#15 |
Drives: 2013 SWP BRZ limited
I only sell ID injectors now. I quit selling the others about a year or so back. The biggest thing that sets ID apart is that they provide proper injectors data for a variety of applications. In order to properly tune you need all the data. Without it you are guessing.
#16 | |
Drives: FRS with 2jz, 2015 STI 9.68@147
#17 |
Boosted
Drives: Not a supra....yet
#18 | |
#19 |
Drives: car
| The Following 2 Users Say Thank You to arghx7 For This Useful Post: | jamesm (02-06-2014), Sportsguy83 (02-06-2014) |
#20 |
| The Following 5 Users Say Thank You to jamesm For This Useful Post: | arghx7 (02-06-2014), Calum (02-06-2014), Lonewolf (02-16-2014), Sportsguy83 (02-06-2014), wparsons (02-06-2014) |
#21 |
NASA SpecE30 Racer
Noted for the future.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#22 |
Drives: Passat
My DW injectors were made by Denso. I didn't know that DW sold any Bosch injectors.
#23 | |
Drives: Slowly
I don't like how they test them with the wrong fluid and inflate the flow capacity, otherwise I'll agree that they are very consistent and the flow is linear. As James said, take the lovely data as a starting point ... not a bunch of numbers you can simply plug and play. |
#24 |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
ID vs DW vs XX is not so clear cut IMO. Basically most injector resellers/distributors take off the shelf bosch/denso/whichever injectors, find the right p/n and attach it to the application. Some end up using spacers, pigtails, etc...but the goal is to always be able to use the OEM body without having to re-drill the nozzle--that's economics. Then you just best match the flows from the ones you have and bundle them. This is what most injector companies do for you. We started using DW after getting mismatched sets with BS flow numbers from other vendors. (not DW nor ID). The DW stuff we have sold and tuned have been 100% and without issues on the BRZ and MX5 over the years. DW does their own flow testing so we have had no issues. However, in applications where flow has to be tweaked by boring out the injector nozzle, that flow testing is even more critical.
I don't understand why people are using 1000cc injectors on this car and running <500whp. We sell the 450 and 700cc DW versions, and I don't see over 25% capacity on the 700's at <350whp on pump. Using 1000s is just asking for driveability issues and roughness. You can do it easier on this since the DI is the primary fueling in the low range, but using the right injector for the application is much more cost effective from both the hardware perspective, and tuning time as well. With DI being able to support >250 hp without a serious overdrive, you should not need more than 550's to break the motor and trans in this car and have duty cycle to spare. |
| The Following 2 Users Say Thank You to Xero-Limit For This Useful Post: | arghx7 (02-07-2014), Fast_Freddy (02-07-2014) |
#25 |
If I had it to do over I'd go with smaller injectors, but only to save money. As you alluded to, the drawbacks to large injectors are pretty much a non-issue on this platform. I've never had much trouble achieving better-than-stock drivability on the turbo cars with injectors of any size, given a decent maf. It took about 3 months to figure out a solid process to do it, but it's repeatable and works on any setup I've come across so far. These IDs just make it a lot faster and easier to accomplish, and the end result in terms of cumulative fueling error is noticeably better.
| The Following User Says Thank You to jamesm For This Useful Post: | Ironsquid (02-07-2014) |
#26 |
Drives: SSM LT MT BRZ
Arghx7 is ofcourse correct but possibly a bit too PC
DW injectors started as an injector re-drill shop will horrible quality and consistency, they may be doing less shady work nowadays but that bridge is burned for my business. In reality what Jamesm would have said if he knew was "EV12/14 injectors are amazing" and they are, Bosch went through alot of trouble to make an injector that responds very quickly and has very linear flow rates even during it's opening period, and it has a very minimal opening time. They are indeed a superior injector but they can be sourced alot of places for very decent prices because Bosch has flooded the market with them. The response of the injector is what lets a 1000cc injector work so well even on a small engine such as ours. there was a video floating around a couple years ago of a shop idling a B16 on 1000-1200cc injectors at like 650 RPM and they could command very low AFR consistently, anyone that has ever tried to tune a standard injector in that situation knows what a feat it is to get low pulse width consistency from cylinder to cylinder and still have decent atomization. EV14 FTMFW... If you need to go HUGE loop for their cng or propane injectors which are the same internals with stupid hi flow rates (up to 2300cc IIRC) |
| The Following User Says Thank You to SkullWorks For This Useful Post: | jamesm (02-06-2014) |
#27 |
Drives: Sterling BRZ Ltd
I had DW's in my STi and I was not impressed with there physical quality, looked like used crayons. I switched to ID's and was very impressed.
If my BRZ gets to that point ID will be my first stop.
#28 | ||
That guy
Drives: Ultramarine mt FR-S
Ultramarine mt FR-S
P&L stage 1 turbo Prime Motoring Flex fuel Jr Tuned 506whp @17psi (e73) |
| Amazing Wax | geb2391 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 27 | 04-12-2013 04:42 PM |
| The most amazing thing I've done with my BRZ so far | azngolfur | BRZ Photos, Videos, Wallpapers, Gallery Forum | 8 | 01-09-2013 08:23 PM |
| Concept-Three-LED's DRL's are AMAZING! | soros151 | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 11-09-2012 01:42 AM |
