#15 | |
Drives: Toyota FT/MT 86
Tank it's 50litres, if you divide 50/4 , each quarter gives around 12.5 liter. with this average I would be doing around 250km for the whole tank fill up. But I think it might have to do with the idling at 800rpm. It's way high |
#16 |
Sarcastic Bastard
Drives: '13 DGM BRZ, '13 Mini, 1999 Blazer
Here we go again with calculating fuel economy with the old divide the gauge into 4 equal parts..... You should wait until you have 10,000 km before even thinking about measuring fuel economy.
| The Following User Says Thank You to ntron1 For This Useful Post: | dssence (03-01-2014) |
#17 | |
Drives: 2006 Cayman S, 2007 Outback 2.5i
Secondly, how are you driving? Is it primarily city driving? Highway? What speed? What RPM range are you keeping the car in? How long is your average trip (from starting the car to turning it off again)? All of these factors can dramatically affect gas mileage. |
| The Following User Says Thank You to chrisl For This Useful Post: | dssence (03-01-2014) |
#18 | |
This is not rocket science, obviously each quarter it's not measured precisely on the fuel meter. But it's giving an approxiamte measurement of each quarter could be 12.5 liters name it 13.5 not more than that. So my calculation it's not far from reality and far from being practical it's what's happening for real. And reality is saying i''ve done only 60km with just 1/4 tank want it or not. Tell you more.. on my first tank I reached to the last quarter of the tank , and have only done 140 km don't know what else you want me to do, reach up to the point where the low fuel led starts blinking and there tell you how many km i've done, just to sound more logical?. No thanks. |
#19 | |
Thanks
#20 |
Sarcastic Bastard
Dessence,
Good luck to you. I just can't take it anymore. |
#21 | |
As for what you should do? No, you don't have to go until it starts blinking, but you should base your fuel usage on how much fuel it takes to top off the tank, not how much you think is gone based on the gas gauge. Finally, 140km down to the bottom quarter is really bad, but it is possible depending on driving style. As I asked above, how are you driving? |
#22 | |
On my second tank fill up, I've put 32liters with the last quarter tank left. And guess what's I've done 140km. How am I driving ? Well I'm driving like a grandpa, trying to be as gentle as possible on 1st and 2nd gear. To see if this thing give me a good efficiency. Shifting less than 3k for 4th , 5th. I never go past 3k rpms. So many thanks |
#23 | |
#24 | |
Exactly you just said it. I've done 140km when I did my 2nd fill up with the last quarter left. putting exactly 32 litres of fuel. That I can tell you for real. I'm driving calm, shifting always below 3k . Shortest 1st and 2nd gear possible |
#25 | |
If you are in stop and go city traffic all day your mileage will suck. So once again, please describe your driving conditions. Sent from my Nexus 5 using Tapatalk |
| The Following User Says Thank You to jvincent For This Useful Post: | dssence (03-01-2014) |
#26 |
Yep it's pretty much city driving. Stop and go mostly. but it's not like I'm stopping and go .. over and over. but yes it's city wise. But even if I'm city stop and go can it put down the fuel efficiency so much. IT could be adding to the fact my idle it's a bit high and i'm stopping and leaving in neutral that car. that might even add up a bit more to consuming fuel more. shouldn't be like that.. if we think new cars should be more efficient ad they use injectors and ports Versus my old ancient celica liftback 1979 year which uses a carburator it's also 4 cilinder, and I do the same stop and go routine.
#27 | |
If you are in city traffic all day you are going to get terrible mileage, plain and simple. If the highway mileage is bad then there may be an actual problem with the car. Sent from my Nexus 5 using Tapatalk |
#28 | |
| Rattling in 2nd or 3rd at low rpms | BigFatFlip | Engine, Exhaust, Transmission | 54 | 09-07-2015 08:54 PM |
| Turbo RPMs | Fabron757 | Forced Induction | 11 | 04-02-2013 04:35 PM |
| frs dancing rpms? | MontrealFRS | Issues | Warranty | Recalls / TSB | 10 | 10-19-2012 03:04 PM |
| Where are your RPMS | Dragon86 | CANADA | 13 | 07-26-2012 10:43 AM |
| RPMS!! | Spencer Strayer | Engine, Exhaust, Transmission | 82 | 09-15-2011 09:51 AM |
