Old 04-11-2014, 03:13 PM   #15
zooki
Drives: waiting on a 2021...
Smile
They're for cars that have, you know, like, torque.
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
Old 04-11-2014, 09:06 PM   #16
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
I ment that link for the website more than that specific transmission.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Old 04-12-2014, 02:46 AM   #17
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Originally Posted by Dipstik-sportech View Post
Oh they're brutal. The 6th gear is like .5:1. Top speed of 235mph anyone?!
The Frozen North
It depends on the what magnum you're looking at. 6th for the 11009 is .63. As is, my first and second are unusable when running e85 @20 psi.
I was also looking into swapping in the 6 speed from the Z's. They are cheap, durable, and still in production. The gearing however killed that pretty quick. I would need a sub 3.5FD to make that work so a swap would have to include the trans, DS, FD, Axles, and clutch.
If anyone has a better idea, I'm all ears.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Old 04-12-2014, 06:20 AM   #18
Dipstik-sportech
Dipstik-sportech's Avatar
Yeah I tried the cd009 Nissan trans. It won't fit without cutting the trans tunnel. That trans gets wider near the tailshaft and our tunnel narrows in the same spot. Also the starter location would be interesting to sort out
The Frozen North
Old 04-12-2014, 08:55 AM   #19
Reaper
Reaper's Avatar
Drives: violent
Wrx trans with the rwd spool in it?
Old 04-12-2014, 02:13 PM   #20
OrbitalEllipses
Drives: Attitude
Very true.
Old 04-12-2014, 11:21 PM   #21
Poodles
Drives: 2015 Series.Blue
Originally Posted by mrk1 View Post
Anything that has the Supra name with it gets priced up, I don't get it, I never thought it was some amazing car.
With patience and creativity I'm sure there are other options out there.
Then you don't know enough about them
The MKIV Supra is relatively rare, and then the turbo version is a bit more rare...and then the manual transmission is even a bit more rare than that. Not to mention it's not a transmission they're ripping out to stuff something else in because it's too weak (I've seen first hand over 1500HP through one of them).
R154 out of a MKIII Supra Turbo would fit as well with the V160 adapter (as I mentioned in that thread). That transmission has tons of upgrade parts available (and can handle a hell of a lot if in good shape, even stock), but it's only a 5-speed..
Originally Posted by Reaper View Post
these are brand new mind you but still ALOT CHEAPER. There is many varients as well, im sure one of them fits. They come in mustangs, camaros, corvettes, vipers all sorts of high hp heavy cars.
http://streetperformanceusa.com/i-15...FUgA7AodjRoAvQ
Double overdrive transmission isn't conductive to a high reving sports car...
Originally Posted by Target70 View Post
what about the getrag 5-spd from the Toyota soarer / lexus sc300? I thought they were strong but maybe not as expensive?
Those aren't Getrag, but a W58 from Aisin. Nice shifting trans, but ultimately weak (compared to the V160 and R154)
Originally Posted by Hawaiian View Post
Getrag. It's one of the reasons i stayed away from them.
They're a licensed Getrag made in China. It's a real shame as Getrags are usually bulletproof.
The Frozen North
Yeah, double overdrive is a bitch... 6th isn't a power gear at all on those trannies, in fact I remember them grenading in the 3rd gen F-bodies when used as such...
EDIT: After doing a bit of digging, how about the Aisin AY transmission used in the IS250 (and numerous other cars)?
1: 4.17
2: 2.19
3: 1.49
4: 1.19
5: 1.00
6: 0.84
R: 3.67
Looks like first gear is too steep though compared to the twins. I also find it weird people are having issues with the transmission in the twins as it's basically the same as the S2000, RX-8, and Miata. Someone out there has to make upgrade parts for it. Marlin Crawler would be a good place to start in that regard as they've been dealing with Toyota/Aisin transmissions for 2 decades now...
Also of note: Pontiac Solstice/Saturn Sky/Hummer H3/GMC Canyon/Chevy Colorado 5-speed is an upgraded R154 (MKIII Supra Turbo tranny). Honestly as the stock 6 speed is a single overdrive, if you're boosted and have a nice fat torque curve, a 5 speed would work just fine.
Old 04-13-2014, 11:56 PM   #22
Poodles
Hell, there's a Quaife sequential 6-speed for the S2000 that might bolt in. Main issue is cost as the V160 is a bargain compared to the Quaife
Old 04-14-2014, 12:03 AM   #23
Dipstik-sportech
Once @FullBlown finalises their v160 swap kit I'm going to attempt the r154 swap. You'll need to extend the shifter though because the twins bell housing to shifter distance is quite long.
The Frozen North
Old 04-14-2014, 01:52 PM   #24
Poodles
The Frozen North
You have PM
Old 01-12-2015, 04:13 PM   #25
blown
Drives: ft86
The Frozen North
bump?
blown is offline   Reply With Quote
Old 01-13-2015, 05:25 PM   #26
Dipstik-sportech
Originally Posted by blown View Post
bump?
Found issues fitting the r154 due to the shift linkage being along the top of the trans necessitating the need to hack the crap out of the tunnel.
Old 01-22-2015, 06:48 PM   #27
Reaper
Reaper's Avatar
Drives: violent
Might as well go tremec magnum or the Nissan transmission if it requires cutting up the tunnel. That sucks to hear dipstick. I'll have a faced tremec before the end of the spring.
Old 12-29-2015, 11:01 AM   #28
xoBethxo
xoBethxo's Avatar
Any new info on transmissions being swapped in? 30k miles and our 4th gear already has grinding at 31k miles.
Headers, cai, catback only. Haven't even tuned it yet, though I have the OFT to tune the car. Waiting to tune it so they don't try to weasel their way out of fixing the trans.
xoBethxo is offline   Reply With Quote
Scion FR-S options:what options did you have dealer installed? Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 42 01-06-2014 01:35 AM
Bushing upgrades, geometry options and other component options? der_rainman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-26-2013 12:53 PM
Canadian FR-S options VS U.S.A's options? Tino Scion FR-S / Toyota 86 GT86 General Forum 15 11-06-2012 10:07 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
Gearing Options and Diff options airboy808 Engine, Exhaust, Transmission 26 12-25-2011 01:11 PM
