Old 03-10-2016, 04:31 PM   #15
bhbnuckle
bhbnuckle's Avatar
Drives: 2013 Asphalt FR-S/2003 Honda Accord
Originally Posted by Killerbee View Post
A word of advice. Dont put anything that is more than 8" wide on a not lowered FRS. Otherwise it will look like an offroad truck
That being said, I dont see you mentioning any offset of the rims, which is important to answer your question.
If you dont lower your car on coilovers, you will have problems clearing the front inner struits. Anything with a highter offset than +38 will rub. Also be aware that a 9.5X18 with +38 (or lower) will poke out quiet a bit. It will not rub outside, but it will look offroadish if not lowered.
Now on the tire side, on a 9.5" wheel you should fit at least 245/35/18 tires. It will strech a bit, but not much you can do about it as the front is limited again by the inner struit.
So bottom line:
If you do not plan to lower your car, take 8" Wheels max.
If you plan to lower your car with springs, take 8.5" Wheels and have no tire strech, or 9.5" wheels and have some tire strech
If you plan to lower on coilovers, take whatever option you like since you will have more room in front (the coilover struits are smaller than the stock struits) and can also play a bit with camber settings
EDIT: Just saw the offset was in the links you posted. +43 and +45, the will rub in the front with stock supsension
Hey KillerBee
I'm trying to buy Enkei Raijin 18x8.5 front and 18x9.5 rear both offset 45.
Will this fit on my Eibach Pro kit spring setup?
I need your advice...
Thank you!
bhbnuckle is offline   Reply With Quote
Old 03-10-2016, 06:39 PM   #16
Killerbee
Killerbee's Avatar
Drives: GR86 / Supra MK5 MT / MR-S / Z4
Originally Posted by bhbnuckle View Post
Hey KillerBee
Thank you!
I'm not 100% sure on this. 18.8.5 with offset 45 in the front is very very tight to the inner struits, but it should fit. But be carefull with the tires you choose, a 245/35/18 should be the absolute maximum you put on these. But again, I'm not 100% sure on this, so try the wheels before mounting any tries (so you could still send them back if they dont fit.
Rear is no issue with 18x9.5 offset 45, this is fine.
@Edit on my post
Just found those posts here:
http://www.ft86club.com/forums/showp...&postcount=197
I know that the Goodrich Tires have big flanks, still, maybe go with 235/40/18 just to be safe. Again, this is a very tight fit if not used with coilovers
Killerbee is offline   Reply With Quote
Old 03-10-2016, 10:24 PM   #17
CBKLax3
CBKLax3's Avatar
Drives: 2015 FRS RS 1.0
Currently running this wheel and tire size and can confirm it fits. You are probably right on it being the maximum size as the shop told me that they were EXTREMELY close to the strut.
CBKLax3 is offline   Reply With Quote
The Following User Says Thank You to CBKLax3 For This Useful Post:
Killerbee (03-11-2016)
Old 03-10-2016, 10:42 PM   #18
Jonesy86
Jonesy86's Avatar
Drives: innovate sc frs
For what it is worth, i am running 18x 8.5+35 up front and 18x 9.5+35 in the rear. On swift springs (about a 1 in drop). Tires are 245/35/18 up front. 255/35/18 rear with spc lca. No rubbing up front or in the rear. @Chen 's rims are wimpy.
Corn fed, Intercooled Innovate sc tuned by vit viper, perrin crank pulley, raceng 72.5 mm pulley, Tomei EL header, Perrin front/mid pipe and 2.5 resonated exhaust, Cusco oil cooler, dual radium catch cans and more!
Jonesy86 is offline   Reply With Quote
Old 03-11-2016, 12:07 AM   #19
bhbnuckle
bhbnuckle's Avatar
@Edit on my post
Thank you for your answer!!!
Im going to run 225/4018 front 245/35/18 rear for this setup.
I will order my rims tmmrw, and hope theres no rub..
The Following User Says Thank You to bhbnuckle For This Useful Post:
Old 03-11-2016, 04:36 AM   #20
Chen
Regional Moderator
Chen's Avatar
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
I wish I would of gone 9.5 in the rear. But in the front are perfect. 18x8.5+45 on 235/40 tires.
Chen is offline   Reply With Quote
Old 03-11-2016, 06:53 AM   #21
bhbnuckle
bhbnuckle's Avatar
You shoulnt have any problem with +35 offset, thats far away from the strut
Old 04-01-2016, 02:33 PM   #22
bhbnuckle
bhbnuckle's Avatar
Hey!!
is it possible for you to post some pic of your car and fitment?
Thanks!!
Old 04-01-2016, 02:45 PM   #23
ZionsWrath
Thanks
ZionsWrath's Avatar
You will rub stock suspension. They fit with aftermarket "coilovers" because they have a smaller diameter than stock.
If keeping stock go 8.5 front 9.5 rear.
Old 04-01-2016, 03:45 PM   #24
Jonesy86
Jonesy86's Avatar
Hey!!
Thanks!!
Jonesygt86 on instagram.
Wheel Directory: Enkei Raijin 18x8.0 +45 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 66 03-30-2018 11:37 AM
JRP-Enkei RAIJIN 18 X 9.5 +45 5 X 100 CB72.6 Black Stav Canada Classifieds 26 01-22-2014 08:25 PM
Selling Enkei Raijin Wheels subayota89 Wheels and Tires 28 10-06-2013 09:26 AM
Wheel Directory: Enkei Raijin 18x8.0 +40 / 18x9.5 +45 seanmc69 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 07-08-2013 12:38 PM
enkei raijin 18x8 raven frs thebear21 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 08-06-2012 03:03 PM
