Old 07-17-2014, 09:25 AM   #15
SomeoneWhoIsntMe
Drives: 2013 Subaru BRZ
Huh. Guess I'll have an easier time getting rid of my old S14 Silvia K's calipers (same as z32) when I go evo X brembos up front.
1jz salvaged brz build thread brought to you by visconti tuning --> Pipe dreams and poor life choices
SomeoneWhoIsntMe is offline   Reply With Quote
Old 07-17-2014, 10:33 AM   #16
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by mike the snake View Post
Agreed!
I found some 300zx's at a junkyard. Heading there tomorrow.
Learn about the various 300z calipers first. You will need the ones for the 30mm rotors I'd bet based on the 30mm LGT rotor width, but those are common enough, just make sure. Based on the pic, Eikond has the aluminum ones, which are lighter and harder to find than the iron ones.
What's the swept area like for the 300z spec pads on those rotors? They were for 280mm rotors IIRC originally so I'm curious how well the pad matches the larger disc radius.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 07-17-2014, 10:49 AM   #17
eikond
Wish Nissan made one
eikond's Avatar
Drives: '13 WRB BRZ Premium
Great questions jritt and dave.
I'm not an engineer by trade so I won't be able to provide a professional response. However I have considered each of these things. I'm traveling at the moment but i will share more tonight when i get the chance
eikond is offline   Reply With Quote
Old 07-17-2014, 11:32 AM   #18
mike the snake
Thanks, I actually did check. I want the 90-92.5 30mm calipers, preferrably the aluminum ones.
Old 07-17-2014, 11:35 AM   #19
SomeoneWhoIsntMe
edit: removed incorrect information
Old 07-17-2014, 12:03 PM   #20
eikond
eikond's Avatar
You want 91 to 92.5. 90 had 26mm.
I have also heard that iron calipers were better for race purposes. They are 11 lbs each vs. 6. Still lighter than the 14 lbs stock.
Old 07-17-2014, 12:17 PM   #21
SomeoneWhoIsntMe
Wait, you live in LO? Right on.
Old 07-17-2014, 12:21 PM   #22
eikond
eikond's Avatar
Yessir. Come visit soon and test drive and compare as an independent opinion.
Old 07-17-2014, 12:35 PM   #23
mike the snake
Correct, but the 90 twin turbo had the aluminum 30mm calipers.
Old 07-17-2014, 01:19 PM   #24
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by SomeoneWhoIsntMe View Post
z32tt's had the 30mm wide calipers, they're actually the same as the n/a calipers except they have a spacer in the middle to make them wider. IIRC, the iron calipers are preferable because they flex less or for similar reasoning. they are heavy for what they are, though.
The NA and TT are the same caliper except for 90. 90 the TT was the 30mm aluminum, NA was 26mm aluminum. 92.5-96 are all 30mm iron.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 07-17-2014, 01:19 PM   #25
azian_advanced
*****istrator
azian_advanced's Avatar
Drives: 2013 Scion FR-S 10-Series M/T
A good find for those looking for something between stock and STI brembos...
Did you do the rears as well? Or just the fronts?
SC10N FR-S #435 of 2500
azian_advanced is offline   Reply With Quote
Old 07-17-2014, 01:24 PM   #26
Cockatoo
TALLY FT86
Cockatoo's Avatar
Drives: 2014 FR-S Monogram -- SBD Turbo --
Awesome! Maybe I can still kinda be in the Nissan family after all...
Cockatoo is offline   Reply With Quote
Old 07-17-2014, 01:31 PM   #27
eikond
eikond's Avatar
Thank you.. That is EXACTLY what I was after.. Something close to Brembo performance but for much less money. This setup would not be optimal for a full purpose track car or similar.. Those people are going to buy a professional BBK. But for weekend warriors on a budget, I think this is a nice affordable option.
I think there is some additional research to be done to validate the performance.. ie.. brake bias changes due to piston size, etc.. I know the Subaru 4-pots have been done successfully on a BRZ/FRS already, and these should be about the same impact.
I will do the rears. I have the calipers already. I just need a set of brackets from KNS Brakes and some lines and pads. Just have to save some pennies to order the final parts. Hopefully in the next month or so..
Old 07-17-2014, 01:39 PM   #28
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
The WRX 4 pots suck. Not saying these are comparable but the WRX setup shifts bias towards the back.
You may have meant the STI full setup though
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Brake Pads, Rotors and All Your Brake/Suspension Needs! Great Prices!! Check it out!! Mike@CZP Brakes, Suspension, Chassis 348 06-01-2018 12:29 PM
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! eauto Brakes, Suspension, Chassis 255 10-15-2014 01:45 PM
FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot CamryDS Interior Parts (Incl. Lighting) 0 06-24-2013 11:26 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 10:28 AM
