#15 |
Boosted
Drives: Sideways
have you unplugged your battery recently? I had this issue 8 months ago when I pulled my battery and started it after putting it back in. The ECU has to relearn its trim levels and can take up to 50 miles to get back to normal.
#16 |
Professional Smartass
Drives: White Out FRS
Nope, it had at least 500 miles since the last battery pull. Yesterday I unplugged it to see if the trims were just bad and it's still doing it.
#17 |
Pull a log with what Nelson (nelsmar) suggested to see what the commanded AFR is. If the tune is asking for a high AFR you can fix it if you really want, if it's requesting low and just lagging a bit in response there's nothing you can do unless there is something else at fault (leak, bad sensor, etc).
IIRC, pulling the battery doesn't reset the trims either, you have to do a fresh flash to reset them.
#18 |
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
If it's not under load no worries
SOLD THEM BOTH
Hers: 2007 987S Mine: 2012 991S That was fun, thanks Hachi ![]() |
#19 | |
PhoneFlash by EcuTeK
As for what might be going on, you may want to take a look at your long term fuel trims and see what they are doing. You might see some crazy swings to rich or lean almost randomly, this can cause the AFR ratios to do just like you have stated. We have seen this happen more so on forced inductions vehicles, depending on how they are calibrated. Cheers, William Knose Delicious Tuning |
#20 | |
Mapping it our you're spot on. My long term fuel trims are going nuts. And the sensor is seeing 15 AFR and using the trims to bring it back down. ![]() Attached logs with requested parameters. Last edited by post_break; 06-05-2014 at 08:34 PM. |
#21 |
FYI, you can share logs easier by uploading them to datazap.me
![]() I don't have anything to open them with at work, but I'm sure someone will take a look before I'm home!
| The Following User Says Thank You to wparsons For This Useful Post: | post_break (06-06-2014) |
#22 | |
| The Following User Says Thank You to post_break For This Useful Post: | wparsons (06-06-2014) |
#23 |
Yep, sure is! SO handy.
#24 |
So after clamping the evap hoses under the intake my AFRs went back back down. Here is an updated log.
http://datazap.me/u/postbreak/kraftw...i-93-flex-fuel |
