Old 07-18-2014, 04:53 AM   #15
Chen
Regional Moderator
Chen's Avatar
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
My question, which nut do I use to adjust the height of the light output?
Chen is offline   Reply With Quote
Old 07-18-2014, 08:58 AM   #16
STS-V
Why exactly are these not FI friendly?
STS-V is offline   Reply With Quote
Old 07-19-2014, 11:41 AM   #17
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
See post #5
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
Old 07-23-2014, 05:45 PM   #18
aznknightz17
Drives: Vroom Vroom
Did you guys use harness for the D2S? @ecko04? Cold start my driver didnt turn on, had to turn off and turn it back on again to let them ignite.
Also like @Chen Im curious which knob is it to aim the headlight up/down
aznknightz17 is offline   Reply With Quote
Old 07-23-2014, 08:33 PM   #19
Chen
Regional Moderator
Chen's Avatar
I figured it out. It's the only 8mm bolt that's back there. Counter clock wise for up and clock wise for down.
My advise do it whole the headlight is off the car. It's a pain while it's on the car
Edit- clock wise for up and counter clock wide for down.
Old 10-16-2014, 01:07 PM   #20
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Sorry to bumb this thread, but I installed these earlier and hadn't seen this mentioned in any of the other threads on them. Do these not have Hi/Lo beams? I'll look to see if I see it in any other threads, but figured I'd start here. Thanks!
Old 10-16-2014, 01:29 PM   #21
jonzhuxD
Drives: Ultramarine FR-S
Yes, there is a high/low beam but it's a bit different than stock.
It's a bi-xenon projector setup. The projector inside has a shield that blocks off light above a certain threshold so you don't blind other drivers. When you turn on your high beam, this shield moves down to let all the light shine out of the projector.
There's much more to it but that's a general description.
jonzhuxD is offline   Reply With Quote
Old 08-17-2016, 09:53 AM   #22
kennyd8606
Drives: 2013 scion frs
hi I just got these light install on my frs today but I was wondering how do you wire the led drl strip to stay on without turn on the light switch on in the daytime?!
kennyd8606 is offline   Reply With Quote
Old 08-17-2016, 05:30 PM   #23
Chen
Regional Moderator
Chen's Avatar
DRL like when you put down your e-break and the lights come on? If I remember right, you can't because you take the harness out when you install the new headlights.
Old 10-14-2016, 08:52 AM   #24
FR-S Runner
Drives: 2013 FR-S Whiteout
Kinda need help with this guys, please bare with me. I got the headlights same time as you all but now i just had the chance to installed it on Wed. Long story short got the HID H1 in and after couple mins of messing with the washer, i got it to fit. The long "rod" was upward and the bulb itself on on the bottom if you know what I mean. The output and coverage was quite disappointing, please check and see. Is that what you guys are getting also?
As you can see since the "rod" is above the actual bulb, there is a reflection of it on the wall and also on the ground. Hard to miss it. Should I go get D2S instead?
How exactly did you fix this? My body shop put these lights on and got the same results.
FR-S Runner is offline   Reply With Quote
Old 10-15-2016, 01:46 PM   #25
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
Are you guys using D2S bulbs? I know with that bulb there is also a D2R that has the rod thing of the bulb in a different spot.
@Diode Dynamics for someone who actually knows lol
Old 10-17-2016, 10:28 AM   #26
Diode Dynamics
Diode Dynamics's Avatar
D2S is designed for use in OEM projector style housings, D2R is designed for reflector style applications.
Those output shots with the keyholes look like OP is running an H11 in an H11B housing or H11B in H11 housing etc etc
That keyhole is caused by the position of the leadwire on the HID bulb.
Nick C.
John C.
Diode Dynamics
Old 10-17-2016, 06:56 PM   #27
FR-S Runner
I was told that there is an h1 bulb in there.
Old 10-17-2016, 07:12 PM   #28
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
factory is h1
I run D2S in mine they fit fine (there is a adapter to fit the h1)
Springs! Post your Pics!! stevohl Suspension | Chassis | Brakes -- Sponsored by 949 Racing 113 11-10-2016 02:30 PM
Cat/Car pics, post yours :) ZionsWrath Other Vehicles & General Automotive Discussions 18 08-10-2014 11:26 AM
Post your winter pics kidgogeta Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 12-16-2013 01:52 PM
Raven Only! Post Pics! imlevinit FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 1 07-06-2012 07:41 PM
