Old 05-07-2014, 03:09 PM   #15
brzzz
Drives: White BRZ
Try setting it to blow on the windshield then turn it off.
brzzz is offline   Reply With Quote
Old 05-07-2014, 03:21 PM   #16
codesplice
Elite Recognized Geek
codesplice's Avatar
Drives: 2014 DGM BRZ Limited
That's the other recommendation I've seen/tried.
This post is a work of fiction. Names, characters, places, and incidents either are the product of the poster's imagination or are used fictitiously, and any resemblance to actual persons, living or dead, business establishments, events, or locales is entirely coincidental.
G+
codesplice is offline   Reply With Quote
Old 05-07-2014, 03:35 PM   #17
swaq
swaq's Avatar
Drives: 2013 Subaru BRZ
Originally Posted by SirBrass View Post
This is my first subie where this has been an issue.
I have the same issue with my 2005 Legacy GT. I haven't noticed this behavior with my BRZ (manual climate controls).
swaq is offline   Reply With Quote
Old 05-16-2014, 05:03 PM   #18
bdbx18
Drives: Present MDX, Civic Hybrid, BRZ
I never drive all my cars with recir off. But for safety venting reasons, auto manufacturers always default to having it off? At least with Bimmers, it is a programmable feature. Perhaps it's the freeway parking in LA; who needs pure exhaust and fresh foul catalytic converter smells warfing into a small interior?
Current: 07 MDX, 06 Civic Hybrid, 13 BRZL
Past: 03 M3 SMG, 99 540i, 01 X5 4.4, 01 X5 3.0, 03 MDX, 92 NSX, 89 Maxima, 86 Integra, 88 Odyssey, 88 Legend, Supra, MR2T, Pathfinder, MirageT, Accord
bdbx18 is offline   Reply With Quote
Old 05-19-2014, 05:34 PM   #19
uEih
Drives: CBS Subaru BRZ Limited
Still doesn't help in my case. This is my first subie where this has been an issue.
When it was much cooler, no problem. I normally wanted some warmer air anyway even if I wasn't running the heat. Now, though, it gets annoying. Usually I have to run the temp up to just about where ambient is (set HVAC to auto, and roll the temp up till the fans drop to a low fan speed) and hit the A/C and recirc. If I have the windows down, I hit recirc and turn a/c off and drop the temps down. Still end up with way warmer air than what is coming in through the windows.
I think it's b/c our engine bay runs hotter than normal anyway, so wherever the cabin air is being pumped in from fresh (or even near the firewall), is where it gets heated up more than normal.
I bet if one is able to ventilate a good bit of the normal bay heat, the issue will decrease.
Air still blows through when you have the recirc on? Sounds like a problem because when I have that on I don't get any air in at all.
uEih is offline   Reply With Quote
Old 05-19-2014, 05:38 PM   #20
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
No, I'm saying that even with recirculating air, the air coming out of the vents is hotter than the air coming in through the windows. That means that something in the HVAC system that is making contact with the airflow after the fresh air/recirc cutoff point is heating the HVAC cabin air.
^GT5 Replay Photo Mode^
Old 05-19-2014, 05:49 PM   #21
t.chk
Drives: Subaru BRZ Limited
Originally Posted by Lebby83 View Post
Not sure if this is normal or not for our cars. When I have the AC/Heat off completely there is a lot of hot air flowing out of the vents, mainly when in motion of course. I have never noticed this on any of my previous and current cars, but this is my first Subaru so I am not sure if this is common.
Any input??
Thanks!
The trick that I learned is to turn the system on for a min then hit the off button. It will continue to allow air into the car but it will be cooler temp for the rest of the drive.
Just did a 190 trip like this and it was great.
I have a BRZ limited with the dual zone climate control...do not know if this works on other units.
t.chk is offline   Reply With Quote
Old 05-19-2014, 05:50 PM   #22
SirBrass
SirBrass's Avatar
I'll give this a try, since I'm in a BRZ Limited also.
Old 05-19-2014, 05:56 PM   #23
t.chk
Yea it seems going from fullauto to off fixes it for me (you do have to wait for the air to cool off before hitting off for whatever reason). at speed a good amount of air is forced through the vents. I was driving in ~75 degree weather and it felt 'close to outside' temp.
Old 05-19-2014, 07:58 PM   #24
darkelf
Drives: Crystal Black Silica BRZ
i found the same issue with hot air blowing through the vents... i played around with various settings and found that with everything off and airflow set so that the air is coming through from outside, once i pressed the air direction button and set it to the main vents or whatever is your preference (it actually has to light up to show the selected option), then the air coming in was cool... it obviously also depends on the outside temperature at the time...
i am not sure if this will be of help as i am no great at explaining things but it worked for me...
darkelf is offline   Reply With Quote
Want to trade my BRZ fender vents for you FRS fender vents, or buy FRS vents outright ill roller Exterior Parts (Aero, Lighting, Etc.) 6 09-22-2013 10:49 PM
How cold is your a/c blowing? jermyzy Issues | Warranty | Recalls / TSB 68 08-18-2013 03:29 PM
WTB BRZ galaxy blue fender vents or trade w my FRS UM blue side vents BlueLeader Exterior Parts (Aero, Lighting, Etc.) 0 03-18-2013 02:55 PM
Did the issue with the air vents blowing hot ever get resolved? fiveoneoh Scion FR-S / Toyota 86 GT86 General Forum 25 09-05-2012 01:21 AM
A/C Compressor blowing hot? Is this normal? SocalBurt Engine, Exhaust, Transmission 3 08-22-2012 07:10 AM
