Old 03-10-2014, 04:24 PM   #15
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Originally Posted by fooddude View Post
Do Swift springs actually come in the "lowering spring/oem replaceable" format??
I thought they only came in small OD format, just for coilovers.
If, yes(they actually do come in a "lowering spring" format), do they have customizable and different rates to choose from?? I thought only RCE offers a "lowering spring" with the stiffest rates (4.5kg yellows and 5kg tarmc grays).
If Swift really offers "lowering springs" for the frs/brz in many different rates, please post a link or info where to buy and what they offer
I wouldn't mind getting a stiffer (6kg-8kg) high quality Swift lowering spring teamed with B8s
Idk about multiple swift rates but, I found some B8 struts on FT86speedfactory.com
Old 03-11-2014, 12:34 AM   #16
guslucatero
guslucatero's Avatar
Drives: 2014 WhiteOut
Originally Posted by cdrazic93 View Post
thank you for sure site....there are really good deals here!!
guslucatero is offline   Reply With Quote
Old 03-11-2014, 12:40 AM   #17
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Another good coilover that I completely forgot about that falls way under your price range, ST coilovers. $850, and allows a drop of .8 to 2 inches total, with 4kg/mm spring rate up front and 5kg/mm springs in the back.
Made by KW as well so quality is top notch. Most consider these as the best quality coilovers by far for under $1k. I'm personally going to go with these.
Old 03-11-2014, 01:27 AM   #18
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
St, tein or bilstein
Old 03-11-2014, 11:15 AM   #19
Racecomp Engineering
If you want to lower an inch or more and that's a priority, you'll want a coilover.
If your priority is handling at a low cost and want to keep things simple, our RCE Yellows are a good choice. Add Bilsteins or Koni Yellows to complete the package if you like. Only lower 20mm, but simple, fast, and fun.
- Andy
Old 03-12-2014, 04:13 PM   #20
dkx64
Drives: 2014 Frs
Definitely go with the ST coils if you can afford to go that route. You will need to get adjustable lower control arms to adjust camber
dkx64 is offline   Reply With Quote
Old 03-12-2014, 04:55 PM   #21
CSG David
CSG David's Avatar
TEIN Street Basis or ST Coilovers for under that $1k territory.
Old 03-12-2014, 04:56 PM   #22
dkx64
Drives: 2014 Frs
Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped GuerillaRacing Brakes, Suspension, Chassis 149 05-12-2015 06:53 PM
megan ez street coilovers good or bad? juanam0909 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 10-02-2013 05:34 PM
Megan Ez street Coilovers used 2 months... F-T Brakes, Suspension, Chassis 11 04-25-2013 11:55 PM
Megan Racing Street vs EZ Street g0lden Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 04-14-2013 07:50 PM
Megan Racing Street Series Coilover Kit DeeJayMajesty Brakes, Suspension, Chassis 4 03-22-2013 05:59 PM
