#15 |
Drives: Smells like tires when I drive
While I don't own either a big question that's been plaguing my "build" for a while is if I trust an oil pump for the oil return on the turbo. I may have said no in the past for various reasons however I believe AVO has really done it right by driving it off the cam rather than having an electric pump, which I REALLY don't trust.
#16 |
Drives: Silver 2013 BRZ limited
Is it cause the turbo is limiting? What is it about the turbo that people would rather change it out?
#17 |
dying bird under the hood
Drives: 2013 SWP Limited BRZ
some people like to go big to have the capability to go above 400whp. Few do though.
| The Following User Says Thank You to midnight23 For This Useful Post: | SliverBrz (04-14-2014) |
#18 |
I like to eat!
SliverBrz
I have an AVO kit on my BRZ, and love it. It puts out 260whp on 8 psi. If I were living in SoCal there would be no question I would choose the AVO over the Greddy. Your main concern should be HEAT! You will need either an oil cooler, more fans, a vented hood and fenders, or a larger aftermarket radiator to keep a front mount turbo cool in SoCal. With the AVO, you can DD or track the car with no heat issues with the stock cooling system. I do. Pete |
#19 |
Junior
Drives: a car
Everyone seems to forgot AVO is coming out with a stage 3 option, which will include stage 2, plus 3" piping and a billet compressor wheel.
| The Following User Says Thank You to cdrazic93 For This Useful Post: | CxG (01-31-2017) |
#20 |
NASA SpecE30 Racer
AVO Pros:
Cheap AVO Cons: Poor QC leading to leaking flanges Poor QC leading to flaking of ceramic coating Cheap turbo that is too small to hold boost to redline Sell the kit without a BOV or BPV and expect customer to plug holes Due to low mount requires complicated oil delivery and return system Intercooler mounting is not compatibile with most aftermarket oil/water cooling solutions GReddy Pros: Short intercooler piping GReddy Cons: Expensive No BOV
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#21 |
Drives: 2JZ FRS
I haven't had any qc issues and it's been 10k plus miles at 11-17psi. No fancy gaskets, just new oem
The oil system is much faster to install than having to weld up an oil pan. Again, zero issues and I prefer it over an electric scavenge pump. I'm not against welding up an oil pan though so it wasn't really a concern for me I do agree, the kit should include the bov from the start I can't say anything about oil coolers since I don't run one Boost does taper off, but I make a good bit of torque at redline even with the drop |
#22 |
The Greddy also requires getting rid of your front bumper beam. I know they have a template for cutting it, but after you are done there is almost nothing left of it.
The oil system on the AVO is a plus in my book, once you bolt up their plate it's like any other system, just hooking up a few lines. And it uses an OEM solution unlike the electric pumps out there. The PTuning kit should really switch to the same mechanism since the pump is only about $80 from Subaru and you just need a plate to mount it to. AVO is just a small turbo that's all, the Greddy kit is very similar since it uses almost the same size turbo. It's a good street turbo. Both systems IMHO are overpriced for what you are getting in the kit. |
#23 | |
Stig's dark passenger
Ball bearing, more efficient, twin scroll, quicker transient times, name brand turbo for sponsorship reasons, etc etc etc Locked in with that turbo for me, is a limiting factor. But, as I said before, its tue closest ots setup that would work for me. D |
#25 |
Subaru Certified Sales
Drives: '13 BRZ Premium, '05 WRX STi
As mentioned earlier, the SBD kit is nearly a complete solution with similar power and delivery as both kits. Sure, crash beam blah blah blah. You either worry or don't. We are all accepting risk when we mod our cars.
The SBD pros are: billet wheel 20G, bov, boost control, good base map, excellent support, short piping and price. Cons? No ECUTek license or cable, but you can just borrow a cable and buy a license. No gauges, but a P3Cars gauge and wire in a wide band O2 and you're set. For some, the modifying or removal of the crash beam us a sore spot. I have been running my SBD turbo for a little bit on stock everything and 91. The most it made on 10psi was 278 and lowest on 8psi it was about 248. I've lined up with a few fast cars for little bits of street fun and the car is surprisingly quick. This past Sunday at Import Face Off I ran a 13.7 @ 102mph with a 2.1 60'. It was consistent 13.8 ET and 102mph traps. I'm admittedly rusty and the lack of launch control made leaving a bit tricky. Flex fuel is also coming down the pipe and an oil cooling solution is already on the table. These are exciting for me! I can't really comment on the AVO but I'm not a fan of a scavenge pump.
[Subaru WRX STi] Benson Block - Kelford Cams - PTE6466 - ID2000s - AEM - E85 [Subaru BRZ] Speed by Design Turbo Kit - Invidia N1 - BC Racing BR Coilovers - Rota RT5s [Subaru WRX] Prodrive - Subaru Tecnica International - APS - Tein - Rota Titans "The only thing that I trust in this world is cars!" - Don 'The Goods' Ready |
#26 |
NASA SpecE30 Racer
Did I miss where this thread turned into an SBD pros and cons thread? We all have our favorite turbo kits, but we didn't do pros and cons for them in a thread about the AVO and GReddy kits.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z Last edited by King Tut; 04-15-2014 at 12:50 PM. |
#27 |
NASA SpecE30 Racer
I forgot to address this. Clutch yes, brakes no. The OEM brakes will do just fine on the street. If you are planning on going to the track then I would consider an upgrade.
- King Tut
| The Following User Says Thank You to King Tut For This Useful Post: | CxG (01-31-2017) |
#28 | |
If you don't look around or get an interjection from others, how do you ever make an informed decision?
| Pros and Cons of the Rocket Bunny Kit | VroomVroom86 | Cosmetic Modification (Interior/Exterior/Lighting) | 28 | 11-07-2014 02:29 AM |
| KW V3's pros & cons | Shaolin | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 22 | 02-25-2014 10:58 AM |
| Car Wrap / Foil Wrap : Pros and Cons? | LeBryan | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 06-25-2013 10:13 PM |
| What are the Pros and Cons of switching to a bigger set of Brakes? | STi88 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 50 | 08-06-2012 03:50 PM |
