Old 07-07-2014, 06:08 PM   #15
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Forget what people have to say about it being non-turbo. I drove my current white one for 5 years before swapping in a gen3 3sgte. Sometimes, being non-turbo can be a good thing. Here is what I miss: 87 octane, stupidly easy to maintain (just change conventional oil/filter), short gearing so it scoots along briskly, 31mpg, and you can flog the car reaching threshold limits easily. In fact, my FRS reminds me exactly how my sw20 used to be when it was non-turbo with handling mods. Underpowered and fun to drive without getting too hairy.
hmong337 is offline   Reply With Quote
Old 07-08-2014, 11:17 AM   #16
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Originally Posted by LSxJunkie View Post
I do quite love me an SW20, but I'd spend the value of my Mustang building one if I ever did get around to buying one.
Here's some MisterTwo porn.
That red one reminds me or maybe is a local car to me...
BRZZZZZZZZZZ is offline   Reply With Quote
Old 07-08-2014, 12:07 PM   #17
MokSpeed
Granny Shifter
MokSpeed's Avatar
Drives: 2014 FR-S
Originally Posted by hmong337 View Post
Turbo's are nice but these days, it's near impossible to find one that hasn't been beat to an inch of its life or pony up for a mint one. Having owned two sw20's in the past ten years (a 93 turbo and my current car which started off as a 91 na), I strongly believe you're best to go with the cleanest shell. Clean shells are usually non-turbos since they see half the stress as their turbo counterparts due to being powered by a Camry 5sfe. Drop a gen3 3sgte into the car and you've got yourself a pretty capable car. Having owned all three iterations of mr2 engines (usdm gen2 3sgte, gen3 3sgte, and 5sfe) there's no questioning the gen3 is the winner. Again, I'd much rather start with a clean non-turbo than a potentially problematic and stress out turbo chassis.
$0.02 from an mr2 owner.
Do exactly what he says. Then sell it to me.
MokSpeed is offline   Reply With Quote
The Following 2 Users Say Thank You to MokSpeed For This Useful Post:
hmong337 (07-08-2014), itsibarra (07-09-2014)
Old 07-08-2014, 07:17 PM   #18
zygrene
zygrene's Avatar
Drives: 1991 Formula Red NSX
Get that car inspected for sure. If it's in good mechanical condition and actually has 53k original miles, it is TOTALLY worth $3500. My good friend just sold his '91 MR2 T-Top N/A for a little over $5000, with 80k original miles and completely stock with a brand new clutch and timing belt.
I drove that car a good bit (borrowed it on a few occasions when my S2000 was out of commission) and really enjoyed the relatively light weight and RWD dynamics. For a car with 130hp and 2800lb, the power-to-weight ratio is terrible, but it will teach you to drive a RWD manual car well without traction control or stability control. Later on you can always turbo the 5SFE or swap to a 3S-GTE (3rd Gen outputs around 250hp) for a reasonable cost. Once you go that route, you'll likely want to upgrade your brakes/wheels/tires to keep up with the power.
I think my biggest complaints with the car were the transmission and steering. The transmission was very easy to shift, but almost too easy. The shifter itself had almost zero resistance when rowing through the gears and didn't feel mechanical enough. But that might be because I'm used to the S2000 transmission, which is probably the best in the world. The steering also felt a bit too light and vague/rubbery, a bit like an old Camry.
zygrene is offline   Reply With Quote
Old 07-08-2014, 09:50 PM   #19
speargunsandracecars
Drives: 2014 BRZ
I'd take it and swap a BEAMS 3SGE in there. NA all the way.
speargunsandracecars is offline   Reply With Quote
The Following User Says Thank You to speargunsandracecars For This Useful Post:
Old 07-08-2014, 10:02 PM   #20
hmong337
Emperor JDM
hmong337's Avatar
Although a noble idea with the BEAMS engine, the V6 2grfe is the route I'd go if I was to keep it NA
Old 07-08-2014, 10:17 PM   #21
Drives: 2014 BRZ
That would be the case if I just wanted MOAR POWWWAAAHHH! But the BEAMS is a spritely little motor that revs to high heaven and Yamaha helped design it. The Camry engine is a little too lethargic for my tastes, despite the power it produces.
Old 07-09-2014, 02:49 AM   #22
serialk11r
Drives: '06 AM V8V Coupe
3S-GEs are hard to get in the US aren't they? If I'm wrong about that, then it's a solid option.
My engine of choice in an MKII would be a K20. I guess that would be my engine of choice in any midengined car really Makes you wonder why Honda didn't make more cars with K20s, or come up with a new K20 with the recent refresh. They could probably make enough money to offset the R&D just by selling it to 3rd parties.
Old 07-09-2014, 12:17 PM   #23
itsibarra
itsibarra's Avatar
Drives: Supercharged Car
Test drove it yesterday, and the car did have some pep to it! As well as feeling very similar to the twins. Checked all the areas that members chimed in on, and the car looks to be in good shape. Owner says it was garage kept all its life and this past year he had a quick tune-up, a/c, belt, and tires done with paperwork accounted for. He said he like my offer of $3k, but I don't think I can pull the $ together by Thurs. which is when he's taking the car with him to see more potential buyers.. If someone close to the Southbay is looking for one, I thought I'd pass it along!!
Sent from Tapatalk
itsibarra is offline   Reply With Quote
Old 07-09-2014, 01:57 PM   #24
hmong337
Emperor JDM
hmong337's Avatar
If only I was local. I'd buy that car without a doubt! I would gladly pay $3500 for it too. Around my neck of the woods, a clean na easily fetches $5000. Turbo, $10k. Even if i had the means to buy it, i don't have any parking for it
Good luck.
Old 08-14-2014, 03:22 PM   #25
dinternetman
Drives: 330ci
OP is the car still for sale?
I have been looking for a clean base mr2 for years...
would it be ok to pm me the seller info and I can get into contact with him?? please please
dinternetman is offline   Reply With Quote
Old 08-14-2014, 03:43 PM   #26
MokSpeed
Granny Shifter
MokSpeed's Avatar
Drives: 2014 FR-S
There are so many import engine shops nowadays it's not too hard to get. About as difficult as a 2JZ-GTE. It's just getting one with lower mileage that is difficult at this point.
Opinion? cncnjn Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 08-11-2013 12:00 AM
DGM Opinion soontobrz BRZ First-Gen (2012+) — General Topics 4 02-03-2013 09:31 AM
Your opinion? xAgentzero13 BRZ Photos, Videos, Wallpapers, Gallery Forum 73 09-11-2012 07:20 AM
