Old 08-05-2014, 03:55 PM   #15
FR-S Matt
Originally Posted by skyloran View Post
how many liter of Gear 300 u use for tranny and diff?
Between both, almost a full 4 quarts. I had some left in the last one. The tranny takes a lot more than the diff.
There's a vendor that sells a fluid swap package on here that is very convenient and a good deal. Highly recommend it.
Old 08-05-2014, 04:01 PM   #16
Argento86
Drives: Argento
Thanks guys for the responses. I already did the diff fluid change and that drain bolt was nasty. I ordered the tranny fluid and will do that this weekend.
Argento86 is offline   Reply With Quote
Old 08-08-2014, 03:53 PM   #17
skyloran
Honeydew old ID
skyloran's Avatar
Drives: GT86
For street cars, every 30k.
For lightly tracked cars, we recommend once a year, or every 15k.
If you're tracking heavily, then we recommend you get a used oil analysis done to determine your interval, but the common "safe" margin that is often used is every oil change. Remember, the differential is thousands, the fluid is less than 1% of the price of a differential.
question.. is there anything I need to be aware while I am changing the fluid??? also am I gonna use the stock washer or new washer? the place I order only gave me 2 new crush washer for diff, but not tranny.
Used to owned M3 and Lotus, but love my GT86 the most.
skyloran is offline   Reply With Quote
Old 08-08-2014, 04:04 PM   #18
gonzo
Drives: frs
same recommendation for changing the trans fluid?
gonzo is offline   Reply With Quote
Old 08-08-2014, 04:30 PM   #19
Yes!
Old 08-08-2014, 04:30 PM   #20
The trans doesn't have a washer
Old 08-08-2014, 06:28 PM   #21
FR-S Matt
I thought the drain plug has one? At least from what I saw it does. I got two washers with my Motul Gear 300 fluid swap pack. I know I used both. Well, fluid isn't leaking anywhere so I think I'm good, lol.
Old 08-08-2014, 06:34 PM   #22
kster1
kster1's Avatar
When I replaced my transmission fluid on the BRZ, there was a crush washer and it's pretty thick (not sure how much it actually "crushes"). But I did change both the drain and fill washers, the Subaru part number is 17008AA050 (for both).
kster1 is offline   Reply With Quote
The Following User Says Thank You to kster1 For This Useful Post:
gonzo (08-15-2014)
Old 08-08-2014, 07:52 PM   #23
Hmmm maybe I'm brain farting. I remember something not having a washer on this car...
motul 300 vs motul 300ls about to buy some need help. NickFRS Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 03-24-2016 11:51 PM
Aftermarket differential (LSD) options for automatic transmission (AT)? dp1 Tracking / Autocross / HPDE / Drifting 44 07-21-2014 05:30 AM
Transmission fluid blending Redline MTL and Motul Gear 300 okay? imom Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 11-01-2013 09:03 PM
Differential and Transmission Fluid Swap with Red Line Oil - 2013 Subaru BRZ JPxM0Dz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 05-05-2013 06:12 PM
Transmission and Differential Fluid Change LINK Amadeus DIY (Do-It-Yourself) Guides 1 12-23-2012 07:01 PM
