Old 01-29-2014, 02:50 PM   #15
JS + BRZ
Drives: 2010 MS3
I went with H16 Osram 45W from Autolismo vendor.
Will post some pics when I get them.
JS + BRZ is offline   Reply With Quote
Old 01-29-2014, 02:54 PM   #16
Diode Dynamics
Diode Dynamics's Avatar
Personally, I think our Stage 3's will be a closer match to the factory HID color, they are definitely closer to 4300K than our Stage 1's.
We will have more details on all of our LED's in the coming months
Nick C.
John C.
Diode Dynamics
Old 03-23-2014, 12:05 AM   #17
eazyace
Drives: wish
Any of these bulbs require wire harness etc... ? Or is just plug and play?
Thanks
eazyace is offline   Reply With Quote
Old 03-23-2014, 01:19 AM   #18
Husker BRZ
Go Big Red!!
Drives: 2013 SSM BRZ Limited
Thanks
Mine were just plug and play. The pics of mine are earlier in the thread (post 14)
Husker BRZ is offline   Reply With Quote
Old 03-23-2014, 11:12 AM   #19
eazyace
Drives: wish
Thanks bud
The Following User Says Thank You to eazyace For This Useful Post:
Husker BRZ (03-23-2014)
Old 04-17-2014, 01:25 AM   #20
BoxerFour
Drives: 2014 Brz Sport tech
Can anyone explain how to have the fogs on independent of the headlights?
Like so:
http://hidpowerhouse.com/wp-content/...fog_Gs-LED.jpg
This looks bad ass!
BoxerFour is offline   Reply With Quote
Old 04-17-2014, 07:29 AM   #21
speedrye
Drives: White
Wire your fog switch output (OEM or aftermarket) to an independent relay. If you also keep the output hooked to the car's stock harness for stock foglights (even though you won't use the rest of the foglight circuit), the indicator on the dash will still light up when the headlights are on.
Essentially, you'll have a stand alone wire harness for your fogs that taps into the signal on the stock switch, thus bypassing the computer that only allows the fog lights to be on when the headlights are.
speedrye is offline   Reply With Quote
Old 04-17-2014, 08:36 AM   #22
eazyace
Drives: wish
Thanks for the post. Is this a complicated process ? I am assuming this requires some splicing of wires ?
FR-S / BRZ Turn Signal LEDs! No Resistors! Switchbacks! Plug & Play Install! Diode Dynamics Interior Parts (Incl. Lighting) 158 08-08-2018 07:52 PM
<<< NEW Interior LEDs ~ FR-S + BRZ Domelight/Trunk/Packages (BRIGHTNESS OPTIONS)>>> KI_ZN6 Interior Parts (Incl. Lighting) 939 02-19-2016 12:02 AM
** INTRO PRICING** JWM Switchback Turn Signal LEDS For FR-S Owners JWMotoring Exterior Parts - Lighting 212 04-07-2014 12:24 AM
