Old 11-18-2015, 04:56 PM   #15
JarredH
JarredH's Avatar
Drives: Scion frs
Anybody find this fix?
JarredH is offline   Reply With Quote
Old 12-24-2019, 05:06 PM   #16
doggieboy09
Sènior Member
doggieboy09's Avatar
Drives: '22 BRZ |'13 BRZ SSC (formerly)
Found something else!
https://www.ft86speedfactory.com/ver...l#.XgKL1EdKiUk
doggieboy09 is offline   Reply With Quote
Old 02-01-2021, 08:21 PM   #17
Trapstyle666
Drives: Slammed 2015 Subaru BRZ aozora
Found them, https://www.etsy.com/listing/8755169...-marker-delete
Trapstyle666 is offline   Reply With Quote
Old 06-04-2021, 08:45 AM   #18
86hales
Drives: Supercharged '16 Release Series FRS
Smile FOUND THEM!
I didn't see this guys post^^
But I also found something very similar on etsy, I am having my whole bumper repainted and I found some inserts that will be perfect to be sanded and molded into the new bumper.
https://www.etsy.com/listing/8755169...=hp_rv-1&pro=1
~ENJOY~
86hales is offline   Reply With Quote
The Following User Says Thank You to 86hales For This Useful Post:
jflogerzi (06-27-2021)
Old 06-27-2021, 07:13 PM   #19
jflogerzi
jflogerzi's Avatar
~ENJOY~
Thanks for sharing!
2013 Series 10 FRS #553
Old 06-28-2021, 10:20 AM   #20
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
~ENJOY~
They will crack out unless you get a bumper mounting solutions such as the Move Over Racing Bumper Quick Releases. The stock bumper tabs flex too much putting pressure on the outside corner of the bumper. Where normally the sidemarker is. JiveTurkey and myself are probably the only ones that deleted/shaved them. Mine didn't crack put but, stressed enough to show a hairline in the paint.
Old 06-28-2021, 04:57 PM   #21
czellers
czellers's Avatar
Drives: 2K19 GT86
Originally Posted by SmsAlSuwaidi View Post
Paint match the stock ones, thats what i did
Same here, I lucked out with black (D4S) because gloss black paint is nearly perfect - Before/After:
czellers is offline   Reply With Quote
WTB: orange OEM side marker (passenger side or both) Kayzer Soze Exterior Parts (Aero, Lighting, Etc.) 4 09-05-2013 04:46 AM
Side marker clips ? PhreshhWun Cosmetic Modification (Interior/Exterior/Lighting) 3 08-29-2013 04:21 PM
WTB: smoked side marker (driver side) vincent201089 Exterior Parts (Aero, Lighting, Etc.) 2 07-29-2013 04:29 AM
Side marker feature mashal Cosmetic Modification (Interior/Exterior/Lighting) 17 07-08-2013 07:27 AM
JDM Side Marker fitment fix. l0aded Cosmetic Modification (Interior/Exterior/Lighting) 2 06-11-2013 11:15 PM
