Old 03-03-2014, 12:20 AM   #15
1stGenBRZ86
1stGenBRZ86's Avatar
use whatever method that works to remove the old filter, then replace it with one of these:
http://www.knfilters.com/search/prod...x?prod=HP-1004
and never look back...
1stGenBRZ86 is offline   Reply With Quote
Old 03-03-2014, 12:37 AM   #16
tzhu07
Originally Posted by CoupedUpSubie View Post
I like the filters with grit in the paint as I have never had to use tools to remove one.
Yeah, I already purchased a replacement filter for my upcoming oil change. It's a Purolator PureONE, and they have a textured surface meant for toolless hand installation.
tzhu07 is offline   Reply With Quote
Old 03-03-2014, 01:03 AM   #17
racecat
racecat's Avatar
Drives: Hot Lava FR-S MT
Originally Posted by supramkivtt2jz View Post
ugh.
take screwdriver and hammer. hammer screwdriver through filter. use the handle to loosen filter
I had to do this when I changed the oil some time after break-in. It was insanely tight, but this method works like a charm. Just be careful!
racecat is offline   Reply With Quote
Old 03-03-2014, 02:06 AM   #18
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Whatever any of you are doing, if you're installing the oil filter so tight where removing by hand the next time around is an issue, YOU ARE DOING IT WRONG.
-alex
Old 03-03-2014, 02:18 AM   #19
racecat
racecat's Avatar
-alex
I think generally people here are saying it's either the first filter from the dealership or after taking it in for service. Your average joe would have no reason to install a filter so tight...can't figure out why dealerships do.
Old 03-03-2014, 02:31 AM   #20
tzhu07
Can you describe exactly what angle you aimed your screwdriver while still having room to hammer it in?
Old 03-03-2014, 02:57 AM   #21
racecat
racecat's Avatar
If I recall (and that's dubious given I did it 7 months ago), I had to come in at an angle over the air box to allow enough room to use the screwdriver as a kind of "breaker bar." You want to drive it into the filter as horizontal as you can obviously, but the tightness in that area makes it a little difficult.
You might even be able to move part of the air box to give yourself some more room, I didn't even look into that.
I hope that was helpful.
Old 03-03-2014, 04:00 AM   #22
edsbreezy
edsbreezy's Avatar
Drives: 2014 Subaru BRZ Premium - Red
the filter was a "bi*ch" to remove on my first oil change. bought one of these and it worked for me:
edsbreezy is offline   Reply With Quote
Old 03-03-2014, 07:58 AM   #23
Malt
Drives: 2015 WRX
I bought and then returned that item. There wasn't enough clearance for the handle.
I've changed the oil several times using that very style wrench. You can tighten the strap with your hands to keep the handle the right position. Do you have a custom intake or something else in the way that isn't stock?
Also, are you sure you are turning it the right direction? Sounds like a dumb question but you never know.
Malt is offline   Reply With Quote
Old 03-03-2014, 08:49 AM   #24
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
Originally Posted by cycleboy View Post
I had to do this on my 1973 BMW 2002 the first time around. Someone had put the filter on retarded-tight and it was the usual narrow/hard to get angle. Tried everything and finally just pounded a screwdriver through it. Messy as fuck, but it worked.
EDIT: there is no way that's needed on this car w/ the filter right there on top.
just a guess, but im assuming you didnt punch a hole in it and let it drain first.
in these cars, i doubt itll be messy at all.
supramkivtt2jz is offline   Reply With Quote
Old 03-03-2014, 09:00 AM   #25
Muskokan
Drives: white Sport-tech
This is why you add oil around the seal before putting on your filter kids.
Muskokan is offline   Reply With Quote
Old 03-03-2014, 10:11 AM   #26
choi0706
Drives: t
-alex
your hand tight, my hand tight, and average joe hand tight are different..
you need to follow the directions on the filter.. which usually is 3/4to 1.5 turns from when the gasket touches the base.. thats the only way to properly do it.. and from what I've seen and done myself, its impossible to reach 3/4 without some tool of sort on most vehicles..
choi0706 is offline   Reply With Quote
Old 03-03-2014, 10:11 AM   #27
choi0706
Drives: t
factory filter has some grease on the gasket..
Old 03-03-2014, 10:38 AM   #28
MrTranxD
MrTranxD's Avatar
Drives: Scion FR-S
Ive never heard of hammering a screwdriver through the filter, but that seems....interesting? But overall, this thread is a funny read for some strange reason.
2013 Ultramarine FR-S 6MT
MrTranxD is offline   Reply With Quote
OEM Subaru engine air filter + cabin air filter autobrz Mechanical Maintenance and Tools 6 03-09-2014 09:28 PM
Does anybody know exactly what filter the injen Sri uses? I want to get a new filter Frsexxxy Engine, Exhaust, Transmission 13 02-19-2013 10:04 AM
PLS REMOVE Nezz Australia Classifieds 0 01-31-2013 05:59 AM
will polishing your car to remove swirls remove opti-coat? bacon_cheese_beer Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 10-25-2012 10:41 PM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
