Old 07-17-2014, 10:48 AM   #15
mike the snake
I originally had the Robispec with no shroud. Car still ran hot on the dyno, but that may have been due to not bleeding the system properly.
Switched to the Full Blown radiator with Spal fans and shroud, and temps have not moved more than one or 2 degrees regardless of load.
I think the biggest factor is the shroud and fans. It directs the air from the fans and utilizes the entire radiator area.
Old 07-17-2014, 11:13 AM   #16
Luis_GT
Unless you're going FI there's no point. My car has stock rad, and I track it and haven't had any heating issues... and I live in the tropics where its summer year round...
Old 07-17-2014, 11:29 AM   #17
kombatlion
Life to short to be slow!
kombatlion's Avatar
Drives: Toyota GT86
So how do you know you dont have any heat issues?
are you running oil temp or water temp gauge?
are you using Torque during those track laps?
kombatlion is offline   Reply With Quote
Old 07-17-2014, 11:35 AM   #18
Luis_GT
torque, I have a Bluetooth OBD2 plug. On a N/A car you may only need an oil cooler upgrade if you drive the car hard on the track, not a radiator upgrade, which is what OP is talking about. And OP wants to upgrade the cooling system because its gonna be summer, not cause he races, which an even bigger waste of money.
The Following User Says Thank You to Luis_GT For This Useful Post:
kombatlion (07-17-2014)
Old 07-17-2014, 11:45 AM   #19
MAPerformance
Drives: Asphalt FRS
I run the Mishimoto and it's been great. Also, their lifetime warranty is a win in my book. Quality seems to be there, and fitment was great.
MAPerformance is offline   Reply With Quote
Old 07-17-2014, 11:47 AM   #20
FR-S Matt
Originally Posted by MAPerformance View Post
I run the Mishimoto and it's been great. Also, their lifetime warranty is a win in my book. Quality seems to be there, and fitment was great. FYI, the FullBlown is a Mishimoto unit.
Question since you run this and I'm about to install it. Do these use the OEM spring clips on the hoses currently since the hose kit didn't come with any or is there a better solution to use for clamping?
Old 07-17-2014, 12:01 PM   #21
FullBlown
FullBlown's Avatar
Drives: Scion FRS
I run the Mishimoto and it's been great. Also, their lifetime warranty is a win in my book. Quality seems to be there, and fitment was great. FYI, the FullBlown is a Mishimoto unit, so you will get the same quality.
No its not a mishimoto unit, we designed it ourselves. Our radiator was released before theirs and the mounting locations are different.
FullBlown is offline   Reply With Quote
The Following 2 Users Say Thank You to FullBlown For This Useful Post:
Dipstik-sportech (07-17-2014), Sportsguy83 (07-17-2014)
Old 07-17-2014, 12:25 PM   #22
MAPerformance
Drives: Asphalt FRS
I stand corrected. Post has been edited. I guess I am just jealous cause we don't have a 10 second FRS
Old 07-17-2014, 12:27 PM   #23
Dipstik-sportech
Dipstik-sportech's Avatar
Or an 11second one Lol jk
The Following User Says Thank You to Dipstik-sportech For This Useful Post:
MAPerformance (07-17-2014)
Old 07-17-2014, 01:29 PM   #24
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Originally Posted by zooki View Post
If you've never increased the power of your vehicle and drive it hard then you probably never would have the need for it. The cooling system is designed for stock parameters. Once you've exceeded those is when this comes into play.
Wouldnt a oil cooler be more than enough?
Carlitoz3 is offline   Reply With Quote
Old 07-17-2014, 03:16 PM   #25
kombatlion
kombatlion's Avatar
Drives: Toyota GT86
Do your radiator is bolt on, no modifications?
Old 07-17-2014, 03:19 PM   #26
FullBlown
FullBlown's Avatar
Drives: Scion FRS
No mods, direct bolt on.
The Following User Says Thank You to FullBlown For This Useful Post:
Old 07-17-2014, 03:42 PM   #27
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
How well does the FBM rad work with other kits? In terms of fitment
Old 07-17-2014, 03:52 PM   #28
peri.Laynz
Drives: 2014 Whiteout M/T
I have the FBM radiator on my current twin and had a Koyorad on my last twin. I can say I was instantly blown away by the craftsmanship of the FBM radiator. It's big and beautiful. And while you're changing put the radiator I'd recommend swapping out the hoses for some better quality ones. But yeah, FBM all the way for me. 3 times the size of stock (17mm vs. 42mm) and a dual core system is sweeeeeet.
peri.Laynz is offline   Reply With Quote
The Following User Says Thank You to peri.Laynz For This Useful Post:
FullBlown (07-17-2014)
FBM Dual Pass Radiators FullBlown Forced Induction 23 05-31-2017 01:15 AM
Mishimoto BRZ/FRS Radiators now at MAPerformance! MAPerformance Engine, Exhaust, Bolt-Ons 36 04-27-2016 06:45 PM
FBM Performance Aluminum Radiators FullBlown Engine, Exhaust, Bolt-Ons 2 12-19-2013 04:47 PM
PTUNING FR-S/BRZ Koyo Radiators Now Available! Ken@PTuning Engine, Exhaust, Bolt-Ons 0 07-30-2013 10:58 AM
FBM Performance Aluminum Radiators FullBlown Forced Induction 121 06-17-2013 08:23 PM
