Old 02-04-2014, 09:29 PM   #15
pixel67
pixel67's Avatar
Drives: 13 Asphalt FRS AT
I bought and aem failsafe and turbosmart dual stage mbc. I like the idea of "stupid simple". Stage 1 is for 93 and stage 2 for e85. Should have it all installed in a few weeks.
Sent from my SPH-L710 using Tapatalk
pixel67 is offline   Reply With Quote
Old 02-05-2014, 02:19 AM   #16
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
how do u like that thing? it caught my eye since i don't want to rely on my tuner after i tune for a set boost level and i can adjust my low boost setting at will, but that hi price tag
Originally Posted by Sportsguy83 View Post
ONLY look for an EBCS EBC if the tuner can tune it perfectly or if you can get an EBC and are able to understand how to calibrated it and do so properly. If not its not worth it.
Also remember that with a stand alone EBC you an change it yourself.
About the EBCS and changing boost, you can tell your tuner to set you with 4 maps each with a different boost target.
well looks like I'm going MBC
lbroskee is offline   Reply With Quote
Old 02-05-2014, 09:05 AM   #17
pixel67
pixel67's Avatar
It wasn't too bad at $200, but seemed the best compromise. It has a very solid feel to it and changing boost via dial has a very precise feeling. I was going to TRY and mount the HI/Lo switch in place of the stereo USB connector since i don't use it.
The Following User Says Thank You to pixel67 For This Useful Post:
lbroskee (02-05-2014)
Old 02-05-2014, 11:30 AM   #18
lbroskee
lbroskee's Avatar
well I'm hearing nothing but good so ill probably pick 1 up. thanks. i just wonder if i can use a dif switch with it
Ecutek boost control with ebcs help. gdrider77 Software Tuning 11 02-02-2014 10:06 PM
(SOLD!) Tactrix Subaru EBCS with extended Harness Sportsguy83 Engine, Exhaust, Bolt-Ons 18 09-16-2013 10:21 AM
