Old 07-20-2014, 05:39 PM   #15
deucethemoose
Functionally Retarded
deucethemoose's Avatar
Drives: LinkECU V6 MR2 - MKVII Golf R
I think what they mean is behind the wheel where the U-joints (CVs) bolt to the wheel hub.
The u joint is on the driveshaft, not on the axles.
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
I'm not really an asshole, but I play one on the internet.
deucethemoose is offline   Reply With Quote
Old 07-20-2014, 05:52 PM   #16
litemup
Drives: around
Those are constant-velocity u-joints.
litemup is offline   Reply With Quote
Old 07-20-2014, 06:10 PM   #17
stugray
Drives: 2013 GBS BRZ Limited
There are 4 CV joints on these cars. One at each end of each rear drive axles.
In the manual they are referred to as "EDJ"s or EBJ (extensible ball joint )
In the manual I dont see any bolts on the axles to torque though.
Old 07-20-2014, 10:18 PM   #18
deucethemoose
No.
I understand what you're trying to say, but a Universal joint and a Constant Velocity joint are not the same.
CV (axles):
U-joint (driveshaft):
The Following User Says Thank You to deucethemoose For This Useful Post:
Muaddib (07-20-2014)
Old 07-20-2014, 10:36 PM   #19
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
I just ignore it. :p
Muaddib is offline   Reply With Quote
Old 07-20-2014, 10:53 PM   #20
deucethemoose
Just turn the radio up, or run a loud exhaust.
Old 07-20-2014, 11:34 PM   #21
Jolaessss
Jolaessss's Avatar
Drives: SWP FR-S
I also experience this clicking sound. Its usually when I pull out of my driveway. I too am running e85 and other car mods but I have been hearing this click ever since i was bone stock. Maybe its normal?! haha idk
Jolaessss is offline   Reply With Quote
Old 07-20-2014, 11:41 PM   #22
litemup
Drives: around
If the bolts holding the rear axle bearing housing to the rear axle carrier were loose that would be some seriously dangerous mojo.
Besides the axle nut, those are the only other axle-related fasteners I see potentially needing to be torqued.
But there's no actual torque being applied to that joint. Just a cantilevered load.
The Following User Says Thank You to litemup For This Useful Post:
stugray (07-20-2014)
Old 07-20-2014, 11:47 PM   #23
litemup
Drives: around
No.
Well I feel a little dirty. I was just trolling to back up Stu. "Bazinga," I guess.
Old 07-20-2014, 11:49 PM   #24
edeekeos
edeekeos's Avatar
Drives: 2014 Pearl BRZ Limited
I took the wheel off again, and re-torqued the 4 'axle bearing housing' bolts, as I only did the axle nut the first time. While down there I re-torqued ALL the suspension bolts as well. Still no change. At this point in time, I am ~%95 sure its the cage in the CV joint. Is it feasible/safe to pull the boot, and check this without pulling the axle?
Probably suffered the same fate as this one..
| OFT & Stg2 e85 Tune | Perrin Intake Tube & High Flow Filter | Perrin Lightweight Crank Pully |
| Tomei UEL Header/Overpipe | HFC/Perrin Catback | Tom's Tails | Enkei RPF1's | RS*R SuperDowns |
edeekeos is offline   Reply With Quote
Old 07-21-2014, 12:00 AM   #25
deucethemoose
Old 07-21-2014, 12:33 AM   #26
litemup
Drives: around
Old 07-21-2014, 12:58 AM   #27
deucethemoose
The Following 2 Users Say Thank You to deucethemoose For This Useful Post:
Frers (07-21-2014), litemup (07-21-2014)
Old 07-21-2014, 09:17 AM   #28
FRSpappa
FRSpappa's Avatar
Drives: 2014 FR-S Whiteout
Rear brake adjusters for parking brake maybe??? I had a Chevy Impala that did that...
FRSpappa is offline   Reply With Quote
Strange Noise from rear of car while OFF mike2100 Issues | Warranty | Recalls / TSB 23 12-17-2014 08:14 PM
Rear axle click when entering the car? kurbkilla Issues | Warranty | Recalls / TSB 10 07-01-2014 08:38 PM
Rear driver side clank and click spyingwind Issues | Warranty | Recalls / TSB 11 04-04-2014 11:26 PM
click, clank click sounds when cooling down and more? leaking oil? Boofneenee Issues | Warranty | Recalls / TSB 19 10-02-2013 11:27 AM
Click sound from left rear Tt3Sheppard Issues | Warranty | Recalls / TSB 1 09-25-2013 05:58 PM
