Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
09-02-2014, 11:04 PM | #15 |
Senior Addict
Drives: 86 GT
09-03-2014, 07:34 AM | #16 | |
I wonder if anyone has looked at the coolant flow rates for the different connection options? If the throttle body has a higher flow rate than the t-connection then it would cool better even with smaller diameter hoses. Looking forward to pictures of this. |
09-03-2014, 09:03 AM | #17 | |
Drives: Black 2013 FRS
09-03-2014, 05:01 PM | #18 |
Project BRZ-Boosted Autos
Drives: MY14 BRZ
I'll be uploading a video install guide in the next week or so. In the middle of moving house at the moment.
It taps in to the throttle body loop.
Check out my ProjectBRZ YouTube Channel and Facebook Page for the latest reviews, guides and information. |
The Following User Says Thank You to The Sentinel For This Useful Post: | roddy (09-03-2014) |
09-03-2014, 08:15 PM | #19 |
Drives: MY14 BRZ
That's because the install guide video isn't finished yet....
09-03-2014, 08:53 PM | #20 |
Drives: 86 GT MT
I borrowed a pic from the NSW club
The Following User Says Thank You to keen as For This Useful Post: | hmong337 (09-09-2014) |
09-06-2014, 10:21 PM | #22 |
Drives: MY14 BRZ
Install guide video is uploading now....
09-07-2014, 03:27 AM | #23 |
Drives: MY14 BRZ
Here's the install guide...
[ame="https://www.youtube.com/watch?v=21qWLjhRlfY"]Project BRZ - Video 21 - Oil Cooler Install Guide (Forged Performance Australia) - YouTube[/ame]
The Following 3 Users Say Thank You to The Sentinel For This Useful Post: |
09-08-2014, 07:15 AM | #24 |
Drives: VW MK6 GTI | 13 Mustang GT
Very elegant solution, I like this better than the standard small oil cooler setup, plus a few hundred cheaper as well.
Any temperature numbers from multiple drag runs or track days? Also if you were to do future forced induction would you need to T-Tap those coolant inlets under the throttle body?
SOLD FR-S Build | MK6 GTI Build | I might be getting another FR-S
09-08-2014, 08:47 AM | #25 |
Seems Legit
Drives: Toyota
Real-time Oil temperature Analysis - Pre/Post Coolant Loop Oil Cooler Install
Edit: OEM Oil Cooler
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here] Last edited by ecko04; 09-13-2014 at 12:03 PM. |
09-08-2014, 09:01 PM | #26 |
Drives: 2012 86
I would bypass the throttle body coolant lines as well.
Want data for track/WOT pulls too. |
09-09-2014, 12:06 AM | #27 |
Drives: MY14 BRZ
Next time I'm at the track I'll be recording data. Haven't had an opportunity yet.
I assume you guys watched the post-install temp analysis video under normal driving conditions? As for the turbo oil feed, the alternatives are discussed in the video. there's an additional line at the back of the engine that can be used.
09-09-2014, 11:06 AM | #28 |
Drives: 2014 BRZ
Do this test: drive at 6000RPM for a few minutes and see what the oil temp does.
Tags |
oil, oil cooler, oil temp, temperature |
Similar Threads | ||||
The need for an oil cooler when going FI (Temperature Data Inside) | spdbydesign | Forced Induction | 145 | 11-05-2015 12:02 PM |
Notes on injector / maf scalining using full time open loop | mad_sb | Software Tuning | 40 | 03-03-2014 05:49 PM |
Screencast: experimenting with full-time closed loop fueling | jamesm | Software Tuning | 2 | 12-27-2013 10:19 AM |
Perrin oil cooler real world review. Impressions. | Racecomp Engineering | Engine, Exhaust, Transmission | 40 | 03-18-2013 02:31 PM |
