Old 01-30-2014, 11:22 AM   #15
ToyoburuBRZ
ToyoburuBRZ's Avatar
Drives: Black BRZ
Are you able to use both a positive shift kit bushing and a transmission mount or is just one needed?
ToyoburuBRZ is offline   Reply With Quote
Old 01-30-2014, 11:25 AM   #16
Malt
Drives: 2015 WRX
Kartboy short throw shifter (comes with rear bushing), kartboy trans insert, and MTEC springs. I didn't think the stock shifter could be improved much when I got the car but these parts made the feel amazing. I've also got an aluminum driveshaft which takes some slop feel out if the driveline.
Malt is offline   Reply With Quote
Old 01-30-2014, 01:11 PM   #17
AllStar0419
AllStar0419's Avatar
Drives: 2013 FR-S Asphalt
I don't understand what those MTEC springs are supposed to do.
the stiffer springs make the shifter want to stay center, it makes 2-3 and 5-4 shifts faster but every gear engages with a more satisfying feel. i was worried they would make the shifter too stiff and make it harder to push to the side but its perfect, feels more solid than stock.
AllStar0419 is offline   Reply With Quote
Old 01-30-2014, 08:31 PM   #18
TheseColorsDontRun
Keep calm and drive on
TheseColorsDontRun's Avatar
Drives: 2013 WRB BRZ Limited 6M
I have installed a short shifter in every car I've ever owned. This is the only one that I haven't felt the need. The best factory shifter I have ever had. Having said that, I have installed a Whiteline trans bushing insert, Perrin rear shift bushing and have a weighted knob. The best got better. I have no interest in installing a short shifter.
TheseColorsDontRun is offline   Reply With Quote
Old 01-31-2014, 12:07 AM   #19
cfordart
cfordart's Avatar
Drives: 2014 FR-S
I was determined to put a Billet Pro Shop shifter and shift knob in mine, I thought the stock shifter was too tall. I first put just the BPS shift knob on the stock shifter and was pleasantly surprised at how it made it look and feel shorter. Helped with the weight of the knob too.
I ended up installing the shifter, didn't want to waste the much nicer lockout on the BPS, but you might be surprised at how much just a knob would change the feel of the stock setup.
cfordart is offline   Reply With Quote
Old 01-31-2014, 01:07 AM   #20
Mikepage
Mikepage's Avatar
Drives: Scion FR-S 2013 Raven
Best shifter setup
But at the end, If I understand correctly, you have installed the short shifter too?
o= FR-S =o
Mikepage is offline   Reply With Quote
Old 01-31-2014, 01:50 PM   #21
cfordart
cfordart's Avatar
Drives: 2014 FR-S
Yes I did.
Even though the stock shifter had a shorter look and feel to it with just the BPS knob, I couldn't abide with the cheap look of the stock reverse lock-out.
Old 01-31-2014, 02:16 PM   #22
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Has anyone tried both the billet pro and the kartboy short shifters? Any noticable difference between the two?
I have the KB SS and like it, but I wonder if the billet feels any different.
^GT5 Replay Photo Mode^
Old 02-03-2014, 11:22 PM   #23
Mikepage
Mikepage's Avatar
I think the stock feeling is very good... Also better with Redline oil.
I don't think upgrading the shifter is necessary for the moment...
From my opinion, We will not get a better lap time on a race track with a modified shifter anyway.
I will upgrade it when I will got a problem shifting into speed.
o= FR-S =o
Old 02-03-2014, 11:28 PM   #24
SirBrass
SirBrass's Avatar
Just make sure you're using 75W-90 GL4 gear oil, not the lighter 75W-85 GL4, as the latter is out of spec and thus if you have a transmission failure due to the oil, your warranty claim can be denied as you were using oil NOT specified by Subaru/Toyota.
Old 02-04-2014, 07:36 AM   #25
Mikepage
Mikepage's Avatar
You think like me, Don't worry, I have used the Redline MT-90
o= FR-S =o
Old 02-04-2014, 08:21 AM   #26
SirBrass
SirBrass's Avatar
I always liked short shifters, though, & distinct shifts, & the factory shifter has a fairly long throw from what I'm used to. But as far as factory shifters go, it is one of the best.
Still like the kb short shifter better.
Old 02-04-2014, 08:56 AM   #27
mad_sb
Drives: 2013 Asphalt FR-S
Honestly, do the mtec springs, bushings of your choice, and adjust the reverse lock out (if you have any 2nd gear grind issues) before you do a short shifter... This is probably 90% of the improvement with bushings and springs. You may not feel the need to do a SS after bushings and Mtec springs.
If you do a SS, especially with bushings, be carefull what you choose. I beleive the billet pro will be prone to rattle, based on the ebay knock off version i purchased and latter threw in the trash due to incurable rattles at high rpm. The Kartboy is Much Much better design. I have not seen the TWM design up close so that may be an option as well.
Keep in mind that the kartboy short shifter includes the rear shift mount bushing. Also, don['t forget to put the trans in neutral before installing the mtec springs (makes putting it back together easier).
One other tip, my mtec drift shift knob is more prone to make any shifter rattle than the stock knob. Whole reason i got a SS is so i could use the longer style drift knob.. it just does not have enough weight to dampen vibrations... still looking for an alternative...
Old 02-04-2014, 08:59 AM   #28
SirBrass
SirBrass's Avatar
Mtec springs are on the way. When I install them, the rear shifter bushing, & transmission mount bushing, I'll decide then whether to stick with the kb short shifter or go back to the stock shifter (I've still got it around here somewhere).
Manual MT Shifter Boot Swap Onto Automatic AT Shifter Assembly? soulstice Cosmetic Modification (Interior/Exterior/Lighting) 52 01-24-2016 08:20 PM
kartboy short shifter and rear shifter bushing install and review. FR-S UMB FR-S DIY (Do-It-Yourself) Guides 21 10-18-2014 01:41 AM
Anyone have this setup? Gt86_nick Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 03-04-2014 05:32 PM
Shifter TSB 03-71-13 v. Perrin Rear Shifter Bushing swansons Issues | Warranty | Recalls / TSB 4 02-02-2014 02:27 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
