#15 | |
| The Following 3 Users Say Thank You to CSG David For This Useful Post: |
#17 |
Conedancer
Drives: 2013 Subaru BRZ SWP
Lockup and Decel are independently adjustable..
.. its based off wheel speed of the inner and outer during turns. Bill
Join my BRZ/FRS FB Group ![]() Thanks to:Kartboy/Wheeldude/Nameless Performance /Gaurd Transmission LSD |
| The Following User Says Thank You to Scooby South For This Useful Post: | dp1 (05-20-2014) |
#18 | |
Senior Citizen
Drives: Scion FR-S
The last GT unit I had my hands on looked no different than your average clutch type diff....
| The Following User Says Thank You to simpleisbest For This Useful Post: | dp1 (05-20-2014) |
#19 | |
If the LSD comes with the ring gear on it, then it is transmission specific. If you're using the stock ring/pinion it doesn't matter. You *could* run the manual final drive with an automatic too, but then you would have to pull the pinion from diff pumpkin.
| The Following User Says Thank You to wparsons For This Useful Post: | dp1 (05-20-2014) |
#20 |
driving smoother faster
Drives: Sold
Ok, just talked to @CSG David and I'll get their Cusco setup configured the way @CSG Mike likes it
![]() Now the big question that will be addressed tomorrow: will Scion want to replace the diff and in the process open up and install Cusco bits, or will they just install the new diff as is and I'll get someone else to install Cusco...crossing fingers... Much appreciate all responses |
#21 | |
Conedancer
Bill
#22 |
Both Cusco and OSG headquarters are within 30 minutes of CSG
We've been using the Cusco differential, but you can't go wrong with either unit.By request: OSG Cusco
| The Following User Says Thank You to CSG Mike For This Useful Post: | Shankenstein (05-20-2014) |
#23 |
Drives: Sold
Cusco it is, with middle-of-the-road settings and whipped cream on top, thank you
#24 | |
If it's under warranty, there's no way they'll replace OEM with aftermarket IMO. If you're paying for the replacement, they'll install whatever you want.
#25 | |
Drives: Sold
Yeah, I talked to CSG today and we agree that it's best to have diff replaced under warranty and then I'll have an experienced diff shop install Cusco LSD into the pumpkin afterwards. |
#26 | |
Drives: Sold
#27 |
Damn.
![]() Well, at least we know you have a solid upgrade coming. |
#28 |
Drives: Sold
Aftermarket differential (LSD) options for automatic transmission (AT)?
Yeah, no big deal, comes with the territory. I am a little bit concerned about DSS axles, as the first set I got was leaking axle grease from both (probably just the metal ring wasn't tightened enough, it can happen)...but now this axle pin damaging axle seal and the axle separating...let's see what happens...I don't really want to go back to stock axles as that is a weak point with more power and tracking...hope this gets sorted out with DSS. I don't blame scion for their course of action as it appears that failure may have been caused by an aftermarket part. I know that @PrimeMotoring will take care of me, just scheduled seal replacement and putting in original axles on Tuesday. |
| Automatic Transmission | devinclfalcons | Engine, Exhaust, Transmission | 60 | 04-29-2014 10:42 PM |
| Differential and Transmission Fluid Swap with Red Line Oil - 2013 Subaru BRZ | JPxM0Dz | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 1 | 05-05-2013 06:12 PM |
| Transmission and Differential Fluid Change LINK | Amadeus | DIY (Do-It-Yourself) Guides | 1 | 12-23-2012 07:01 PM |
| Automatic Transmission :( | Almighty Bob | Southern California | 14 | 11-06-2012 02:13 PM |
| topspeed difference between manual transmission and automatic transmission | torquemada | BRZ First-Gen (2012+) — General Topics | 51 | 05-04-2012 08:54 PM |
