Old 02-15-2014, 10:52 PM   #15
1086
1086's Avatar
Drives: UM86 - 6MT
Lock your doors to avoid break in. K? K.
1086 is offline   Reply With Quote
Old 02-15-2014, 11:04 PM   #16
oldpueblo
oldpueblo's Avatar
Drives: Scion FR-S 10 #853
Holy shit read his question, it's specific about a hill.
oldpueblo is offline   Reply With Quote
Old 02-15-2014, 11:05 PM   #17
phloozy
phloozy's Avatar
Drives: Scion FR-S
drive the car.
phloozy is offline   Reply With Quote
Old 02-15-2014, 11:06 PM   #18
Tromatic
But most of the responses are not.
Tromatic is offline   Reply With Quote
Old 02-15-2014, 11:14 PM   #19
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
Originally Posted by Tromatic View Post
How odd that the people who design and build them seem to disagree with you. Do you have a newsletter detailing this conspiracy?
I did not see an option for an FR-S with a factory-run engine to the reccomended break-in mileage that you could beat on off the lot. Got a part number?
LOL at the still-alive "Italian tuning methods" of red-lining from the start.
the key to engine break-in is NOT operating the engine at a constant speed, or RPM.
The sole purpose to the break-in procedure is to seal the piston rings to the cylinder walls. This can only happen with high combustion pressures, and these pressures happen when the engine is forced to accelerate under load.
In a perfect world after a new engine is installed in a given vehicle, the car or truck should be driven on a vacant airport runway. The drive should consist of full throttle acceleration from a stop to approximately 60 km/h then brought down to about 15 km/h – with the throttle closed. Followed by another acceleration run to at least 60 km/h, followed by another deceleration to 15 km/h. This accelerate/decelerate process should go on for about 50 kilometres.
During the acceleration period, the piston rings are forced squarely against the cylinder walls, which trues them to each respective cylinder. In effect, the rings will conform to the shape of the cylinder.
The deceleration period creates a very low pressure in the cylinders (relative to the full power combustion pressures) and in the intake system. This low pressure is exposed to the cylinder valves and the oil that gathers in and around the valve guides. This low pressure (essentially a vacuum), draws this oil past the guides and into the engine cylinders. This helps lubricate the cylinder rings in excess of normal operation. The rings need extra lubrication because of the excess friction created by the break-in process.
http://www.theglobeandmail.com/globe...rticle4180794/
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 02-15-2014, 11:17 PM   #20
Tromatic
Originally Posted by WolfsFang View Post
Load does not equal redline, but that may be over your head given the above.
ETA: Full throttle also does not mean redline. Also over your head. Your own quote says nothing about running a new or rebuilt engine to max rpm from go. That you on the clowncycle?
Old 02-15-2014, 11:21 PM   #21
WolfsFang
Scrape Master
WolfsFang's Avatar
It says full throttle, that kinda means redline. I'v never heard anyone going full throttle to 4k rpm on a 7.4k rpm engine.
Old 02-15-2014, 11:24 PM   #22
fatherfork
Fears Hiccups
fatherfork's Avatar
Drives: Toyota badged 2013 Whiteout FR-S
Originally Posted by subiestyle View Post
So I've got a steep hill on my commute.
During break-in, whats better?
1. Shift to the highest gear possible and use the brakes to slow the car.
2. Shift to a lower gear and use the transmission gear to slow the car.
Engine brake using a gear which allows you to coast down the hill at an appropriate speed without going over 4000rpm. Use the brakes if necessary.
fatherfork is offline   Reply With Quote
Old 02-15-2014, 11:29 PM   #23
fatherfork
Fears Hiccups
fatherfork's Avatar
Full throttle is pressing the pedal to the floor (regardless of rpm or how long you hold it there). Redline means not releasing the pedal (which is not neseccarily all the way to the floor) until engine rpm redline.
So, not the same thing.
How did I get sucked into this? This is way off topic.
Old 02-15-2014, 11:30 PM   #24
Tromatic
Then you admit you are clueless? That's the first step, congrats!
Old 02-15-2014, 11:35 PM   #25
Luis_GT
I've full throttled in 6th gear without getting anywhere near red line...
The Following User Says Thank You to Luis_GT For This Useful Post:
fatherfork (02-15-2014)
Old 02-15-2014, 11:39 PM   #26
Tromatic
I never would have imagined someone could confuse the two.
The Following User Says Thank You to Tromatic For This Useful Post:
Luis_GT (02-15-2014)
Old 02-15-2014, 11:43 PM   #27
Luis_GT
I've seen worse...
Old 02-15-2014, 11:45 PM   #28
Brndn704
Brndn704's Avatar
So you admit you're a fucking asshole? That's the first step, congrats!
hahah Seriously though. WHY THE FUCK ARE YOU SUCK A FUCKING DOUCHE BAG ON THIS FORUM?!? Every thread you post in has some smart ass comment to someone else. Just shut the fuck up and if you don't have anything nice to say don't fucking say it.
/vent.
Brndn704 is offline   Reply With Quote
The Following User Says Thank You to Brndn704 For This Useful Post:
WolfsFang (02-15-2014)
Break In Again? Awstryker Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 09-07-2013 11:53 AM
Break in's over! Jertronic Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 33 08-06-2013 10:39 AM
Break in Y/N ? FiRStscion Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 83 07-26-2013 12:41 PM
ECU reset after Break-In paros28 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 02-19-2013 05:41 PM
Break in ipothas Issues | Warranty | Recalls / TSB 11 10-21-2012 04:41 PM
