Old 05-25-2014, 09:43 PM   #15
FloridaFRSdriver
Drives: 2013 Whiteout FRS 6 Speed Manual
Originally Posted by headlikeahole View Post
A shot of my hard work, just because.
I just had to say... That Ultramarine looks really nice, love the wheels too.
FloridaFRSdriver is offline   Reply With Quote
The Following 3 Users Say Thank You to FloridaFRSdriver For This Useful Post:
@Art_Mighty (05-15-2015), Clipdat (05-26-2014), headlikeahole (05-25-2014)
Old 05-26-2014, 01:50 AM   #16
Tromatic
Originally Posted by AznBRZer View Post
Yup. It's a design flaw where the rubber door trim digs into the pillar.
Shit, I've got it too. Is there a TSB for this?
Tromatic is offline   Reply With Quote
Old 05-26-2014, 05:04 PM   #17
KPR10
KPR10's Avatar
Drives: 2013 Scion FRS - Asphalt
As indicated from one of the other threads, I also had this issue and had my pillars replaced under warranty.
The cause is the window sill trim rubbing against the pillar and exposing bare metal to salt and moisture (for those who deal with snow or those near the ocean).
Get them replaced under warranty and make sure to clean those areas regularly. Hopefully that should help.
KPR10 is offline   Reply With Quote
The Following 3 Users Say Thank You to KPR10 For This Useful Post:
brzr (05-27-2014), headlikeahole (05-26-2014), jcw99 (01-02-2015)
Old 05-27-2014, 03:33 PM   #18
cycleboy
Drives: 2013 Scion FR-S - Argento
Originally Posted by blackhawkdown View Post
doesn't warranty cover this?
Yes, but it is a design flaw so it is just going to keep doing it.
Unless we find a DIY method to prevent, such as the small piece of clear film in the other thread.
It is getting frustrating that our cars have all of these known issues that only have DIY solutions and no fix from the factory.
cycleboy is offline   Reply With Quote
The Following User Says Thank You to cycleboy For This Useful Post:
headlikeahole (05-27-2014)
Old 05-27-2014, 05:37 PM   #19
b1pkkf26
Drives: 2005 civic, FR-S
Touch wood, I've been through two winters with my FRS and I have zero issue regarding that part showing rust.
b1pkkf26 is offline   Reply With Quote
Old 05-27-2014, 08:31 PM   #20
brzr
brzr's Avatar
Drives: 2013 frs
i'm gonna have to go check out mine now
thanks op for this!
i bought my plates 7 years before i bought my car
http://www.ft86club.com/forums/album.php?albumid=1329
brzr is offline   Reply With Quote
Old 05-27-2014, 09:11 PM   #21
vh_supra26
Site Moderator
Drives: Supra
Is this issue cover by the warranty?
vh_supra26 is offline   Reply With Quote
Old 05-27-2014, 09:23 PM   #22
headlikeahole
headlikeahole's Avatar
Drives: Ultramarine toyobaru
So far for most people the answer has been yes
headlikeahole is offline   Reply With Quote
The Following User Says Thank You to headlikeahole For This Useful Post:
vh_supra26 (05-27-2014)
Old 05-27-2014, 09:27 PM   #23
vh_supra26
Site Moderator
Drives: Supra
So once its fix, will the issue reoccur?
Old 05-27-2014, 11:10 PM   #24
sirsol66
Drives: 2013 FRS- Hot Lava
I tried to look at mine but it seems like my weather stripping is glued in place, I can't even push it down. How are you guys even seeing this?
sirsol66 is offline   Reply With Quote
Old 05-27-2014, 11:43 PM   #25
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Won't XPEL Paint Protection Film prevent this?
Chad86 is offline   Reply With Quote
Old 05-28-2014, 02:13 PM   #26
CruiseZen
CruiseZen's Avatar
Drives: 2014 Ultramarine 6MT FR-S Monogram
It might. Haven't heard from anyone yet who's applied a film to this area. I always carefully apply a little spray on wax using a cue tip to this area every time I wash the car. If this area is kept protected it shouldn't rust.
Borla axleback exhaust * mud guards * Michelin Pilot Super Sport tires * Opti-Coat * BRZ trunk lid liner * Rexpeed Wide Mirrors (heated)
CruiseZen is offline   Reply With Quote
Old 05-28-2014, 02:48 PM   #27
hamzam
Proud dad of 2 boys :)
hamzam's Avatar
Drives: Firestorm 6-MT
Wow. I have rust in that spot (minor) on both sides. Thanks for the heads up! Car was bought Aug. 1, 2013.
hamzam is offline   Reply With Quote
Old 05-28-2014, 02:59 PM   #28
FRSupra
FRSupra's Avatar
I just wanted to share, I believe what causes this (obviously as stated above the trim rubbing on the metal) is the vibration from the door closing.
I have taken meticulous care of my car, and it's garage kept and not driven in winter. Sure enough, slight rust is present, but only on the drivers side. I have barely ever used the passenger side door, it's been opened maybe 15 times since I've owned it, and no rust is present.
If you shut the door you can almost watch it happen.
FRSupra is offline   Reply With Quote
The Following 2 Users Say Thank You to FRSupra For This Useful Post:
Chad86 (05-28-2014), KPR10 (05-28-2014)
Beware: Excessive rust on suspension parts mav1178 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 11-20-2013 02:22 PM
Small rust spot look a like stain? Bach415 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 23 04-30-2013 02:35 PM
BEWARE DRL TSB! Hawaiian Issues | Warranty | Recalls / TSB 34 03-30-2013 10:21 AM
Rust? even with rust proofing? Chinadian Issues | Warranty | Recalls / TSB 8 01-26-2013 05:15 PM
