antstronaut is offline   Reply With Quote
The Following User Says Thank You to Antstronaut For This Useful Post:
b1gb2olo (08-30-2014)
Old 08-30-2014, 01:07 PM   #16
b1gb2olo
b1gb2olo's Avatar
Drives: 2014 BRZ A/T Limited
i literally just bought the car 2 weeks ago from Subaru and yes
b1gb2olo is offline   Reply With Quote
Old 08-30-2014, 01:09 PM   #17
b1gb2olo
b1gb2olo's Avatar
Do I have to download maps ... I don't understand im nervous now something is wrong
Old 08-30-2014, 01:20 PM   #18
Antstronaut
So Hot Right Now
Drives: '14 BRZ
Was it used?
I only ask since this is very reminiscent of the issue another user was having after returning to "stock" tune with ECUtek: Same Error Message
Follow steve99's advice in the post if this is the case.
Please keep in mind I only offer these as suggestions, use them at your own risk.
If you are truly on a 100% factory stock tune:
If you have the stock tune loaded on the tablet, I would load the OpenFlash Manager software on a PC and plug it in to update the software and then try flashing to the ECU once it's up to date. Alternatively, you can delete the stock tune and try reading it again as long as you haven't attempted a write to the ECU (just to ensure you aren't reading a non-stock tune.)
In regards to downloading maps, the OFT came pre-loaded with maps v1.59 (I believe) if you purchased it within the past ~2 months. So you wouldn't need to download maps. But there are v2.0+ BETA maps available, which I use myself and can be downloaded from the OpenFlash site. You might want to try the newer maps once the OFT and car are married and you are able to write to the ECU.
Most important thing is to NOT interrupt the OFT when in use as this can cause serious issues.
Old 08-30-2014, 01:28 PM   #19
b1gb2olo
b1gb2olo's Avatar
Originally Posted by Antstronaut View Post
Was it used?
It only had 200 mile on the car...
I updated device now im going outside to try again...also I tried to download beta 2 maps but they don't work idk if im doing something wrong for that or how to add to device doesn't seem to work,,, maybe they aren't for public only can get the v1,59
Old 08-30-2014, 01:35 PM   #20
b1gb2olo
b1gb2olo's Avatar
Im seriously about to flip the hell out...spent 600$ on junk that doesn't work....
I turn On power and click tuning it says "preparing tuneing file"
than goes to Mode file not found or whatever.... wtf man
Old 08-30-2014, 01:36 PM   #21
Antstronaut
So Hot Right Now
Drives: '14 BRZ
Are the Write and Read options greyed out when connected to the car?
When uploading maps to the OpenFlash Tablet, you can only upload maps that match your CAL ID which is the last four digits in the CAL section on the Upload screen. See the following tutorial video:
[ame="http://http://www.youtube.com/watch?v=92SV3VpV_1E"]Uploading Maps to OpenFlash Tablet[/ame]
Old 08-30-2014, 01:36 PM   #22
s2d4
s2d4's Avatar
What is your cal ID?
Old 08-30-2014, 01:39 PM   #23
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
Find someone local who has experience, buy them a beer, and I'm sure they'll be willing to show you how to do it.
Also, you can try calling the shop you bought it from or oft and see if they can help you.
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 08-30-2014, 01:42 PM   #24
b1gb2olo
b1gb2olo's Avatar
ZA1JB00D
Old 08-30-2014, 01:42 PM   #25
b1gb2olo
b1gb2olo's Avatar
ZA1JB00D
Old 08-30-2014, 01:43 PM   #26
Antstronaut
So Hot Right Now
Drives: '14 BRZ
I can understand the frustration but let's keep a cool head for now.
Are the Read and Write buttons greyed out when connected to the car?
Also when you say turn On power, you mean just accessory power and not actually starting the car, correct?
At no point during the flashing process do you start the car; only accessory power is turned on.
Have you tried deleting the stock tune and re-marrying it by reading the original tune again?
Are you connecting the OFT and then selecting Write before turning accessory power on? I.e. the write process is being followed according to the instruction video?
What is your CAL ID?
Old 08-30-2014, 01:43 PM   #27
b1gb2olo
b1gb2olo's Avatar
Don't no anyone that messes with cars im new to all this...it was suppose to be easy im not a dumb ass ,, obv it was a waste of my money cause it doesn't work
Old 08-30-2014, 01:44 PM   #28
b1gb2olo
b1gb2olo's Avatar
I never started the car.... I don't no how to unmarry cant find info on that
WTB: Stock MAP Sensor, Stock Frontpipe, Stock Midpipe. Sterz Engine, Exhaust, Bolt-Ons 4 07-02-2014 10:22 PM
TYC Colin Smoked Tail Lights | Stock FRS Tails | Stock FRS Reverse Bar BumpersFRS Exterior Parts (Aero, Lighting, Etc.) 1 01-11-2014 04:42 AM
WTS: Airaid Intake System, Stock Exhaust, Stock Radiator Hoses Sony Engine, Exhaust, Bolt-Ons 0 11-21-2012 12:10 AM
FS: Ecutek Cable, stock axleback exhaust, stock springs Philly Canada Classifieds 4 11-02-2012 09:50 PM
