Old 05-23-2012, 10:29 PM   #15
jdrxb9
jdrxb9's Avatar
Drives: ND2, formerly BRZ (MT/CBS)
sparks - good to see the Subaru procedure finally - any idea when this will go public at http://techinfo.subaru.com/index.html ?
Interesting to see that even though the Toyota/Scion part numbers are different than typical Toyota numbers, they are also completely different than the Subaru number.
Also, is it really +/- 4.5' recommended for Subaru? For scion, it is +/- 45' 'Standard Dimension' and then another +/- 45' adjustment from the replacement bolt.
jdrxb9 is offline   Reply With Quote
Old 05-24-2012, 07:51 AM   #16
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by sparks View Post
0.0" +/- 4.5' = .075 degrees - Recommended
0" 45' = .75 degrees - With the adjustment bolts
Its the minutes to degrees covnersion
facepalm...
Thanks
Old 05-30-2012, 04:28 PM   #17
slimjoe
Drives: 2013 WRB BRZ
What's the stock camber before putting this bolt in?
slimjoe is offline   Reply With Quote
Old 05-30-2012, 07:18 PM   #18
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Perrin said the front is set to 0* and the rear is -.5*
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 02-27-2013, 12:52 AM   #19
Not4off
Not4off's Avatar
Drives: White Premium Manual
Ten bucks worth of Negative Camber
Installed Subaru camber bolts and had the car aligned the following day. The max negative camber we could get was 1.0 degree.
Front camber -1.0
caster 5.6
toe 0.0
Rear camber -1.0
toe .14
Still...this is an improvement over stock (front) camber of 0 degrees for $10- in parts
2013 BRZ Premium Manual
2009 Porsche Carrera S Manual
Not4off is offline   Reply With Quote
Old 03-28-2013, 07:58 PM   #20
SLICVIC
SLICVIC's Avatar
Drives: 2006 STi
my BC coilovers come "slotted" for camber adjustment and are maxed out as of right now. the knuckle is hitting the coilover "lower mount" on top, so a camber bolt in the top hole will not give me anymore negative camber, will i be able to install the bolt in the lower hole? id like to get more negative camber up front for clearance reasons with wide wheels. On my old STi it was specific which bolts can be replaced and which would need to stay with stock bolts otherwise its likely to slip.
SLICVIC is offline   Reply With Quote
Old 03-28-2013, 09:38 PM   #21
OrbitalEllipses
Drives: Attitude
Lower bolt hole can be used, it's advertised as "for race use only" by the bolt manufacturer. Which means it will probably slip eventually,
Old 03-28-2013, 10:17 PM   #22
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
I wonder what the max we could get with these + Eibach style bolts is. I could easily get 3* on my old Impreza. And if you install them correctly slipping isn't really an issue.
Nathan
SubieNate is offline   Reply With Quote
BRZ front grille mod bloomy116 Cosmetic Modification (Interior/Exterior/Lighting) 255 06-13-2021 08:58 PM
power steering feel adjustment brillo Engine, Exhaust, Transmission 29 11-06-2017 03:41 PM
My frs confirmed. Now what? Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 51 05-09-2012 06:05 PM
Comparing front end of the FR-S/FT-86 to BRZ DIG1992 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 66 11-21-2011 05:26 PM
Handling: Camber Attainable with Struts. Your Experiences? skeeler Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 11-09-2011 04:07 PM
