#15 |
Drives: 02 WRX, 05 LGT, 08 LGT, 08 SpecB
Crank pulley is an ok mod. You lose a few pounds off the end of the crank which equates to a few hundred pounds of "load". But, you lose the samll amount of vibration damopening that the stock pulley provides.
The other pulleys are a waste of money. If you have an MT the crank pulley is less "impressive". If you have a AT you feel it more. If you have an MT, do not mix a LWCP with a LWFW. By removing the mass and inertia from both sides of the crank you will cause all the vibration to be absorbed in the crank bearings. You will eat right through the bearings fast. We have seen bearing failures in as little as 2000 miles in EJ motors when combining a LWCP and a LWFW. |
| The Following 11 Users Say Thank You to Infamous Performance For This Useful Post: | #maverick# (08-04-2014), 2much (01-05-2015), Ammunition (09-12-2014), Black Tire (03-23-2015), Cal3000 (11-11-2014), gonzo (08-05-2014), jcw99 (06-18-2016), mwjcyber (08-20-2014), Namuna (09-11-2014), radroach (08-06-2014), sato (08-11-2014) |
#16 | |
Drives:
What's the acceleration feel like with the new pulley? |
#17 |
Exactly, 1 or the other. Both is what goes boom.
On an AT you can feel the slight improvement in acceleration. Throttle response is snappier and the car gets off the line quicker. If you are uber nice to the throttle while cruising you can usually see a 1-2mpg increase as well. On the MT it is not as noticeable. Same changes, just a smaller dose. |
| The Following 2 Users Say Thank You to Infamous Performance For This Useful Post: | mwjcyber (08-20-2014), WallsAndFoundations (08-01-2014) |
#18 | |
Drives:
In your opinion - as it seems you know your shit - is it worth it? Only 300 bucks or so and it seems to add a decent amount of performance.. and a possible MPG boost you say? |
#19 | |
Drives: 2013 DGM BRZ
Also 1-2mpg seems like quite the overstatement. 4lbs less of rotational mass at the crank typically equates to more like a .1-.2mpg at most in my experience. Do you have any evidence to back this up? |
#20 | |
Señor Member
1974 TA22 Celica
2013 86 GT |
#21 |
Drives:
Feel install would be a lot more expensive for install though.... but in the end it's really what is better for the car. If I go that route what manufacturers should I look at??
#22 |
Señor Member
Brand is down to personal preference. I personally like Toda as they work with the standard clutch and are chromoly steel. I haven't installed mine yet as I still need to track down some ARP bolts.
1974 TA22 Celica
2013 86 GT |
| The Following User Says Thank You to Turdinator For This Useful Post: | s30series (11-10-2014) |
#23 |
Drives:
Thanks Turdinator. I was gonna do it this month but obviously I got some stuff to think about.
| The Following User Says Thank You to WallsAndFoundations For This Useful Post: | Turdinator (08-02-2014) |
#24 |
Seems like the other pulleys would be just as important. Don't they all share the same load? less weight less resistance...... Last edited by Brinks; 08-02-2014 at 08:05 AM. |
#25 | |
Drives: 2015 WRX
Out of all of the pulleys available from raceseng the highest value comes in buying the crank pulley by itself or the complete S2 setup. The higher quality bearings in them are especially important if you are going to supercharge as people have had issues with pulleys melting/bearings giving out. Looking solely at a cost/benefit ratio in this case is pretty misleading as those people are seeing an additional cost of $350 for all the other pulleys and only dropping the weight by ~0.9 lbs as opposed to the 4 lb reduction with only the crank pulley that only costs $145. They are not accounting for the better bearings that are in the idlers and the fact that they are no longer plastic. Also as with everything else in modding cars, there are diminishing returns everywhere, especially on this platform while staying NA. The S2 kit might not meet everyone's needs, but those who want to squeak out every bit of performance they can understand that the lowest hanging fruit is always the first picked and everything else requires more effort/money. I'm not going with a pulley kit just yet, but when I do it will most assuredly be a raceseng S2 set in black. As for Infamous Performance claims of issues with pulleys and lightened flywheels, I have yet to see anyone talk of problems with the FA20 motor. Infact I'm fairly certain there are several people running full raceseng S2 set, lightened flywheels, and carbon driveshafts with no problems. Sure there might have been issues with the EJ's (uggh, hello 02-03 WRX) but this is a completely new motor and I'm failing to see how the two are related. |
#26 | |
Personally lightweight flywheels are about the worst thing you can do to a daily driver. It makes stop and go traffic a nightmare not to mention having every minivan smoke you off the line while your revving the shit out of your car like a jack ass so you don't bog down. Awesome for the track not so awesome on the street. |
#27 |
Drives: '23 BRZ
Going to a 10 lb. aluminum flywheel (13 lb. lighter than stock) on the Z was a GREAT mod. Easier/quicker shifting up and down the gears, and slightly QUICKER off the line, not slower. IMO a lightweight flywheel is a MUCH better and more effective mod than replacing the factory harmonic damper with a slightly lighter-weight solid pulley which will increase dynamic stresses in the crank and give about zero discernible performance benefit.
| The Following 5 Users Say Thank You to ZDan For This Useful Post: | Boxer486 (08-03-2014), litemup (08-03-2014), sato (08-11-2014), stugray (08-02-2014), Turdinator (08-02-2014) |
#28 | |
Theirs no harmonic dampener on a flat 4. "Zero performance benefits" is also a bold statement for 5lb's off the rotational mass that a pulley kit will get you. Sure it doesn't show up on a dyno but the car will accelerate faster using the same amount of power. My 510 only has a 110 HP and it smokes my BRZ off the line. Numbers arnt everything. |
| Light weight flywheel and crank pulley? | wootwoot | Engine, Exhaust, Transmission | 133 | 06-23-2015 01:04 PM |
| Light Weight Pulley's | exam2300 | Engine, Exhaust, Transmission | 18 | 02-08-2014 12:02 AM |
| FS:PERRIN Light weight pulley NEW $85 Shipped | Amalgamo | Engine, Exhaust, Bolt-Ons | 1 | 05-01-2013 11:10 AM |
| FS - Agency Power Light Weight Pulley | Kochinopride | Engine, Exhaust, Bolt-Ons | 3 | 11-12-2012 05:32 PM |
