Old 03-13-2014, 03:36 AM   #15
steve99
Originally Posted by regal View Post
Shiv I like you and don't take this the wrong way but Toyota didn't change the calib for no good reason. Its the first cal update that they will flash on a 2012 build car that ought to tell you something right there.
You are confessing that its a huge time consuming task, so there could very well be some changes with B01c that improve the engine life.
Personally thought the whole business cass for OFT was for the customer to tweak the latest factory rom. But doing all this tuning, flex fuel, vortec, headers, etc.
I think there are a lot more people who just want to avoid the dealer and tinker than risk E85 and Vortec on this iffy engine. JMHO
Mate if all you want is a stock rom then just ask on this forum somone will post up a stock b series and you can flash it to your car.
Old 03-13-2014, 03:47 AM   #16
regal
I've been awake over day so bear with me but didn't Shiv just say you can't do that with OFT.
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 03-13-2014, 05:27 AM   #17
steve99
Yep correct OFT will only load same cal id ROM,s
You could use Tactrix or some other flashing device or
If the ROM get is definitly compatable with you car ie an update.
1. Open the B01C ROM with a hex editor search for cal id B01C
2. Change the calid to A01C or A00C whatever you car is
3. save it.
4. the check sum will be wrong but OFT should fix this
5. load it to OFT
6. Flash it with OFT
7. if no go flash your standard ROM from OFT or another tune already in the OFT
Note I have not actually done this so its at your own risk
PS3 (GT6?) won't update 1.03 ZionsWrath Off-Topic Lounge [WARNING: NO POLITICS] 3 01-22-2014 01:33 AM
Mod Update.... UM FRS CANADA 12 12-25-2012 01:50 PM
Module ECM update? dem00n Issues | Warranty | Recalls / TSB 1 12-21-2012 11:52 AM
HQTScion Rep Update on FR-S HQTSCION REP Southeast 0 06-06-2012 11:18 AM
GT5 2.0 Update!... MF_DEUCE Off-Topic Lounge [WARNING: NO POLITICS] 11 10-15-2011 02:53 PM
