Old 03-30-2014, 11:55 PM   #15
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
Originally Posted by Scalzo View Post
Damn but for 3.1K why wouldn't someone just get some wilwoods or new brembos?
Just a question, not hating lol
3.1 is for both front and rear. Brembos would cost about 4k, wilwoods would cost about the samet
supramkivtt2jz is offline   Reply With Quote
The Following User Says Thank You to supramkivtt2jz For This Useful Post:
Trap63 (03-31-2014)
Old 04-02-2014, 09:53 AM   #16
omgwtfbbqsauce
omgwtfbbqsauce's Avatar
Originally Posted by Trap63 View Post
I found a special sale from a friend that have bought wrong model of DBA....the DBA4655.
You can solve this issue very easily....Yo need to have a new hub level and I solved this issue with an internal spacer (4 mms H - 125mms DIA - 5x100 PCD). If you need, I get the .DWG file to realize this spacer.
Wish I had read your post earlier as I have DBA-4655-10 multistud. I don't really understand what you mean by adding spacers to fit the rotors, will it not physically bolt on the HUB without spacers? Can you please point me to the right direction?
omgwtfbbqsauce is offline   Reply With Quote
Old 04-02-2014, 10:01 AM   #17
Model Citizen
Lacking brains
Drives: frz
You should probably take a look at the used market for sti brembos in the us.
There are always tons on eBay from parters, and with patience, effort and luck better deals can be found on Nasioc.
Op, are you saying the difference between the old sti style rear rotor and new (bolt pattern aside) is a 4 mm x125mm spacer? I've been meaning to look up the actual difference, if so. That's awesome, makes pulling the full set from my forester much more appealing since the rear rotors would not be useless.
Model Citizen is offline   Reply With Quote
Old 04-02-2014, 10:41 AM   #18
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
so, for all
installing calipers coming from wrx sti 2008 if you get rotors dba4655 (no matter about pcd measures) H is 67.5 mms. on BRZ limited usa or sport europe the rotor stop too near to hub brackets and there isn't enough slot for the pad (internal). you need rotors dba42656 that they are H 63.5mms.
the only solution is to reduce internal quote for 4mms when using dba4655 and best option is to fits them with a spacer of 125.00mms like hub, and 4mms as High.
Inviato da mio iPhone usando Tapatalk
Trap63 is offline   Reply With Quote
Old 04-02-2014, 06:19 PM   #19
Trap63
Trap63's Avatar
so, for all
installing calipers coming from wrx sti 2008 if you get rotors dba4655 (no matter about pcd measures 100 or 114.3) H is 67.5 mms. On BRZ limited usa or sport europe the rotor stop too much near vs hub brackets and there isn't enough slot for the pad (internal). You need rotors dba42656 that they are H 63.5mms.
the only solution is to reduce internal quote for 4mms when using dba4655 and best option is to fits them with a spacer of 125.00mms DIA like hub, and 4mms as High.
I think that AUS version of BRZ /GT has the same measures of Sport Europe or Limited USA, so the stock rear calipers are the same and therefore same brackets and you need a DBA with H of 63.5 mms (not the DBA4655 5-10- 67.5 mms).
Old 07-15-2014, 09:15 PM   #20
The Sentinel
Project BRZ-Boosted Autos
The Sentinel's Avatar
Drives: MY14 BRZ
I did mine last weekend. Wasn't able to swap the bleeders over. Stripped one of the hex plugs, and didn't try the others. Will take to a machine shop later to have done.
I'm curious to know what you guys did about the banjo bolt mounts on the front calipers. The posts which stop it rotation are facing the wrong direction.
In my case, I just bolted it up facing the other way, and have it hard up against the posts on the other side, so if it spins at all, the only thing that can happen is it gets tighter.
Check out my ProjectBRZ YouTube Channel and Facebook Page for the latest reviews, guides and information.
The Sentinel is offline   Reply With Quote
Old 07-15-2014, 10:44 PM   #21
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
I know others will disagree with me, but when I installed my Brembo I didn't bother to swap the bleeders over. Doing it this way means that my brake lines will be safely secured by the posts and I don't ever have to worry about it moving (however unlikely it is). I've had the brakes on now for about a month, and did lots of hard braking since, but when I removed my front pads last weekend I didn't notice any uneven wear. I guess time will tell how fast my front pads will wear out....compared to running the calipers the "proper" way round.
Fizz is offline   Reply With Quote
The Following User Says Thank You to Fizz For This Useful Post:
SkAsphalt (07-18-2014)
Old 07-16-2014, 07:34 PM   #22
The Sentinel
Drives: MY14 BRZ
Thanks for the feedback mate! I'll touch base with you again in a month or so to see how your pads are wearing. I'm very tempted to swap sides due to the post issue.
Old 07-16-2014, 10:13 PM   #23
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
No worries. I'm actually removing them next month to have them re-sprayed . So I'll be able to have another good look at the front pads again.
Old 05-04-2016, 01:47 PM   #24
asnatlas
Drives: 2013 - BRZ - SWP
Any updates on how these are holding up ?
asnatlas is offline   Reply With Quote
Old 05-19-2016, 01:58 AM   #25
brzy007
Drives: 2013 wrb brz
I know I'm a little late on this but for the rotors do you have to use the front DBA4654 (XS)
rear DBA42656 (XS) or could you just get the the regular the DBA4654
rear DBA42656 I just want slotted and it seems the XS make it drilled and slotted
brzy007 is offline   Reply With Quote
Old 05-21-2016, 08:28 PM   #26
gtishtar
Drives: 86
you can get DBA42656S-10 for rear and DBA4654S-10 for front
they are slotted only
gtishtar is offline   Reply With Quote
Old 07-29-2016, 12:50 AM   #27
In1t
In1t's Avatar
Drives: Black Limited JDM BRZ
thanks a lot for the info! i'm doing the same update at the moment. do you rekon it's better to powdercoat the calipers as once piece or disassembled?
In1t is offline   Reply With Quote
Old 12-11-2018, 08:36 PM   #28
Sleeper86
Drives: FT86 GTS white AT
anyone know where I can buy a bleeder plug? not the bleeder bolt, it's the one on the other side that blocks the bleeder hole, I striped it while swapping the bleeders, but couldn't find any replacement plug online.
Sleeper86 is offline   Reply With Quote
Evo X brembo brakes Justkiz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 08-12-2013 03:00 AM
STI Brembo HELP ~ Trap63 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 08-02-2013 07:59 PM
Brembo + STD R9 dompower Brakes, Suspension, Chassis 17 06-13-2013 08:56 PM
WORKS Stage 1 Complete Brake Package Upgrade 86_ZN6 Brakes, Suspension, Chassis 1 05-28-2013 05:57 PM
