Old 05-30-2012, 03:03 PM   #15
HotLavaMann
First 86 member
Drives: FRS, Tacoma, Honda CB1100
Originally Posted by smbrm View Post
5th & 6th could be lower on th AT
According to DadHawk, his AT is running at 2350 at 70 MPH whereas my MT is running a bit over 3000 rpm at same speed. That is quite a big difference.
And that is why I'm looking to get the 3.727... it would split the difference between the two.
HotLavaMann is offline   Reply With Quote
Old 05-30-2012, 03:17 PM   #16
Jeff Lange
Jeff Lange's Avatar
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
Originally Posted by HotLavaMan View Post
I spoke with my local Lexus dealer parts department. It's either a 41039-22010 or 41039-35010 and he's not sure which one would be the correct one. Price is either $172 or $197 and will take about a week to get here from central Lexus parts depot. So more research required.
Jeff Lange, do you have any suggestions on finding out which Lexus part number it would be?
No, those are not what you are looking for, that is the differential internal gear set for a non-LSD open differential. Both of those are the wrong part number. Not sure why they would have looked those up for you.
41201-80050 - Ring & Pinion Gear Set, 3.727:1
41201-80052 - Ring & Pinion Gear Set, 3.909:1
41201-19605 - Ring & Pinion Gear Set, 4.100:1
41201-29606 - Ring & Pinion Gear Set, 4.300:1
Pricing is probably going to be quite a bit higher than what you were quoted for those wrong parts.
Jeff
2011 Lexus IS350 F-Sport 6MT with LSD
1986 Toyota Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
The Following 8 Users Say Thank You to Jeff Lange For This Useful Post:
37 (07-22-2013), Dave-ROR (06-01-2012), ESBjiujitsu (05-30-2012), rice_classic (06-22-2012), Ryephile (01-23-2013), Tad_07 (05-30-2012), TRD_07 (01-22-2013), WRXGuy1 (01-23-2013)
Old 05-30-2012, 03:21 PM   #17
HotLavaMann
First 86 member
Thanks much Jeff. Great info. Do you know if those part kits would also include the appropriate "crush sleeve" (according to my mechanic this would also need to be replaced) or is that yet another part to be ordered?
Old 05-30-2012, 03:52 PM   #18
Jeff Lange
Jeff Lange's Avatar
The kit includes the ring gear, pinion gear, pinion seal, pinion stake nut, crush sleeve, ring gear bolts and ring gear bolt locking plates.
The 4.300:1 gear kit listed above is for a different model, so the pinion seal is different for that kit. If you went 4.3, you'll probably also need a new pinion seal.
Jeff
Old 05-30-2012, 03:55 PM   #19
HotLavaMann
First 86 member
Jeff
Thanks for all the great info Jeff. Then looks like the 41201-80050 is the one I'm after and has all required parts.
Old 05-30-2012, 04:09 PM   #20
Jeff Lange
Jeff Lange's Avatar
That's correct.
Jeff
Old 05-30-2012, 04:19 PM   #21
HotLavaMann
First 86 member
Local pricing through my Lexus dealer for 41201-80050 is $1106... ouch.
That doesn't include tax and actually having it installed. Hm. I may reconsider priority of changing that out at that price.
Old 05-30-2012, 04:37 PM   #22
Jeff Lange
Jeff Lange's Avatar
Consider this:
http://www.lexuspartsnow.com/parts/l...201-80050.html
Jeff
Old 05-30-2012, 05:00 PM   #23
ESBjiujitsu
MUST HAVE MORE 86 ! ! !
ESBjiujitsu's Avatar
Drives: Mazdaspeed 6 2.3 AWD Turbo
this thread is full of good info!!!!!
WISH LIST: Whiteout FRS- Bronze 18' race rims, Cooper Zeon RS3-S tires,
Cusco Coilovers, Cusco 6 point cage, CF Lip spoiler, CF F1 Mirrors, HKS GT-86 SC
92 carmy -> 86 corolla-> Honda S2000 -> Audi TT -> Mazdaspeed6 -> NEXT UP TOYOTA FT-86!!!!
ESBjiujitsu is offline   Reply With Quote
The Following User Says Thank You to ESBjiujitsu For This Useful Post:
Old 05-30-2012, 05:24 PM   #24
serialk11r
Drives: '06 AM V8V Coupe
Originally Posted by SpeedR View Post
ya the auto could use lower gearing for better acceleration. I would do this in a second.
Only problem is, you still have the crappy ginormous gap between the ratios, so you will only get marginally better 1st gear acceleration :/
Apparently on some Japanese site the 3.727 gets about 5% better fuel economy on their test cycle, which is probably around what you can expect cruising on the highway. If you drive a lot the savings could add up quickly.
Old 05-30-2012, 05:29 PM   #25
Calum
That Guy
Drives: 2013 asphalt FRS MT
How much gas are people expecting to save by doing this? Why not just disconnect the sound tube after the diaphrame? That would cut down on the noise at least.
Old 05-30-2012, 07:19 PM   #26
HotLavaMann
First 86 member
Well in theory you could on the MT get the same mileage as the AT which would move it from 30 to 34 or about 13% (EPA estimates of course). I don't think it's going to be that high as the total gear ratio will still be shorter than the AT even with the 3.727. But 10% might be within reach.
Old 05-30-2012, 10:49 PM   #27
serialk11r
Naw, 3.727 is 10% lower than 4.1, you won't see 10% fuel economy increase from that. The MT revving 30% higher than the AT in 6th is likely worth 10-15% fuel economy depending on speed. 5% would be pretty good already.
Old 05-30-2012, 10:54 PM   #28
bimmerboy
Drives: 2009 135i
+1 this is a great idea, Cruising around 70mph would bring the rpms down a bit as well as lengthen the ratios a little. Should come in handy once power upgrades are available
bimmerboy is offline   Reply With Quote
GT86 GEAR BOX FIRECAR Engine, Exhaust, Transmission 10 11-24-2013 02:25 PM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 02:21 PM
86,BRZ MT gear ratio Yobiwan Engine, Exhaust, Transmission 1 01-26-2012 03:40 AM
Top gear USA 4agze Off-Topic Lounge [WARNING: NO POLITICS] 25 12-09-2010 12:01 AM
