Old 02-18-2014, 05:00 AM   #15
ZDan
ZDan's Avatar
Drives: '23 BRZ
Originally Posted by Lo View Post
What's the point in having high end torque? Would'nt you rather have low end torque for quicker starts?
POWER is what is important. Power is torque x rpm. Making torque at elevated rpm is key to making maximum power. That's why a 2.0 S2000 accelerates faster than the FR-S/BRZ. The s2000 makes peak power at 8300 and keeps making usable power up to 9000rpm whereas the FR-S/BRZ peaks at 7000 and signs off at 7400. Same weight, same torque, but S2000 revs much higher, so it makes more power, and as a result is 5mph faster in the 1/4.
Think of it this way: engine power, not torque, tells you how quickly you can accelerate from a given speed. If you make 200hp by spinning a 1.0 75 lb-ft engine up to 14,000 rpm or by spinning a 2.0 150 lb-ft engine up to 7000rpm, they'll give you the same acceleration (each geared appropriately of course).
1 horsepower is 550 ft-lb/sec. This is NOT "torque over time", it is rather the *rate of doing work*. The "ft-lb" term isn't torque, but work. Push something with 1lb of force a distance of 1ft in the same direction as the applied force and you've done 1lb x 1ft = 1ft-lb of work. Motion is required. As opposed to 1 lb-ft of torque. Hang a 1lb weight off the free end of a 1ft horizontal cantilever beam and you have 1 lb-ft of torque at the fixed end. No motion required, and the force and distance terms (lb and ft) are not in the same direction but perpendicular to each other.
So, 200hp is 200*550 = 110,000 lb-ft/sec. Rate of doing work, but also ability to apply a force at a given speed. Say, 110 ft/sec, which is 75mph. 200hp can apply a force of 1000 lb at 75 mph (110,000lb-ft/sec divided by 110 ft/sec).
That's 0.333-g for a 3000 lb car.
240hp is 132,000 lb-ft/sec, that's 1200 lb for acceleration at 75 mph. 0.4-g acceleration for the same 3000lb car. Quicker.
The Following 2 Users Say Thank You to ZDan For This Useful Post:
chrisl (02-18-2014), Luis_GT (02-19-2014)
Old 02-18-2014, 10:36 AM   #16
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
this discussion is useless without gearing information
and relative weight
and relative usage
The Following 2 Users Say Thank You to 7thgear For This Useful Post:
f0rge (02-19-2014), skye67 (02-23-2014)
Old 02-19-2014, 12:29 AM   #17
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Originally Posted by Mikeez View Post
The FRS has
151 ft/lb @ 6400 RPM
How would you compare this if we had a 200 ft/lb @ 3000 RPM
In other words, Low Torque @ High RPM VS High Torque @ Low RPM
the fr-s also has the same tq at 2500 rpm whats your point?
before drive train losses we actually have like 165 ft/lb fyi with headers the dip is gone and its closer to 170ft/lb from 2500-7000 rpm
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
Old 02-19-2014, 10:01 AM   #18
f0rge
head of infinite swagger
Drives: 2013 FR-S 6MT
I've had both types of cars. Both have their moments. You really get addicted to the swell of torque as you roll into the throttle on low revving torque engine, but they die above 5000rpm (mine was supercharged so that didn't help). The power is always there, you just need to put some foot into it and you're gone.
High RPM engines are less rewarding around town, but much more rewarding when you're getting on it. The extra downshifts required to get anywhere are a bit annoying but you get used to it and learn to anticipate. The wail from the exhaust at 8000rpm is like nothing else. Definitely more work, but I would say the rewards are also greater.
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater
2000 Silverstone M5 6MT - SOLD
2013 Ultramarine FR-S 6MT - Car Journal - SOLD
2004 AlpineWhite M3 6MT - SOLD
f0rge is offline   Reply With Quote
Old 02-19-2014, 01:35 PM   #19
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Originally Posted by ZDan View Post
POWER is what is important....
That's a very usable explanation.
You compared the F20c and the FA20 in this explanation, would you revisit it comparing an engine that makes more HP than Torque to an engine that makes more Torque than HP?
The example I have is a friend who races an STI makes 300hp Awhp but makes 330ft/lbs of torque. If "work" is a relation of torque-in-motion does that suggest, within the realm of your explanation, that his engine is leaving "work on the table" or is failing to turn all of it's torque into work?
Finally, the class he races in has a 10:1 power to weight ratio but the rules say if your engine makes more torque than HP, you have to average the 2 and thus his car has to weigh 3150lbs instead of 3000lbs. I feel like because his engine makes more torque than HP, he's being handicapped by having to be heavier than a competitor who makes 300hp and 300ft/lbs and can weigh 3000lbs minimum weight.
Your thoughts?
SCCA T4 - FRS
Old 02-19-2014, 01:49 PM   #20
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
Turbos sort of let you have the best of both worlds.
My evo: 276 hp @ 6500 rpm and 268 ftlbs @ 3000 rpm. Though the general consensus is Mitsubishi understated the hp due Japans gentlements agreement back then.
Nolan
pheoxs is offline   Reply With Quote
Old 02-19-2014, 03:45 PM   #21
ZDan
ZDan's Avatar
Drives: '23 BRZ
Power and torque are different things, so you can't really say you have "more torque than power". The relative values are quite different in different units systems for this reason.
But I know what you're getting at, an engine that makes peak power somewhat beyond 5252rpm vs. one that makes peak power below that rpm (roughly). A revvy higher-rpm engine vs. a torquey low-rpm engine.
It does mean that the engine isn't breathing well above 5000 or so rpm. If it was still making 330 lb-ft at 5000, that would be 314hp, so torque is falling off below that rpm.
I agree with you. They should go strictly by horsepower IMO.
My time trial club does something similar, they add 2/3*horsepower to 1/3*torque in lb-ft in what I think is a misguided attempt to come up with "real world" power. But you can't add or average values for two different things! Should just go by power. Torque by itself doesn't tell you anything about performance potential. Power does.
rice_classic (02-19-2014)
Old 02-19-2014, 04:13 PM   #22
Whitigir
Drives: 450 awhp twin turbo vr4
There is no argument here. Flat Torque Curve is the perfect one every-body want. Unless you can not have it, then it is depend. Torque is all relative to RPM and gear ratio.....when it is down to that, that is where people differ from each other, and that is why you need a test drive
Whitigir is offline   Reply With Quote
Old 02-19-2014, 04:35 PM   #23
chrisl
Drives: 2006 Cayman S, 2007 Outback 2.5i
It really doesn't mean much, since it's purely an artifact of the units. A relatively high horsepower with a relatively low torque means the engine has a powerband high in the rev range, while a low horsepower high torque engine has a powerband low in the rev range.
Not at all - it's turning all of its torque into work just fine. That just means that it is making its peak torque below 5252 rpm, and the torque falls off relatively quickly above that value.
Your thoughts?
He is being handicapped, without a doubt - an identical weight car making 315hp with a similarly broad powerband (geared appropriately) will definitely be faster, at least in acceleration. Horsepower, not torque, is what determines how fast a car accelerates (assuming it is geared correctly for the engine and desired usage).
chrisl is offline   Reply With Quote
Old 02-19-2014, 04:38 PM   #24
chrisl
That system will be very, very kind to a super revvy, low-torque motor that breathes well at high RPM then (and very unkind to a low-revving, large displacement or turbo engine).
Old 02-19-2014, 11:01 PM   #25
rice_classic
However if he had 315HP, without reducing his TQ value, he'd have to add even more weight. Are you suggesting that since his car weighs 3150lbs that if it made 15 fewer TQ's and 15 more HP, it would be faster? To me that sounds exactly right.
For you and Zdan: So to meet he rule of 10:1 it's simply HP to Weight. But if your car makes more torque than HP (like the STI) you have to average the two in order to determine minimum weight. So if you were to submit a rule change so that the minimum weight was only based off of HP, how would you make that argument to win the votes of your fellow racers in that class?
SCCA T4 - FRS
Old 02-19-2014, 11:04 PM   #26
rice_classic
Second question..
How would you go about getting a turbo engine to reduce torque and increase more HP up top? Change in turbo size, tuning, boost pressure?
SCCA T4 - FRS
Old 02-19-2014, 11:13 PM   #27
chrisl
Precisely. Note that when I refer to a broad powerband, it doesn't mean that it has to be in the same place, it just has to be broad. So, for a revvier, lower-torque motor, a broad powerband could mean that it's making within 5% of peak power from 5500-7400rpm, while for a high torque, lower rpm motor, it could mean that it is making within 5% of peak power from 4000-5800rpm (note that I'm not mentioning torque here). Either one will work just as well (assuming similar peak power) for racing.
(The broad powerband is important because it allows you to be making near peak power at all time, by shifting appropriately. A very peaky motor, especially with a wide ratio gearbox, will not be as fast as the peak horsepower number might imply)
The Following User Says Thank You to chrisl For This Useful Post:
rice_classic (02-20-2014)
Old 02-20-2014, 12:51 AM   #28
rice_classic
Good recap on the basics. I am aware of the relationship of TQ and HP but in the context of higher TQ than HP especially in a ruleset with a 10:1 power cap I hadn't given it much thought. I never thought of a torque value actually being a "penalty" on a race car. It's interesting how that plays out.
330TQ, 300HP car is required to weigh 3150lbs.
Take the same car, remove 30 ft/lbs so it's 300/300 and now, according to the rules, it can weigh 3000lbs and should be noticeably quicker because the engine still does the same amount of "work" but now the car weighs 150lbs less.
This is what happens when we have "rules".
SCCA T4 - FRS
[SYD] Milwaukee M18 1/2" High-Torque Impact Wrench 2663-22 eckoflyte Australia Classifieds 2 08-27-2013 06:19 AM
Torque Dip sierra Scion FR-S / Toyota 86 GT86 General Forum 68 07-22-2013 04:18 PM
500 hp & 550 lb/ft torque ? yes please LS13 Scion FR-S / Toyota 86 GT86 General Forum 3 06-17-2013 01:48 PM
torque mrnibbs Scion FR-S / Toyota 86 GT86 General Forum 21 05-13-2013 10:37 PM
