#15 |
I love peanut butter
Drives: 2013 SWP BRZ Limited
#16 |
Drives: '13 DGM BRZ Limited
I don't trust jack stands, ramps, or jacks alone. I always use a backup. When I installed my header the other day, I used jack stands with ramps under the front wheels just in case. Always better to have a backup just in case.
| The Following User Says Thank You to cnk For This Useful Post: | Propaganda (09-02-2014) |
#17 |
Drives: Scion FRS
I agree with you guys. Thanks for all the tips and let's see how it goes this weekend. I hope it doesn't take too long and I don't run into issues. And yes, WD40 over all nuts before trying to unbolt them.
#18 |
Don't forget before and after sound clips/vids.
| The Following User Says Thank You to B-R-Z For This Useful Post: | Jay2420 (09-02-2014) |
#19 | |
Sent from my SAMSUNG-SM-N900A using Tapatalk |
#20 |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
I just finished installing the Tomei UEL header in my garage (no lift, flat backed it with the BRZ on 4 ramps). The only thing I have to add would be to use a 14mm crows foot to re-install the 2 inner flange stud nuts since I could not get to them properly with any combination of wobble heads/sockets, 1/2 or 3/8 drive.
The crows foot with an extension worked perfectly and allowed me to use the torque wrench. Going to heat cycle it a few times and re-torque before I put the skid plate back on. Last edited by BirdTRD; 09-27-2014 at 07:34 PM. Reason: grammar |
#21 |
Simply Forgotus
Tomei UEL header cold start and revs after warmup
Tomei UEL header with the rest of exhaust stock (except for tips). Only other mods are OFT Stage 2 UEL tune, TRD drop in air filter and Perrin silicone intake tube. Other than cold start, it's hard to tell that I have a header by the volume alone, just has that "boxer rumble" now.
Happy with the results.[ame]http://youtu.be/ELSChRVBm_k[/ame] |
#22 |
Drives: 2014 Ultramarine FR-S
Bumping this.
With regards to the included heat tape, are you guys slapping the whole sheet on the oil pan? How about the rubber components in that area? Within the header's vicinity, I notice there's a couple of rubber hoses and then there's the engine mounts. Would it be a good idea to apply some heat tape around those parts as well? |
#23 | |
Simply Forgotus
I just used it on the oil pan and thermostat housing to keep heat from transferring to the oil and coolant. I don't think you will melt any rubber that is not in direct contact with the header, but certainly something to watch out for. |
| The Following User Says Thank You to BirdTRD For This Useful Post: | NLSP (11-03-2014) |
#24 |
Drives: 2020 DGM BRZ Limited
Sorry to bring this back to life, but for those than installed it did you loosen the spacers at all before bolting it up, or did it come pre-spaced and matched? Going to install this hopefully over the weekend, just wondering what other's have found.
#25 |
Drives: FRS-Raven-MT
Loosen first, test fit, remove, tighten and reinstall.
#26 |
Drives: Scion F-RS 2013 Asphalt MT
how did you guys remove the o2 sensor? did it require a sensor remover or can i just use a wrench?
#27 | |
Drives: 2013 FRS
| The Following 4 Users Say Thank You to Cop For This Useful Post: |
#28 |
Drives: 2013 BRZ Limited
I'll be installing my Tomei UEL headers in a few weeks hopefully. What are people's opinions about the Tomei gaskets? I wasn't sure if I should pick up a set of Grimmspeed gaskets just to be safe or if the Tomei supplied gaskets don't have any issues.
| The Following User Says Thank You to afohlin For This Useful Post: | RobertPaulson (03-09-2015) |
| Evasive Tomei Header Group Buy | Evasive Motorsports | Groupbuys | 424 | 08-05-2018 01:55 PM |
| *Groupbuy: Invidia N1 and Q300 Cat-Back Exhausts (SS tips, T.I. tips) -fteightysix* | 86SPEED | Groupbuys | 74 | 11-09-2016 02:45 PM |
| Quick tips for Remote Start installation | trueno86power | DIY (Do-It-Yourself) Guides | 12 | 12-07-2014 04:47 PM |
| Tomei Exhaust with Tomei Straight Pipe | leech | Engine, Exhaust, Transmission | 10 | 01-07-2014 11:42 AM |
| FS: Tomei UEL Header (WRX) | [deleted] | Miscellaneous | 0 | 03-19-2013 10:58 PM |
