Old 06-16-2014, 11:15 PM   #15
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
Originally Posted by Chaz@ORT View Post
Ken Block has a Bagged Focus ST that he daily drives ;]
Okay.
I wasn't very specific. I'm interested in finding out if you know of any teams or owners that run road races that are using your product or one like it in Tudor/Continental, World-Challenge, Canadian Touring Car, or any of the series across the pond such as BTCC and the like.
dradernh is offline   Reply With Quote
Old 06-17-2014, 09:30 AM   #16
Racecomp Engineering
Be nice guys!
Originally Posted by Andrew@ORT View Post
We're working on some statistical data to show the correlation in height / psi to the spring rate.
This would be pretty cool to see.
- Andy
Old 06-17-2014, 09:33 AM   #17
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
There are two questions to dig through here
Can a car on bags perform at the track? I suppose it can, if the effective spring rate of the bags distributes the weight transfer correctly and matches the harshness of the road, and the dampers on it are tuned to control the oscillations correctly.
Can the car pictured in the initial post perform at the track? Highly doubtful, unless it is the smoothest of tracks (not many of those though..) because it would have to be setup like a DTM car, where mechanical grip is sacrificed for aero grip…. And you’d never want to be driving such a car on the street.
Not to mention the fact that when you’re an inch off the ground not only have you screwed your roll centers (again, forcing you to build an aero car), but you’ve also exceeded the designed articulation in the oem suspension pickup points and the drive axles… a remedy to which would be a custom front and rear crossmember.
Bags are certainly an option, but they’re not some magical solution, at least not if you’re serious about building a dual duty vehicle.
When a car encounters a bump, the wheels need to move up and the chassis needs to stay where it is, if there is no room for the wheel to move up, then the chassis has to move up, and while this whole movement can be dulled down somewhat with the help of super-properly-setup dampers, your ass is still going to bounce at least once.. bags or no bags.
Old 06-17-2014, 01:34 PM   #18
We're working on some statistical data to show the correlation in height / psi to the spring rate. We're just scratching the surface here as this "scene" is very new to air suspension. We don't want to throw too much knowledge down in the first post.
I'd love to see the data, and how the airbag is damped.
Old 06-17-2014, 05:57 PM   #19
ntaphse
Drives: beater
You do realize that Sti is laid out in the pic right? You wouldn't drive the car at 0 psi.
ntaphse is offline   Reply With Quote
Old 06-18-2014, 12:19 AM   #20
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
one would hope....
Old 06-18-2014, 11:11 AM   #21
Andrew@ORT
Drives: BT 6.4 (tow pig) / e46 M3
A bit off topic, but our RS7 has the standard air suspension, that shit is nuts. I've driven cars with air suspension both OEM and aftermarket and I've never been impressed until we drove that car. Defiently made me a believer that you can have a good handling car with air suspension.
Besides that, the technicality of air suspension is a subject i have yet to wander into.
The RS7 is one of many cars this day and age that is equipped with factory air suspension. And, honestly, I am very excited and thankful that you posted your feedback. While we've been around slinging air suspension for quite some time, it's not until probably the last 2-3 years that we've really seen a progression in technology across the market as whole.
Originally Posted by Racecomp Engineering View Post
Be nice guys!
- Andy
Thanks Andy!
Actually working on some graphs / charts to show spring rates at three different heights / pressures to give everyone an idea of what's possible with an air suspension setup.
Andrew@ORT is offline   Reply With Quote
Old 06-18-2014, 11:30 AM   #22
Andrew@ORT
This is a really good read (FT86 related) : http://www.revvolution.com/blog/2014...ital-combo-kit
Old 06-18-2014, 11:43 AM   #23
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
Is there a follow-up to that article? It was an interesting read, but now I must know their reflections after the install!
Jyn is offline   Reply With Quote
Old 06-18-2014, 01:28 PM   #24
Andrew@ORT
Spoke to some mutual friends and they've got it on and installed, they're just awaiting the completion of their motor. Hopefully soon!
Old 06-21-2014, 11:10 PM   #25
Chaz@ORT
Chaz@ORT's Avatar
Drives: VW GTI
So while we're waiting for Air Lift to deliver us the technical data we've asked for you to answer your questions, I just want to chime in and say something.
Honestly, we're not here to try and convince you to switch your track car to air suspension. And we're not here to debate what would work best on the track, or on your canyon road, or whatever kind of driving you're into.
We're here to answer questions, deliver information, and most importantly help FRS/BRZ owners as a whole just understand how it is that air suspension works and performs, because it is relatively new to this platform.
This thread is designed to answer those questions you're afraid to ask, or feel "too dumb" to ask. This thread is designed to help explain installation procedures. This thread is designed to help you decide what kind of tank/compressor/management system is right for you, and how you could go about installing.
There's going to be the hardcore coilover/static junkies who will detest air suspension till their death, and honestly this thread isn't here to try and change your mind. The guys at ORT all have owned cars on air suspension, coilovers, cup kits, you name it. So we're not here to get into a battle about what's better.
With that said, lets open up the floor more for discussion. and Very soon we'll have the technical data that was requested previously in the thread.
Cheers
Chaz@ORT is offline   Reply With Quote
Old 06-21-2014, 11:20 PM   #26
jebuwh
Village Idiot
jebuwh's Avatar
Drives: '13 FR-S Ultramarine Manual
Has price already been covered? What does a full kit, with everything needed for install run for the twins?
jebuwh is offline   Reply With Quote
Old 06-21-2014, 11:22 PM   #27
Andrew@ORT
Price has not been covered, but this is a discussion thread in the technical section. Due to this, we cannot post a price. We'd be more than happy to discuss price via pm.
Cheers,
Andrew
sent via telepathy
Old 06-21-2014, 11:23 PM   #28
jebuwh
Village Idiot
jebuwh's Avatar
Cheers,
Andrew
sent via telepathy
That would be cool. I mean I'm just looking for a rough range of what they run. Just to compare to standard coilovers. That's technically technical right?
Track Brake Pad Discussion Thread CSG David Tracking / Autocross / HPDE / Drifting 422 04-03-2025 10:13 PM
Anime Discussion Thread ERA Off-Topic Lounge [WARNING: NO POLITICS] 2698 02-14-2024 11:55 PM
Brake Pad Discussion Thread CSG David Suspension | Chassis | Brakes -- Sponsored by 949 Racing 36 06-26-2014 05:59 PM
Another Coilover discussion thread... nobody__ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 02-04-2014 10:49 AM
Forza 3 vs. GT5 Discussion Thread Snaps Off-Topic Lounge [WARNING: NO POLITICS] 386 03-06-2011 12:10 AM
