CANADA Canada
Old 04-26-2014, 04:54 PM   #15
Pbrown
Drives: 2013 Scion FRS Raven
a couple of reasonable choices
go to your dealer for a paint pen or DR. Colorchip They have the exact match for your vehicle.
Pbrown is offline   Reply With Quote
The Following User Says Thank You to Pbrown For This Useful Post:
Minovsky (04-27-2014)
Old 04-26-2014, 05:19 PM   #16
headlikeahole
headlikeahole's Avatar
Drives: Ultramarine toyobaru
Originally Posted by Honeydew View Post
oh so i shouldnt use a paint pen? i'll run by the canadian tire or something and see if they have anything!! Hope it helps!!!
No you could definitely use a paint pen! but you don't need the color side just the clear (I think)
headlikeahole is offline   Reply With Quote
The Following User Says Thank You to headlikeahole For This Useful Post:
Old 04-26-2014, 05:43 PM   #17
congee
congee's Avatar
Drives: SSM BRZ
Originally Posted by headlikeahole View Post
It doesn't look like it's completely through the clear coat, have you tried a scratch remover or compound? I'm guessing this wouldn't completely remove it as it looks deep but it could help.
If that doesn't do the trick you could get a clear paint chip repair. Add the clear into the scratch to "fill" it, then remove excess with a rubbing compound. repeat until the scratch is gone. I know the toyota paint pens have a clear coat on one side. Might work.
This.
I had a few big scratches on my bumper that looked as deep as your scratches. Got myself meguiars ultimate compound from CT. Had to rub it in hard and the scratches disappeared. Don't be discouraged if it doesn't work the first time. For a few of the bigger scratches, I had to rub at least ten times before it disappeared.
And I would suggest you take it to someone who knows what they're doing if you decide to go the paint pen route. From those pictures, doesn't seem like you need to tho.
congee is offline   Reply With Quote
The Following User Says Thank You to congee For This Useful Post:
Old 04-26-2014, 05:59 PM   #18
wbradley
Sarcastic SOB
wbradley's Avatar
I'd suggest Meguiars scratch remover only if the scratch isn't to the metal or deep enough that there's no pigment inside the actual scratch. Unless the scratch is thread thin, its a waste of time.
Dr Colorchip won't work.
There's a mobile paint repair guy on Toronto Subaru Club forum that a lot of people recommend. At the very minimum he could look at your pics or take a look at the damage and let you know if he can work his miracles. Last resort, body shop respray.
The Following User Says Thank You to wbradley For This Useful Post:
Old 04-27-2014, 03:25 PM   #19
AznKirby
Are you 20/20?
AznKirby's Avatar
Drives: Hopes and dreams
You should ask @brianc for a quick assessment. He's a detailing wizard
2014 FR-S Monogram
2005 Acura RSX Type-S
IG: @MonKehC
Old 04-28-2014, 12:02 AM   #20
daftpunk
daftpunk's Avatar
Damn, I'm so sorry to hear that. This is one of the things I dread most happening to me - and I work in that area as well.
Regarding a spot fix, from what I've seen, some professionals can do it pretty well to the point where it will be barely noticeable, but will still show a slight hint of it. the other option would be a respray.blend of panels, which would be more invasive to the integrity of the original paint.
You can give Chipmasters in Markham a call as they specialize in spot fixes
pm me if you want a recommendation of additional shops.
2013 Firestorm Scion FRS
2005 Civic SI Sedan- Sold
2004 Impreza WRX - Sold
1992 Civic Hatchback - Parted, RIP
daftpunk is offline   Reply With Quote
Old 04-29-2014, 05:41 PM   #21
glorydays
Remember me?
glorydays's Avatar
Drives: BRZ Series.Blue
ive had this issue with little kids with no house training... I caught one literally smacking my car with a stick and pole. left a ton of scratches on the a pillar. Ive used dr colorchip but the scratches are still visible just a little darker...
glorydays is offline   Reply With Quote
Why do people lean on their cars when posing with their cars? tzhu07 Other Vehicles & General Automotive Discussions 26 03-15-2014 08:51 AM
Kickstarter: MODARRI CARS (Cars for kids) dem00n Off-Topic Lounge [WARNING: NO POLITICS] 1 02-04-2014 12:19 PM
how much drop without hurting handling? nonicname Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 11-19-2012 08:23 PM
fr-s/brz vs 28k cars sofrsnsokleen FR-S / BRZ vs.... 45 11-16-2012 09:20 PM
Why the FRS / BRZ over other cars Calum Scion FR-S / Toyota 86 GT86 General Forum 11 03-22-2012 02:00 PM
