Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
06-06-2014, 12:49 PM | #15 |
The most common area for any engine to leak oil is the area where TCC, Head, and block meet. With the differences in the metal expansion/retraction due to heat the sealant used will eventually crack. The crack will allow small amounts of oil to leak. There really isn't a good fix for it once it starts other than removing the TCC and cleaning the intersection well. Reapply sealant and allow it to cure fully.
06-06-2014, 01:28 PM | #16 | |
Reverse Burnouts
Drives: 2013 Argento FRS
2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
06-06-2014, 01:34 PM | #17 |
Drives: Scion FR-S
Add me to the list as well mine is on the passenger side. Took it to a toyota dealer they said they are not sure where it's coming from and told me I have to take it to a scion dealership. I am waiting to get an appointment to take it in.
Sent from my Q10 |
06-06-2014, 01:43 PM | #18 | |
Drives: white premium brz M/T
06-06-2014, 02:18 PM | #19 |
Reverse Burnouts
mine is the same, probably worse lol
06-06-2014, 03:42 PM | #20 |
Garbage.
06-06-2014, 04:12 PM | #21 | |
No. That is roughness from the casting process when they make the block, it's not worth the OEM's time to prep every block so it looks pretty. Some examples: http://www.mitsu-media.com/forums/sh...ad.php?t=14522 http://twinturbo.net/nissan/300zx/fo...et-Part-2.html |
06-06-2014, 05:35 PM | #22 | |
06-06-2014, 09:07 PM | #23 |
Drives: Scion FR-S
Let me know if anyone makes it to the dealership before me what they find out. I'm not looking to have an engine fire from an oil leak. I have seen to many people say it's just a little oil and then a few weeks later post a picture of a ball of flames because a small leak turned into a big leak.
Sent from my Q10 |
06-09-2014, 09:32 AM | #24 |
Drives: Whiteout FR-S
I'm curious about this as well I just hit 41k and I've been having a burning smell come through the vents a lot lately. Will be doing a thorough inspection of the engine bay.
2013 Ford Focus St
2013 Scion FR-S 2007 Honda Civic Si 2003 Acura RSX Type-S 1998 Ford Escort ZX2 |
06-09-2014, 10:48 AM | #25 |
Drives: t
this is where the leak is..
The Following User Says Thank You to choi0706 For This Useful Post: | Tt3Sheppard (06-09-2014) |
06-09-2014, 10:57 AM | #26 |
Drives: t
you can run your hand underneath the chain cover to feel for leaks..
06-09-2014, 12:32 PM | #27 |
Drives: 2013 Scion FR-S, 1993 Lexus SC300
I noticed a leak in the same location on my car while inspecting it recently. Car has 22k miles on it ( 8k boosted ). Bought 5/31/2012. Can't do much about it for now. Will keep an eye on it and my oil levels for the near future.
06-09-2014, 08:51 PM | #28 |
Reverse Burnouts
my leak isnt from here though :/ its form the front, top side not bottom
Similar Threads | ||||
Water Leak inside passenger side floorboard | AtlasMick | Issues | Warranty | Recalls / TSB | 30 | 03-28-2019 04:43 PM |
New Body Parts from WORKS | WORKS | Exterior Parts - The Rest | 2 | 06-13-2014 06:58 PM |
Tranny fluid or engine oil leak? | G.I.Choe | Issues | Warranty | Recalls / TSB | 1 | 05-28-2014 06:53 AM |
Small Oil Leak under center of engine? | brillo | Issues | Warranty | Recalls / TSB | 6 | 11-09-2013 09:52 PM |
Wanted: drivers side front fender | Yruyur | Miscellaneous | 0 | 11-26-2012 09:30 PM |
