Old 05-08-2012, 11:27 AM   #15
Turbowned
Turbowned's Avatar
Originally Posted by Afdad120108 View Post
Thats what i thought. The ECU and everything is made by subaru isnt it? So it should be easy to put it everything in the fr-s
The ECU is made by DENSO, just to clarify. It may have Subaru stamped on it, but it's a DENSO unit.
Personally I think a supercharger is a much better fit for this car, if you want to keep it a smooth and responsive driver's car. While I've owned and driven a few turbocharged sports cars in the past, I can't say they were necessarily driver's cars. Maybe the RX-7 and Mazdaspeed MX-5; those are the only turbocharged driver's cars that come to mind.
/opinions.
Old 05-08-2012, 05:07 PM   #16
Afdad120108
Drives: Mr2
Im well aware that engine internals and such would have to be changed i guess what im wondering is if the ppl that buy the brz are able to go to subaru for an " upgrade" an have the turbo installed tuned etc etc could we with our fr-s got to subaru and do the same thing since the engines are the same?
Afdad120108 is offline   Reply With Quote
Old 05-09-2012, 01:57 PM   #17
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
/opinions.
Yeah, small turbos are OK. My 2G Eclipse has a tiny Garrett which is good. But most cars have medium-large sized turbos which have too much lag to be fun and responsive IMO.
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Old 05-17-2012, 12:19 AM   #18
TwinscrollGT35R
Drives: 2006 Subaru
You can put a turbo or S/C on this car in stock form. Yes the injectors will have to get figured out. Since its a direct set up and the pressures are off the roof. But there is plenty of room on the FR-S/ BRZ to add a turbo in the same location as the wrx.
That being said. Once the ECU's are figured out, You would be able to bolt on a low boost turbocharger and run the car. 5-6 psi tops. But you will have to figure out the injector deal 1st.
Direct injection is not like the old days of the wally255 in a tank. These systems run at over 2800psi.
TwinscrollGT35R is offline   Reply With Quote
Old 05-17-2012, 03:09 AM   #19
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
So clearly the answer is actually no in a literal sense.
chulooz is offline   Reply With Quote
Old 05-17-2012, 04:30 AM   #20
serialk11r
Drives: '06 AM V8V Coupe
But the HKS S/C? I suppose they haven't actually told us what's really going on, but somehow I doubt that they developed new injectors and internals to make that thing work. As arghx7 noted, Toyota's dual fan spray injectors are quite unique.
The Following User Says Thank You to serialk11r For This Useful Post:
Saibot (05-17-2012)
Old 05-17-2012, 04:40 AM   #21
Dimman
Kuruma Otaku
Dimman's Avatar
Piggy-back.
Plus the developments parts display that had the headers also had cams, pistons and rods.
Because titanium.
Old 05-17-2012, 05:30 AM   #22
serialk11r
Piggy-back.
Ah. Thanks, didn't realize they were all part of the kit or whatever, 290hp on stock everything would be scary shit.
Old 05-17-2012, 05:46 AM   #23
coyote
coyote's Avatar
Drives: Slowly
Perhaps the old Frankenmotor idea needs revisiting.
New JDM Legacy FA20DIT short block with BRZ FA20 heads?
Give it cams and a turbo to support 8,000rpm, run all 8 injectors 100% of the time and see what breaks first.
coyote is offline   Reply With Quote
Old 05-17-2012, 02:18 PM   #24
wcbjr
Drives: 2006 Subaru LGT
how about just dropping in larger port injectors. leave the direct injectors alone.
wcbjr is offline   Reply With Quote
Old 05-17-2012, 02:25 PM   #25
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
YEAH!
CUZ IT'S THAT SIMPLE.
>____>
Old 05-17-2012, 03:30 PM   #26
Dimman
Kuruma Otaku
Dimman's Avatar
Because it operates on DI only at full loaf.
Because titanium.
Old 05-17-2012, 03:51 PM   #27
fatoni
Im sure if you are going the lenth to add a turbo you can take the time to play with the computer. Also loaf
Old 05-17-2012, 05:38 PM   #28
Dimman
Kuruma Otaku
Dimman's Avatar
Damn fat fingers and touch screen...
Plus your engine will be toast if you get your fueling and ignition wrong. Heh...
Because titanium.
Subaru 216A confirmed with 2.0L turbo, AWD, bigger and heavier than FT-86 Hachiroku BRZ First-Gen (2012+) — General Topics 118 11-16-2017 02:19 PM
Report: Subaru Coupe STI Model Possible, But Without Turbo Hachiroku BRZ First-Gen (2012+) — General Topics 168 07-28-2011 10:03 PM
Assumption: Subaru=Turbo / Scion=NA ftw-86 Scion FR-S / Toyota 86 GT86 General Forum 159 06-20-2011 03:28 PM
Subaru BRZ Coupe STI turbo charged pictures (renders) brandon BRZ Photos, Videos, Wallpapers, Gallery Forum 48 06-13-2011 04:15 PM
