Old 03-04-2014, 09:46 AM   #15
wparsons
wparsons's Avatar
Originally Posted by BRZZZZZZZZZZ View Post
PSS are too soft for auto x once they warm up, Z11, RS-3 or RE-11 get my vote.
Not that I'm disagreeing, but for a compromise tire with someone new to auto x I doubt he'll be overheating them.
All auto x I've been to strictly forbid pre-warming tires, so it's whatever heat you get in them during the run only.
flickr
Old 03-04-2014, 12:27 PM   #16
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Originally Posted by Thorpedo View Post
PSS are harder than the other tires you listed.
Edit: Just noticed you said "after they warm up". Do you mean they grease out quickly? I highly doubt they are too soft.
Yes they grease too quickly and start to fall apart depending on the heat level is my experience with them, otherwise they are great street tires.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 03-04-2014, 02:27 PM   #17
xero404
Originally Posted by Khyron686 View Post
I want the Mich PSS but they are not avail in 235/40 - RE11's sound like a great option.
Other I was looking at for a bit more street a little less autox would be the falken FK453, or the conti extremecontact dw (though some say sidewalls too soft for hard autoX).
I don't care much about wear rating but super noisy tires annoy me.
its sorta weird for me to compare the PSS with the RE-11a since the PSS is a max summer tire and not an an extreme.
PSS is more comparable to the Bridgestone S04 Pole Position IMO.
I haven't had the re-11as for long to comment on the tire life but if its anything like the previous RE-11 its probably around 15-20k depending on driving style. I've done 2 track events and an autocross and they seem to be wearing pretty evenly.
xero404 is offline   Reply With Quote
Old 03-04-2014, 02:31 PM   #18
Thorpedo
The SquadWhisperer
Drives: '13 Ultramarine FR-S (STX)
Mine lasted 10000km on the street plus ~15 (guessing) autocross events at 3-4 runs each.
Thorpedo is offline   Reply With Quote
Old 03-04-2014, 02:35 PM   #19
BRZZZZZZZZZZ
Car Nut
That's not very long, I ran Direzzas on my much heavier 135i and those lasted 20000km and over 100 auto x runs including some drifting.
Old 03-04-2014, 02:50 PM   #20
Thorpedo
The SquadWhisperer
Ever think that our driving may be very different? Alignment? Stop and go Vs highway? Let me add, I am a driver who is TOO aggressive and I am slowly learning to calm down on course. Being a rookie may have had something to do with it :p Almost all of my kms were around town.
Old 03-04-2014, 03:34 PM   #21
f0rge
head of infinite swagger
Drives: 2013 FR-S 6MT
I went with Pilot Super Sport, great tire so far.
My concern wasn't just ultimate dry grip since this is also my DD, I needed something that worked just as well in the rain.
So far I'm very pleased with mine.
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater
2000 Silverstone M5 6MT - SOLD
2013 Ultramarine FR-S 6MT - Car Journal - SOLD
2004 AlpineWhite M3 6MT - SOLD
f0rge is offline   Reply With Quote
Old 03-04-2014, 03:45 PM   #22
YDNA
YDNA's Avatar
Drives: Raven FR-S
Not sure if most of you realize, but the rs3s are on crazy backorder right now and seems pretty impossible to get now
YDNA is offline   Reply With Quote
Old 03-04-2014, 05:22 PM   #23
BRZZZZZZZZZZ
Car Nut
Regardless of your driving situation, 10000km and 60ish auto x runs is extremely low for a expensive street tire like that. I have run Direzzas side by side with PSS on the same type of vehicle with the same mods and found Direzzas hold up much better and last longer under anything other than daily driving, which is why me myself would not recommend someone PSS over Direzzas if there's more than daily driving involved.
Old 03-04-2014, 05:36 PM   #24
Thorpedo
The SquadWhisperer
I must say, you've damned near got me talked into trying a set of Direzzas for the upcoming summer. I can't see them actually lasting me that much longer, but every km counts. Did you find the Direzzas hardened at all over time?
Old 03-04-2014, 06:46 PM   #25
BRZZZZZZZZZZ
Car Nut
I found my sets were nice and sticky right to the end, but the two major downsides compared to the PSS are more road noise and they are rock solid under 5 degrees Celsius, whereas the PSS seems a bit more compliant when it gets colder out.
Old 03-04-2014, 08:00 PM   #26
Thorpedo
The SquadWhisperer
I only drive the car in the summer, so no problem there. I have track wheels this year so I won't be on the ZIIs daily. Sounds like a good choice then. Thanks for the input.
Old 03-04-2014, 08:10 PM   #27
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Originally Posted by wparsons View Post
I run Dunlop ZII's (225/45/17) daily and for autox/track events. They're definitely not quiet tires, but they pass the wife test on the highway.
One thing to look at when picking tires is what other mods you plan to do. Tires like RS3's and XS's are lighter with softer sidewalls so you need more negative camber to maintain a good contact patch. It's not a bad thing, just something to keep in mind.
I need to remember this
Carlitoz3 is offline   Reply With Quote
Old 03-05-2014, 12:58 PM   #28
mxrider404
mxrider404's Avatar
Drives: 2014 Scion FRS Pearl White 6 Speed
Yea based on the input you guys have given and some other research I think I may go with dunlops. Any idea of what the widest tire I can put on the stock rims? Without rubbing that is.
mxrider404 is offline   Reply With Quote
XXR 527_ Good or bad wheels for autocross karma003 Tracking / Autocross / HPDE / Drifting 42 05-22-2014 09:33 AM
Good wheel/tire set up for daily driver Oburn Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 07-10-2013 02:21 PM
Autocross/18x8 wheels/what tires? rmz290 Tracking / Autocross / HPDE / Drifting 6 04-22-2013 12:34 PM
I slip my rear tires on a daily basis.... Laika BRZ Photos, Videos, Wallpapers, Gallery Forum 16 07-27-2012 11:44 PM
Good sporty daily driver? Staticz Scion FR-S / Toyota 86 GT86 General Forum 79 03-01-2012 04:20 PM
