Old 05-31-2012, 05:23 PM   #15
MarkRacerX
MarkRacerX's Avatar
Drives: 12' Evo X , prior 1st 86 FR-S
Autocross
Originally Posted by frsnky View Post
Hey Mark ,
Watched this past weekend because only had 245 miles I plan on running at next months autox . I'm with you on the fun and learning the car
Bill
Frsnky ultramarine, manual
Right on !!
I just ordered Hankook RS3's for next race June 9/10th weekend. Shall be whole new car on Sticky 140 treadwear tires, Can't Wait
Autocross & Drift = my Anti Drug!!
I have Car A.D.D prior few:
12' Evo GSR, 13' FR-S, 11' STi, 08' 135i, 07' 335Xi,
08' STi, 04' 350Z, 04' STi, 02' WRX. 96' GSR, 04' SE-R/SpecV
MarkRacerX is offline   Reply With Quote
Old 05-31-2012, 05:40 PM   #16
MTeator
First 86
Originally Posted by MarkRacerX View Post
Right on !!
Did you stick with the 215's? I was going to do 225, but after looking at it I think the RS3's will do best with the 215's. The tread is almost an inch wider than the Primacy HPs.
Only two of my Traklites came in today though... gotta wait till monday for the other two.
Scion First 86 in Lexington KY - Firestorm 6MT - Delivered May 17, 2012
Mods: Motegi 17x7 TrakLites, BFG Rivals, K&N 33-2300 Filter, Nameless Perf. Track Pipe, TRD springs & rear bar, Hotchkis front bar (eh), Kask trailer hitch
MTeator is offline   Reply With Quote
Old 05-31-2012, 05:45 PM   #17
MarkRacerX
MarkRacerX's Avatar
New Rubber
OEM Size to stick w/ C-Stock Class
Right on! What are weight of those? I am prob going w/ RPF1s Blk.
Old 05-31-2012, 06:01 PM   #18
MTeator
First 86
About 14.1lbs. They also have the perfect 42mm offset, especially if I put 245 hoosiers on them for CStock rather than RTR.
Since I wanted to stay in stock class prep I didn't go with the RPF1's.
Old 05-31-2012, 06:04 PM   #19
MarkRacerX
MarkRacerX's Avatar
info
About 14.1lbs. They also have the perfect 42mm offset, especially if I put 225 or 245 hoosers on them for CStock rather than RTR.
Wow that's Great weight ! How much are they?
Yeah for now just putting on Oem wheels, then later do wheels.
Old 05-31-2012, 06:10 PM   #20
MTeator
First 86
I got them for 268/ea through my local tire guy. Being forged they weigh less than comparable cast wheels.
The Following User Says Thank You to MTeator For This Useful Post:
MarkRacerX (05-31-2012)
Old 05-31-2012, 06:36 PM   #21
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
I have 225/45/17s mounted already for rs3s and a set of star specs. I need new lug nuts for them though. I have a event this weekend but the car wont be broken in by then so I may have to wait until the tenth.
feldy is offline   Reply With Quote
Old 05-31-2012, 11:56 PM   #22
Vanguard
Drives: Ford F-150 (not for long)
Just so you know, you can run any size tire you want...you just have to keep the same wheel diameter and width and stay in Stock classes.
Vanguard is offline   Reply With Quote
The Following User Says Thank You to Vanguard For This Useful Post:
MarkRacerX (06-01-2012)
Old 06-05-2012, 11:16 PM   #23
MarkRacerX
MarkRacerX's Avatar
Can't wait to test these RS3's out !!!
The Following User Says Thank You to MarkRacerX For This Useful Post:
Scooby South (06-05-2012)
Old 06-05-2012, 11:39 PM   #24
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
I put myself in STX *pro* class... as they get scored different on a different index than standard folks... that way I lessen the controversy that will surround the classing of this thing...and since its a shakedown run anyways... I am not expecting Miracles.. just want to get a feel for the car... will have some mods done on Sat...Exhuast turndown... Rims/tires...Rear Swaybar (16mm).... Endlinks... and most likely...my 4pot brakes going on.. since I am prepping for STX for real anyways..
Bill
Scooby South is offline   Reply With Quote
Old 06-06-2012, 01:55 AM   #25
NYR Solo
Drives: Subaru & Mazda
Time for some tire totes if your hauling them in the car to events.
NYR Solo is offline   Reply With Quote
The Following User Says Thank You to NYR Solo For This Useful Post:
MarkRacerX (06-06-2012)
Old 06-06-2012, 07:13 AM   #26
lordtakuban
lordtakuban's Avatar
Drives: 2013 FRS - Whiteout
+1
If I start autocrossing the FRS, I'll be picking up a set from TireRack.
Speaking to classing the car...
If it's put in CS, it will be fine unless it starts beating all the miatas, then there will be protests and they'll probably move it somewhere else (my cynicism speaking there). I would probably try to keep this in stock class if possible or one of the modest Steet Tire classes. Time will tell though.
2013 FRS - Whiteout - Slightly modified
2001 MR2 Spyder - Super White - Heavily modified
lordtakuban is offline   Reply With Quote
Old 06-06-2012, 08:06 AM   #27
MTeator
First 86
They're stupid if they don't make the FR-S/BRZ the car to have in whatever class it'll be in.
There's going to be a lot of these, and a lot of those will gravitate toward AutoX, which would greatly help the SCCA. Unless they're stupid.
Old 06-06-2012, 12:40 PM   #28
NYR Solo
Originally Posted by lordtakuban View Post
+1
I should finally have first hand experience w/ one of these next weekend. I stand by assertion that this car is a back marker in C Stock. The RX8 and 370Z have nothing to fear when they have wide R comps on. The MSR and ZOK still get the job done. Regular MR-Ss, Skystices, and Miatae are the back markers and compare similarly to the BRZ.
The latter will annihilate the competition that is in D Stock. The soft landing is in E Stock which is running much faster than D Stock.
There is no point for SCCA to go out of it's way to favorably class a car based on someone possibly attending an event. Everyone knows ten people who have said that they go to an event for every one person who has followed thru on what they have said. Way to piss off existing club members...
Interesting graphics on a 86 ESBjiujitsu FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 13 05-11-2012 11:16 PM
Interesting news about BBS Esoteric Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 02-17-2012 06:10 PM
Interesting take on 2012 GT-R bofa Other Vehicles & General Automotive Discussions 84 08-29-2011 06:38 AM
Why ft-86 is interesting? NewCarInQ42011 Scion FR-S / Toyota 86 GT86 General Forum 69 11-26-2010 04:05 PM
