Old 02-06-2015, 12:19 PM   #15
PERRIN_Chris
Drives: 2014 Subaru BRZ
Send a message via AIM to PERRIN_Chris
That's correct, they are -10 fittings on the thermostat. Also keep in mind that if there is some oil on the threads when the fittings are tightened down, then some oil will weep out the hole on the fitting shortly after install. But if oil is still weeping out after wiping it off, then that could mean that there's a problem with the fitting either not being tight enough, or damage to the fitting.
PERRIN_Chris is offline   Reply With Quote
Old 02-06-2015, 12:34 PM   #16
kodyo
Drives: Scion FR-S
Thanks! It's pretty steadily seeping oil. Pretty sure cause is damage to the female cone face due to over torquing.
kodyo is offline   Reply With Quote
Old 02-10-2015, 03:50 PM   #17
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
Yes the metal from the threads on the core need to be picked out of the threads on the line. I am certain I'll need a M22x1.50 tap for the core. If i can't get a bottoming tap I'll just cut the one I'll get. A snap on rep is gonna try to help. Plus my intercooler sits too far forward and I'm having to use the same hole for both top and bottom screws.
texasbound972 is offline   Reply With Quote
Old 02-10-2015, 06:45 PM   #18
FT86POWER
Drives: FRS 6MT
Great write up
FT86POWER is offline   Reply With Quote
Old 02-12-2015, 10:30 PM   #19
kodyo
Drives: Scion FR-S
Is the spacer supposed to have 1 O-Ring or two? I see two grooves but only 1 O-Ring (I probably lost it if there were two).
Old 02-13-2015, 11:43 AM   #20
PERRIN_Chris
When the kit first came out, it had one thick O ring, then a few months later we started using 2 smaller O rings instead. If you need a new O ring, send me a PM for more info, thanks!
Old 02-16-2015, 10:18 PM   #21
kodyo
Drives: Scion FR-S
Huge shout out to @PERRIN_Chris for helping me replace the parts I screwed up. Very good customer service! So if anybody has issues, I highly recommend getting a hold of them. They are very reasonable.
Old 02-19-2015, 12:08 AM   #22
texasbound972
USMC
Yes thank you Chris!!
Old 02-19-2015, 12:53 PM   #23
Brzerker
Brzerker's Avatar
Drives: World Rally Blue BRZ
Hi guys!
I just ordered my perrin oil cooler and would like to ask, how do you hook up an analog oil temp sensor? Would like to install an analog defi gauge to monitor temperature and pressure after installing the oil cooler.
Brzerker is offline   Reply With Quote
Old 02-19-2015, 01:52 PM   #24
PERRIN_Chris
Thanks for your order! If you'd like to add temp and pressure sensors, I'd use a brass Tee off the stock sensor ports. They are located on the front of the engine under the oil filter. That would be the easiest solution, thanks!
Old 02-19-2015, 02:50 PM   #25
texasbound972
USMC
Using the Mishimoto sandwich plate that has the 2 spots for the sensors.
Old 02-20-2015, 08:38 AM   #26
Brzerker
Brzerker's Avatar
Thanks! Does anyone have a picture of the location of the stock sensor ports?
Won't that replace the Perrin sandwich plate?
Old 02-22-2015, 10:41 PM   #27
texasbound972
USMC
Yes it will. But upon installation, the freaking unions won't fit on the Mishimoto sandwich plate. Terrorism I tell you! LMAO!
Old 02-25-2015, 10:41 AM   #28
Brzerker
Brzerker's Avatar
@PERRIN_Chris
Sorry if this is a stupid question, but can you elaborate more on this method? Thanks
Perrin Reverse Lockout Ring Installation and Review! Sony Engine, Exhaust, Transmission 21 07-17-2018 06:19 PM
Perrin Catback Exhaust Installation and Review! Sony Engine, Exhaust, Transmission 316 01-24-2016 01:01 PM
Perrin oil cooler real world review. Impressions. Racecomp Engineering Engine, Exhaust, Transmission 40 03-18-2013 02:31 PM
Perrin Oil cooler install review LeeMaster Engine, Exhaust, Transmission 3 03-14-2013 10:41 PM
Quick review to my perrin CAI, installation, and Results 3askoul Engine, Exhaust, Transmission 0 03-12-2013 03:33 PM
