View Poll Results: Which Wiring?
Option A 3 12.00%
Option B 10 40.00%
Do not attempt 12 48.00%
Voters: 25. You may not vote on this poll
Old 05-26-2014, 09:07 PM   #15
Chimera
Drives: FRS
my back is doing me murder..
the rear another day... still need to figure out running the wires back there.
Old 05-26-2014, 09:18 PM   #16
soundman98
ProCrastinationConsultant
soundman98's Avatar
Originally Posted by Chimera View Post
projects starting to wear me out.
photo here of how I mounted the LEDS for the front grill.
don't give me that.. it's the wrong month for it.. this was my car last saturday, heard back from the insurance it's officially totaled 3 days ago.
now i need to go and pull every single itty bit of gear that i put in it, and then reinstall it all over again in the replacement...
Old 05-26-2014, 09:26 PM   #17
Chimera
Drives: FRS
D#MN.
did someone hit you?
Are you okay?
I can honestly say I haven't followed your build before, how much gear did you have in it?
Old 05-26-2014, 10:58 PM   #18
soundman98
soundman98's Avatar
i had just finished installing all my audio gear about a month ago..
some chick decided to not pay attention to the stop sign that she was supposed to stop for(i didn't have a stop sign at all).. i didn't have a chance, by the time i saw her and realized she wasn't stopping, i was 10' away from impact..
suffice to say, i now think that anyone that insists on changing the airbag emblem to something else is absolutely out of their mind.. sh!t hits the fan so fast, i sure wouldn't want "at least his airbag emblem looked cool" for a funeral motto...
Chimera (05-26-2014)
Old 06-29-2014, 12:56 AM   #19
Chimera
Drives: FRS
If I had known when I started what a pain this project would become, I likely wouldn't have started.
The wheels are now controlled by the same controller as the front, but independently powered and switched.
I need a better camera, my phone camera distorts the lights massively.
Old 06-29-2014, 01:41 AM   #20
retrosmiths
Drives: Scion FR-S Whiteout
@soundman98 nooooo, I remember you from HIDP and from our old convo when you still just had a bike and was very excited to get a 86 and now it's totalled???! (
2013 Scion FR-S
retrosmiths is offline   Reply With Quote
Old 07-01-2014, 10:12 PM   #21
soundman98
soundman98's Avatar
yep.. since then, i broke my wallet and bought another one in identical specs.. maybe i'll regret it later, but for now, i wouldn't have any other car.
Old 10-18-2014, 02:54 PM   #22
Chimera
Drives: FRS
Update
First non-busy weekend is months, got to work on this/finish it I think.
So it is now wired to be a slave to the dome light circuit. It turns on and off when I lock and unlock the doors, which IMO is the best.
If I really want to show them off while driving, like in a parking lot, all I have to do it turn the dome light on.
And thanks to the winjet switch, they are can be disabled.
If Anybody is interested in doing something like this, I can post more details on how I did it. Special thanks to Diode Dynamics, awesome products, only required very minor modifications to make this work.
Final circuit:
Old 10-18-2014, 07:47 PM   #23
Chimera
Drives: FRS
Circuit failed on the way to the gym.. I am really bad at this it seems. Need to investigate.
Edit: I think I need a solid state relay.
Old 10-18-2014, 09:10 PM   #24
Chimera
Drives: FRS
I think I need this:
[ame="http://www.amazon.com/HELLA-H41773001-Solid-State-Ceramic/dp/B000VU5FPE/ref=sr_1_1?ie=UTF8&qid=1413680675&sr=8-1&keywords=H41773001"]Amazon.com: HELLA H41773001 Solid State Ceramic 32 Amp SPST Mini Relay: Automotive[/ame]
Now I guess the question is this, will the control box handle the rapid on off duty cycles from the relay. hmmmm...
the answer is no.. I was curious and swapped the control box for an extra one I had, seems the control box doesn't like the rapid on off cycles.... mines dead.
I think a capacitor could solve the issue... then I could still use a standard relay.
Old 10-22-2014, 12:54 PM   #25
JoeMartin
Drives: 2013 Black Scion FRS
I know a lot of people hate on lights, but I love the idea. I'm all for visibility (most of my driving is at night), and since I don't speed, I don't worry much from the police noticing me as well.
With that said, I can't say I'm feeling the wheel well lighting with it shining directly on the top of the tire like that. It may just be the camera (likely is), but it looks like it's causing a hot huge hot spot that detracts from the accents for the lighting.
I feel having it shine in to the fender well would look better (though you have to keep your fender wells extremely clean, lol).
Keep up the good work. =)
JoeMartin is offline   Reply With Quote
The Following User Says Thank You to JoeMartin For This Useful Post:
Chimera (10-22-2014)
Old 10-22-2014, 08:57 PM   #26
Chimera
Drives: FRS
Quick post, just learned a new thing. The common anode is not where the arrow is... Like that makes sense... It's opposite.
Old 10-25-2014, 09:51 PM   #27
Chimera
Drives: FRS
So,
I tried to use the solid state relay on the common anode, but it let to much current leak, and the LEDs still partially lit even when the circuit was 'open'
So I tried this as an alternative.
It seems to be working so far. 2nd control box hasn't burnt out. Ill keep it this way for a little while.
I ordered another SSR from a different vender, hopefully with tighter tolerances. If it works the circuit will work much smoother by controlling the common anode and look nicer.
I ordered a Bluetooth RGB controller from DD. its neat, has cool functions, and even is pre wired to somewhat do what I'm doing.
Anyways, current circuit appears to be working, on and off is a little rough, but its working.
Edit: the diode shown near 86 85 isn't there.. Oops
Old 10-26-2014, 02:26 PM   #28
Chimera
Drives: FRS
Thanks. I don't really plan to ever have these function during driving, only when parked. The lights still work even with the wheel wells dirty because they are recessed. I might later on change to a more traditional underglow, but I thought that wheel wells would be easier to manage. I'm not sure if I understand what you mean by into the fender? Like inside the splash guards? Or actually behind the wheels instead of above them?
Does anyone know the secret to Japanese fried rice? jLoBRZ Off-Topic Lounge [WARNING: NO POLITICS] 12 03-27-2014 01:26 AM
so....what exactly is RICE? enjoi23 Scion FR-S / Toyota 86 GT86 General Forum 148 11-28-2012 10:05 PM
The Rice Thread Snoopyalien24 Other Vehicles & General Automotive Discussions 15 11-27-2012 04:28 PM
Rice ` jarviz Scion FR-S / Toyota 86 GT86 General Forum 20 11-18-2012 08:59 PM
Rice Killers--- (Dallas) NeedsmoreCowbell Southwest 7 06-23-2012 10:34 PM
